    My Blender journey
    15 Posts 9 Posters 3.4k Views 9 Watching
      In the past that was the first program where after an hour I had not successed to create something! 💚
      Good luck! ☀
      here a site Blender for architects in French but seems there is a Popup language
      • simon le bonS Offline
        simon le bon
        My first " n'importe quoi " with Blender. I have called it "ArchitecturalMistake_000.blend" 😉
        http://i274.photobucket.com/albums/jj245/Spendauballet/Blender/ArchitecturalMistake001.jpg
        and rotated:
        http://i274.photobucket.com/albums/jj245/Spendauballet/Blender/ArchitecturalMistake002.jpg
        Don't know why, as I have already forgotten the shortcuts I learned yesturday 🤣 , I believe in it 😄 ☀
        Thank you Pilou for the link (and for your encouragements 😆 ). We have probably to open a specific thread for Blender links into the French section..
          mptak
          http://ocw.tufts.edu/Course/57
          I remembered this open course from Tufts. I wonder if there is a more current one or how well it travels to the current version.
          • mitcorbM Offline
            mitcorb
            mptak:
            Neal Hirsig, of Tufts University has created a full set of Blender videos at gryllus.net
            I believe this is still active. He goes through most if not all of the application in these videos. I recommend it. That site has been mentioned before in this forum several times.
            PS I have not checked the site in some time, but it is likely that he has updated some of the videos for the later versions.
            I once asked and received his permission to mention his site in the Blender forum.
              tomot
              Its downright embarrassing for me as a SU user to watch videos on You Tube. Where very well meaning users of software other than SU show me how to draw a simple 3d architectural house. The last example I watched was someone using C4D. The video was an hr. in length. I sat down and did the same project with more detail in under 12 minutes, using SU.
              Here is my reasoning where the extra time is spent: I'll chose a simple Cube primitive as an example.
              1. the ground plane does nothing except tell tell one where I am in 3d space.
              2. in order to move a simple cube from its centroid 0,0,0 position, you must take note of its co-ordinates to move it up by y/2 to sit on the ground plane.
              3. there is no 3d snapping one cube to the another cube or other 3d object. or snapping
                a cube to a particular location on predefined ground plane grid.
              Your forever using the orthographic views, just to correctly position simple objects.
              However there are many things SU can't do. Hence learning Blender is a must! Unless you have can afford to buy any of its main competitors.
              my 2 cents!
              my plugins
              tomot
              • mitcorbM Offline
                mitcorb
                Hi, tomot:
                I have to agree with you on principle, as you enumerated.
                • andybotA Offline
                  andybot
                  Haha, that's why my workflow with Blender involves doing all the modeling in SU and exporting (with TIG's excellent obj exporter) into Blender. Saves a lot of headache trying to actually model in Blender 😄
                    yes you can 😉
                    • andybotA Offline
                      andybot
                      yes you can 😉
                      Yes, rendering has come a very long way in Blender, but I don't imagine any of the building was modeled in Blender.
                      • F Offline
                        fossa
                        Lynda.com has some blender tutorials available. I've tried learning it several times now. Just can't seem to wrap my head around that program.
                        • mitcorbM Offline
                          mitcorb
                          Blender did have its own wiki at one time. I remember the gingerbread man.
