    Redraw go-p*d sprocket
    8 Posts 5 Posters 1.2k Views 5 Watching
    • tibetT Offline
      tibet
      hi,
      i´ve just make a 1:1 copy of my friend´s go-pad wheel, and i´d like to help him to
      redraw it, co he can create his own design. finally to cut new ones with laser .
      could you please help me to do it, or suggest another solution with your
      own experiences?
      thank you very much in advance!
      note: sorry, i´ve had to zipped the original, because it refused to upload it.
      http://s8.postimg.org/7sizx6led/CEDULE.jpg
      http://img.sceper.eu/images/KlisT.jpg
      other info about it here: http://www.goped-scooter-tuning.de/infos_eng/goped_kettenlaengen.html
      http://i.imgbox.com/acg9VbYa.jpg
      my_wheel.zip
      SU 2015 Pro on Win10 x64
        TECHDAVE02
        GEAR plugin
        http://rhin.crai.archi.fr/rld/plugin_details.php?id=1005
        how to
        404 Not Found
        (sketchucation.com)
        • sdmitchS Offline
          sdmitch
          The attached model contains sprocket blanks with 76, 82, and 98 teeth. The thickness is probably wrong since I coludn't determine the chain size.
          Sprockets.skp
          http://sdmitch.blogspot.com/
            sketchymick
            I'm not sure where I've heard this, but I understand that CNC laser cutting will be heaps slower on cutting arcs from a sketchup file compared to something like autocad that does true curves. So this could translate into higher cutting costs given all the curves in your design. Only going on hearsay, but might be worth investigating.
            Cheers
            • Mick
            "I love the sound that deadlines make as they rush past"
            • gillesG Offline
              gilles
              First hint:
              you can choose the number of segments in a circle, type 98s and enter.
              Second hint:
              The tape tool can resize the model....
              • tibetT Offline
                tibet
                hi guys,
                thanks for your valuable tips and experiences, especially to sdmitch for his excellent models share.
                may i ask how did you manage to find out the right angle and so on?
                it seems to me a very difficult task
                (...unless you did it for yourself before) 😍
                best of luck!
                http://sqlrus.com/sql/wp/wp-content/uploads/2012/06/thank_you.png
                • sdmitchS Offline
                  sdmitch
                  The sprockets in the model were created using my ANSI Sprocket plugin which can be found on my blog. Input consist of the number of teeth and the chain size which determines the pitch of the teeth and the thickness of the sprocket.
                  • tibetT Offline
                    tibet
                    hi guys,
                    thanks for your cool hints and valuable tips !!!
                    i´ve just visited sdmitch´s blog, and found almost endless list of amazing SU plugins.
                    well done, congratulations !!! i really like it. 👍 👍 👍
                    best of luck!
