[Plugin] Helix along curve
100 Posts 58 Posters 142.1k Views 58 Watching
  • 3 Offline
    3dalbertsoft
    Helix along curve 0.9
    This plugin initially emerged in order to meet design needs some personal projects. I've decided to add some additional details and publish this work. I plan to make more plugins when I have free time.
    These are the Helix along curve plugin options:
    • You can set a value for the radius of the helix start and another for the end (these values can be positive or negative).
    • You can set the number of turns of the helix (this value can be a positive integer or a positive decimal).
    • Specify the number of line segments that make up each turn of the helix (this value can be a positive integer decimal).
    • Modify the start angle of the helix (the angle value should be given in degrees as an integer or decimal).
    • Set the level of "noise" (the value entered must be between 0 and 1), this will add a different random value to each turn radius of the helix. This random noise will be greater when the input value is closer to 1 (the value entered must be between 0 and 1).
    • You can choose from five different options for a parameter called "adherence to the curve", which defines whether the helical curve will strictly or smoothly. (smooth is recommended for best results).
    • The "Calculation mode" simply summarizes multiple internal parameters that would not be easily understood by users. Sometimes very steep curves can cause unwanted results, in these cases smoother curves or slightly different tests can be performed by varying the "calculation method" to find out which will give the best results for that particular curve. If you are not having problems, it is advisable to leave this value in recommended mode (C).
    • You can set the direction of rotation of the helix, i.e. rotation in the clockwise or counterclockwise direction.
    • Helicoid will create with a curve or a circular tube.
    • If you choose to create a tube, you can set your ratio (the value entered must be a positive integer or a positive decimal).
    • You can specify the number of sides of the tube (which can be a minimum of 3 sides, this value must be a positive integer).
    Download:
    from PluginStore:
    sketchucation.com/pluginstore?pln=helix_along_curve
    Or from homepage
    3dalbertsoft.wordpress.com/plugins
    Donations with BitCoin:
    36umPz9XHZwJq63gZkBLjj7VUKWT7EFM2x
    This plugin is available in English and Spanish, if you want to help in translating this plugin into another language please contact me through this forum or by e 3dalbertsoft@gmail.com
    Acknowledgements to Alexander Schreyer Code Editor plugin I was helpful. Special thanks also to TIG and Thomthom, some of the plugins that have published I served as an example to understand several things.
    I would like to see things that make using this plugin 😄
      Jörg
      very cool, 3dalbertsoft, thank you!!!!
        cotty
        Thank you for this great plugin (and the detailed video)!
        my SketchUp gallery
          rv1974
          Albert, this amazing tool, so many options! 👍
          Thank you.
          Are you planning to add more options? If yes, may be you could add some special mode that instead of continuous curve (spiral) it would build closed shapes perpendicular to the path? In example (see video 0.30) it could create evenly enlargening N circles.
            Seems a new hit! ☀
              jolran
              Yes, very cool. And good instructions too.
                gilles
                Will give it a try, it seems very good!
                One option I would love:
                variable pitch.
                Any can dream.
                • F Offline
                  fossa
                  That is awesome. Great plug-in and thank you.
                  • N Offline
                    notareal
                    🎉 Nice work!
                    Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                      guanjin
                      First of all thank you plug-in, there is a problem ,into a tube the normal use of English, translated into Chinese path can not be achieved, reference option to failure, thank you! The language file has an e-mail to you, thanks again!
                        charly2008
                        Hi 3dalbertsoft,
                        thank you very much for this great tool.
                        Charly
                          micione
                          Many thanks 👍 👍 👍
                          • V Offline
                            Vicspa
                            I've been playing around with it, very very nice. Thanks so much. 👍 👍 👍
                              saturne45
                              ☀ It is a very great work, thank you
                              very much.
                                jarynzlesa
                                nice one 👍
                                http://www.vizualizaceschodiste.mypage.cz/
                                  jsteacy
                                  Awesome script and great video on using it! Thank you! 👍
                                  • 3 Offline
                                    3dalbertsoft
                                    Thank you very much for the comments, this I am happy and motivates me to do more projects of this type! 😄
                                    please do not hesitate to ask questions if something is not clear or are having problems with something
                                    • mitcorbM Offline
                                      mitcorb
                                      Congratulations:
                                      This appears to be a very robust and refined version of helical construction.
                                      • N Offline
                                        nektares
                                        Fantastic! can´t wait to try it thank you for this amazing plugin!
                                        • utilerU Offline
                                          utiler
                                          WOW, what a neat little tool!!!!!!!
                                          purpose/expression/purpose/....
                                          • 1 / 5
                                          1 / 5
