    [Plugin] Helix along curve
    100 Posts 58 Posters 176.9k Views 58 Watching
    • guanjinG
      guanjin
      First of all thank you plug-in, there is a problem ,into a tube the normal use of English, translated into Chinese path can not be achieved, reference option to failure, thank you! The language file has an e-mail to you, thanks again!
      • charly2008C
        charly2008
        Hi 3dalbertsoft,
        thank you very much for this great tool.
        Charly
        • micioneM
          micione
          Many thanks 👍 👍 👍
          • V
            Vicspa
            I've been playing around with it, very very nice. Thanks so much. 👍 👍 👍
              saturne45
              ☀ It is a very great work, thank you
              very much.
              • jarynzlesaJ
                jarynzlesa
                nice one 👍
                http://www.vizualizaceschodiste.mypage.cz/
                  jsteacy
                  Awesome script and great video on using it! Thank you! 👍
                    3dalbertsoft
                    Thank you very much for the comments, this I am happy and motivates me to do more projects of this type! 😄
                    please do not hesitate to ask questions if something is not clear or are having problems with something
                    • mitcorbM
                      mitcorb
                      Congratulations:
                      This appears to be a very robust and refined version of helical construction.
                      • N
                        nektares
                        Fantastic! can´t wait to try it thank you for this amazing plugin!
                        • utilerU
                          utiler
                          WOW, what a neat little tool!!!!!!!
                          Just Curious...
                          • charly2008C
                            charly2008
                            Hi 3dalbertsoft,
                            Here's an attempt at a helix. I have one question, why is the radius of the tube limited?
                            Charly
                              3dalbertsoft
                              (Please forgive me for any errors in translation)
                              Karlheinz Hi, thanks for the image , this limitation occurs only if the program detects that could be built with very small length edges, there are circumstances in which the radius of the tube not allows the correct construction of all polygons in each ring that make up the tube, since this plugin is supported by followme tool of SketchUp, this limitation is needed to avoid bugs splats, but in the future could incorporate a tool "followme" own specialized for the needs of this plugin, which would avoid the need for the limitation.
                              You can try the tips mentioned in the alert message, may be helpful
                                3dalbertsoft
                                It is also possible to use this plugin to make a random offset
                                • mitcorbM
                                  mitcorb
                                  Hi, 3dalbertsoft:
                                  I see the Create Tube parameter highlighted, but I do not see the parameter that determines the offset to be the jagged profile. Or, as usual, did I miss something?
                                  • Bob JamesB
                                    Bob James
                                    mitcorb: maybe "Noise"?
                                    • mitcorbM
                                      mitcorb
                                      Hi, Bob:
                                      Thanks. That would be the most logical choice. The only thing in the list that suggests randomness. The highlighted item threw me off.
                                        joko
                                        thanks very nice plugin
                                        • P
                                          publied
                                          nice!
                                          hire me@ http://www.publied.it !
                                            Here the help French Version + File linked of the French UI! ☀
                                            Curiously it don't appear (UI file linked) on the Screen dialog box? 😮
                                            Voici les options:
                                             Vous pouvez donner une valeur pour le rayon du début de l'hélice et une autre pour la fin (ces valeurs peuvent être positives ou négatives)
                                             Vous pouvez définir le nombre de tours de l'hélice (cette valeur peut être un entier positif ou décimal positif)
                                             Indiquez le nombre de segments qui composent chaque tour d'hélice (cette valeur peut être positive ou décimale entière positive).
                                             Modifier l'angle de début de l'hélice (la valeur de l'angle doit être donnée en degré et peut être un nombre entier ou décimal).
                                             Réglez le niveau de «bruit», ce qui peut ajouter une valeur aléatoire différente associé à chaque rayon de giration de l'hélice. L'intensité de ce bruit sera plus élevé lorsque la valeur d'entrée est plus proche de 1 (la valeur saisie doit être comprise entre 0 et 1).
                                             Vous pouvez choisir parmi cinq options différentes pour un paramètre appelé " Respect de la courbe", qui définit si la courbe hélicoïdale sera strictement respectée ou lissée. (lissée est recommandé pour de meilleurs résultats).
                                             Le «Mode de calcul», résume simplement plusieurs paramètres internes qui ne seraient pas faciles à comprendre par les utilisateurs. Parfois les courbes très raides peuvent donner des résultats inattendus, dans ces cas on peut lisser la courbe ou faire des tests différents en faisant varier la "méthode de calcul" pour savoir quel chemin prendre pour obtenir les meilleurs résultats pour cette courbe particulière. Si vous n'avez pas de problèmes, il est conseillé de laisser cette valeur "Mode Calcul".
                                             Vous pouvez définir le sens de rotation de l'hélice, c'est à dire dans le sens  horaire ou dans le sens opposé.
                                             Hélicoïde peut créer une courbe ou un tube circulaire.
                                             Si vous choisissez de créer un tube, vous pouvez régler votre ratio (la valeur saisie doit être supérieure à zéro et être un entier positif ou décimal positif).
                                             Vous pouvez spécifier le nombre d'arêtes du tube (qui peut être au minimum de 3, et cette valeur doit être un entier positif).
                                            helix-EN-FR.zip
