    [Plugin] Helix along curve
    100 Posts 58 Posters 171.9k Views 58 Watching
      jsteacy
      Awesome script and great video on using it! Thank you! 👍
      • 3 Offline
        3dalbertsoft
        Thank you very much for the comments, this I am happy and motivates me to do more projects of this type! 😄
        please do not hesitate to ask questions if something is not clear or are having problems with something
        • mitcorbM Offline
          mitcorb
          Congratulations:
          This appears to be a very robust and refined version of helical construction.
          • N Offline
            nektares
            Fantastic! can´t wait to try it thank you for this amazing plugin!
            • utilerU Offline
              utiler
              WOW, what a neat little tool!!!!!!!
              Just Curious...
              • charly2008C Offline
                charly2008
                Hi 3dalbertsoft,
                Here's an attempt at a helix. I have one question, why is the radius of the tube limited?
                Charly
                • 3 Offline
                  3dalbertsoft
                  (Please forgive me for any errors in translation)
                  Karlheinz Hi, thanks for the image , this limitation occurs only if the program detects that could be built with very small length edges, there are circumstances in which the radius of the tube not allows the correct construction of all polygons in each ring that make up the tube, since this plugin is supported by followme tool of SketchUp, this limitation is needed to avoid bugs splats, but in the future could incorporate a tool "followme" own specialized for the needs of this plugin, which would avoid the need for the limitation.
                  You can try the tips mentioned in the alert message, may be helpful
                  • 3 Offline
                    3dalbertsoft
                    It is also possible to use this plugin to make a random offset
                    • mitcorbM Offline
                      mitcorb
                      Hi, 3dalbertsoft:
                      I see the Create Tube parameter highlighted, but I do not see the parameter that determines the offset to be the jagged profile. Or, as usual, did I miss something?
                      • Bob JamesB Offline
                        Bob James
                        mitcorb: maybe "Noise"?
                        • mitcorbM Offline
                          mitcorb
                          Hi, Bob:
                          Thanks. That would be the most logical choice. The only thing in the list that suggests randomness. The highlighted item threw me off.
                            joko
                            thanks very nice plugin
                              publied
                              nice!
                              hire me@ http://www.publied.it !
                                Here the help French Version + File linked of the French UI! ☀
                                Curiously it don't appear (UI file linked) on the Screen dialog box? 😮
                                Voici les options:
                                 Vous pouvez donner une valeur pour le rayon du début de l'hélice et une autre pour la fin (ces valeurs peuvent être positives ou négatives)
                                 Vous pouvez définir le nombre de tours de l'hélice (cette valeur peut être un entier positif ou décimal positif)
                                 Indiquez le nombre de segments qui composent chaque tour d'hélice (cette valeur peut être positive ou décimale entière positive).
                                 Modifier l'angle de début de l'hélice (la valeur de l'angle doit être donnée en degré et peut être un nombre entier ou décimal).
                                 Réglez le niveau de «bruit», ce qui peut ajouter une valeur aléatoire différente associé à chaque rayon de giration de l'hélice. L'intensité de ce bruit sera plus élevé lorsque la valeur d'entrée est plus proche de 1 (la valeur saisie doit être comprise entre 0 et 1).
                                 Vous pouvez choisir parmi cinq options différentes pour un paramètre appelé " Respect de la courbe", qui définit si la courbe hélicoïdale sera strictement respectée ou lissée. (lissée est recommandé pour de meilleurs résultats).
                                 Le «Mode de calcul», résume simplement plusieurs paramètres internes qui ne seraient pas faciles à comprendre par les utilisateurs. Parfois les courbes très raides peuvent donner des résultats inattendus, dans ces cas on peut lisser la courbe ou faire des tests différents en faisant varier la "méthode de calcul" pour savoir quel chemin prendre pour obtenir les meilleurs résultats pour cette courbe particulière. Si vous n'avez pas de problèmes, il est conseillé de laisser cette valeur "Mode Calcul".
                                 Vous pouvez définir le sens de rotation de l'hélice, c'est à dire dans le sens  horaire ou dans le sens opposé.
                                 Hélicoïde peut créer une courbe ou un tube circulaire.
                                 Si vous choisissez de créer un tube, vous pouvez régler votre ratio (la valeur saisie doit être supérieure à zéro et être un entier positif ou décimal positif).
                                 Vous pouvez spécifier le nombre d'arêtes du tube (qui peut être au minimum de 3, et cette valeur doit être un entier positif).
                                helix-EN-FR.zip
                                  blajnov
                                  I translated it into Russian without changing the name of the original folder
                                  helix-EN-US.lang, in the dialog box, all in Russian....
                                  Rename the file helix-EN-FR.lang in helix-EN-US.lang
                                    Cool trick! 😎
                                      matteo
                                      thank you very much for sharing this great plugin: very good idea!
                                      hire me: http://www.nonsolo3d.it/ !
                                      • panixiaP Offline
                                        panixia
                                        very nice plugin! love it! thank you for sharing! 👍 👍 👍
                                        i don't know if this can be possible, but it could be also nicer if you can add a sort of taper to the tube diameter! 💭
                                        • sboupS Offline
                                          sboup
                                          super ☀
                                          • sboupS Offline
                                            sboup
                                            Cool trick! 😎
                                            [attachment=0:13qlbtkx]<!-- ia0 -->helix.jpg<!-- ia0 -->[/attachment:13qlbtkx]
                                            J'ai procédé comme dit(renommer EN-FR en EN-US) mais la traduction n'est pas prise en compte et ça reste en anglais. J'ai essayé en renommant en -FR tout court, la traduction est opérée mais le plugin devient inactif. 😳
                                            I proceeded as told (rename EN-FR EN-US), but the translation is not taken into consideration and still in English. I tried renaming it -FR simply, the translation is performed, but the plugin becomes inactive.
                                            • 2 / 5
