    [Plugin] LaunchUp – A Quick Launcher for SketchUp
    108 Posts 33 Posters 97.0k Views 33 Watching
      TBA
      Hi Aerilius,
      thanks for all your work !
      I hope you enjoy the sun in Germany/Kaiserslautern also for the next days 😄
      Best regards from Hamburg,
      Thomas
        Maybe add a load trap if one package is missing - display a better error message?
          Finally got around to try out this gem. 😄
          But I'm a little puzzled by the search results some times. It appear to include results not matching my search. ❓
            Aerilius
            What package missing?
            At the moment, the search is a bit too tolerant (ie. it gives abbreviations too much weight, like "S… and"). Today evening I'll have a new version ready.
              In my case I was a bit quick in getting started and didn't install the command package. 😳 I didn't RTFM. 😒
              • Arty2A Offline
                Arty2
                Great work! I can now peaceflly remove making that exact plugin from my TODO list 😄
                • N Offline
                  notareal
                  This has a great potential.
                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                    Aerilius
                    I updated the plugin to version 1.0.4:
                    • I added Chinese and Spanish translations (thanks to caronte01, 麦兜 and 双鱼)
                    • the options should not break anymore with invalid input
                    • the webdialog resizing is better on OS X
                    • the search gives now significantly better matching results
                    • Fredo's tools didn't get into the index, now they are there
                      lionk
                      may be 2 problems?
                      the Apply & Cancel buttons of LaunchUpOptions webdialog have failed.
                      the Search dialog size adjusted to min_width incorrectly sometimes.
                        Aerilius
                        Thanks for noticing that! The dialog reloaded instead of closing.
                        • guanjinG Offline
                          guanjin
                          1.0.5 version of the search function does not work!
                            Same thing. I get no search results. No errors in Console or anything.
                            • guanjinG Offline
                              guanjin
                                TBA
                                Hi Aerillus,
                                I´ve installed the new 1.0.5 update and the plugin won´t work anymore on mac os x 10.8.3 😞
                                The plugin is loaded, but nothing happens with the the search -> no results !!!
                                The preferences button (left button) is now called "option" like the other other option button (right button). ??!!
                                Also the (older called) option window -> after clicking -> is pop up with a empty white sheet as in the versions before.
                                Hope you can fix this soon, or have a older version to download.
                                For now, there is only the 1.0.5 version, which has replaced the older ones in my SU by installing.
                                Best regards,
                                Thomas
                                  hm... 1.0.6 worked - but only after I erased the old version and installing cleanly over it.
                                    Error in validation proc of 'Scale Definition' (94457)
                                    undefined method `transformation' for nil;NilClass
                                    C;/Users/thm.ARC/Dropbox/SketchUp/Plugins/ThomThom/ScaleGroupDefinition/tt_scale_group_definition.rb;138;in `selected_group_scaled?'
                                    C;/Users/thm.ARC/Dropbox/SketchUp/Plugins/ThomThom/ScaleGroupDefinition/tt_scale_group_definition.rb;58
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Index.rb;419;in `call'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Index.rb;419;in `find'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Index.rb;388;in `each'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Index.rb;388;in `find'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Index.rb;260;in `look_up'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/LaunchUp.rb;197;in `show_dialog'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Dialog.rb;71;in `call'
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_LaunchUp/Dialog.rb;71;in `initialize'
                                    When searching I get errors in my console. My "Scale Group Definition" suddenly generates errors. Is the validation procs being called? It's like it's getting nil references.
                                      It'd be nice if pressing ESC while the search box was open would close it.
                                        Seems to do so. My plugin wasn't expecting that - the validation proc was only used within a context menu - and in SketchUp it'd only be called when some entity was selected and the validation proc made the assumption at least one entity was selected. It was trivial to adjust to it, but there might be more plugins with similar assumptions.
                                          Aerilius
                                          Isn't the purpose of validation proc to check for requirements like selection ❓
                                          Errors in other plugins don't (shouldn't) break LaunchUp, but maybe I make such messages only appear if $VERBOSE is true.
                                          No panic, there was a minor issue that has been fixed while you posted.
                                          I don't know what you mean by "options button" (I need clearer info, you can also send me a PM, or write in German 😉 ).
                                          If the dialog appears still empty (which should not be possible to happen aynmore), then it's because the preferences were corrupted, then open the Ruby console and paste AE::LaunchUp.reset
                                            Yes, but since the validation proc was only used in a context-menu and in those circumstances there would always be a selection I skipped that check.
                                            • 2 / 6
