    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Re: [Plugin] Quick Lathe v1.2.0 31mar2013
    58 Posts 23 Posters 59.3k Views 23 Watching
      Trogluddite
      Thanks everyone, glad to hear you're liking it! ๐Ÿ˜
        Steve, now the requests are going to start. ๐Ÿ˜„
        Any chance of getting the plugin to create components instead of or in addition to groups? That would be even better for my work flow.
        Edit to add:
        One of the ways I would use this is to replace Follow Me for this sort of thing. For complex turned parts I like to quarter them. It results in less geometry to deal with when drawing and cleaning up around the pommels and it helps to keep file size lower. I make a component of the quarter and save it for future use. Sometimes I want just half a leg or a 3/4 leg for a kitchen island and they are easily made from these quarters.
          Trogluddite
          He he, yes, I've seen the outrageous way you all treat TIG, ThomThom, Dan etc., you greedy blighters! ๐Ÿ˜† ๐Ÿ˜‰
          Actually, I already had just that feature in mind - I work on a lot of mock-ups of control panels etc. so this is to be part of my little toolkit for designing knobs and dials.
          In fact, it's partly where that bug came from - trying to get the group axis/origin located consistently so that the components could also glue to a face.
          I'm just working on a little addition at the moment that gives a clear indication which way the axis line is pointing, and the option to reverse the direction. I usually use the 'trim template from a rectangle' method to make profiles, and it's 50/50 whether the component ends up upside down when you choose an existing edge - which rather spoils the effect!
            saturne45
            Very good plug. Thank you.
            • kenK Offline
              ken
              Nice plugin and thanks for your work.
              Noticed, since coplanar faces are not removed or even given an option to remove coplanar faces, after lathing, you can not push/pull what should be a face, i.e. the end of a pipe.
              I found this out be doing a lath, that should have made a section of piping. However, when I wished to make the pipe longer, I couldn't push/pull the ends.
              Again thank you for your time and effort.
              Ken
              • BoxB Offline
                Love it, Multiple on same axis excellent, nice clean and simple to use.
                But
                Perhaps I have misunderstood this bit
                • The arcs/circles of the lathe paths remain intact, for easy editing using the 'cardinal points' etc.
                It was the main reason for me testing, so sick of recurving/welding etc
                But my rings seem to be exploding.
                As you can see from the pushpulls in the pic.
                It also seem that if I recurve or weld the the ends of the extrusion, it will still break up when PPed. If I copy the profile away from the extrusion it retains the weld.
                  Trogluddite
                  Wow, so much interest, I am very flattered.
                  @Dave - ah yes, didn't see your pic's before. That's just what I had in mind when getting rid of the follow-me "end mess". Might be an idea also to have an option to remove the "end planes" of the extrusion too, as they would just become useless internal faces when duplicating the segments.
                  @Ken - definitely add that to the 'to do' list For my own intended application I left the 'facets' on co-planar faces as I often want to modify the face later - but I can see how that would not be expected for other applications.
                  @Box - interesting; again I think probably a case of me being a little blinkered by my own intended use (kind of more like Dave's wood turning examples). The circles/arcs that go around the lathe axis stay 'welded', which was my intention, but I hadn't considered the case of the initial 'profile' face being an arc or curve.
                  I'll look into that - getting the loops to stay in one piece proved to be rather tricky, so it may depend on how SU handles having welded curves that cross over each other
                  • BoxB Offline
                    Ah I see now.
                    Would never have thought it was in that direction.
                    Perhaps a choice of one way or the other is possible.
                      Steve, if you are going to modify the plugin for those quarters as I showed, may I suggest that you also see if you can work in a way to get the first and last segments in the extrusion to be perpendicular to the ends of the extrusion? Here's an example where I've set that up for a turned leg. The segments marked in red are perpendicular to each other. These would be the first and last segments for a quartered lathed shape.
                      http://farm5.staticflickr.com/4154/5190512797_5e0876427d_z.jpg
                      I normally set up these types of things that way so I can avoid the shadow line at the seam as you can see in my example in my other post.
                      As to getting rid of the profile faces, that would be a nice option although it isn't difficult to do manually. Of course for something like my table leg or your knobs, those faces aren't required. the main reason I remove the faces is so it won't show through at the seam lines.
                      • gillesG Offline
                        gilles
                        You made a very good one here, be proud of you.
                        Many thanks.
                          Trogluddite
                          Thankyou Gilles, it's been very satisfying to make something useful - and of course, we must not forget all the other kind and generous people here who made it possible for me to learn all these things.
                          Yes, it looks like it will have to be done that way - I made a little test rig to try putting the welded curves the other way, and bar a few minor bugs, that works OK. But whatever I do, SU won't let there be welded curves in both directions at once - I tried it using some of the other welding and recurving plugins, and it seems that the geometry just isn't allowed to work that way.
                          So it will have to be an either/or thing.
                          Hmm, i hadn't considered that, but i know what you mean, it does kind of spoil the appearance when you get those unsmoothed joins.
                          I'll have tinker and see how likely it is once I've tidied up a few other things - the code is getting a little unmanageable with all this "feature creep" going on, so I need to get everything nice and structured so I can see the wood for the trees.
                          PS) Just about there with the co-planar faces thing, so maybe a minor update coming soon just to get the low hanging fruit picked off.
                            Trogluddite
                            Version 1.1.0 now available in the Top Post.
                            New features...
                            • Co-planar faces can now be merged.
                            • When doing arcs, you can choose capped or uncapped ends (or hidden ends for 'seamless' component arrays)
                            • Can now make components as well as groups.
                            • New features added for making arrayed component 'segments' which will join seamlessly, including perpendicular end-caps (as per Dave R's examples in above posts).
                            • First draft of .pdf user guide (very rough - needs many pictures adding!!)
                            • Re-factored code should be a little faster and more robust (and maintainable!!)
                            Still to do...
                            • Face orientation correction only works 100% for closed solids ("capped" arcs and 360deg lathes). Sure this is fixable.
                            • Extrudable end caps - losing co-planar edges makes push/pull possible now, but still working on making them 'smooth aware' for when circles and arcs are extruded.
                              Trogluddite
                              Ooops' apologies to whoever just uploaded - that wasn't the right Ruby file. Re-upped!
                              • gillesG Offline
                                gilles
                                Just select the face WITHOUT its edges and a line for axis.
                                Works fine.
                                  driven
                                  Working now, very clever indeed...
                                    chin925
                                    quick lathe sir i installed the plugin but did not appear in tools menu thks
                                      Cool one ๐Ÿ˜„
                                      In the case of less 360ยฐ
                                      Does it possible to have the End caps as a new selection ? ๐Ÿ˜Ž
                                      And a negative angle (or similar) for have a continuous second form etc...! โ˜€
                                      In this case the "new selection" will make a "return" with the new axe! ๐Ÿ˜ฎ
                                      ( 3 curvated blue arrows wanted ! )
                                      notpossible.skp
                                      • jolranJ Offline
                                        jolran
                                        Cool!! I don't lathe that often except for coffee, but this one was clever.
                                        A quick question LOCAL_X. Cant You just use X_AXIS ? Since its already available can save you some typing ๐Ÿ˜„
                                          Trogluddite
                                          Thanks for the reports and kind words - good to know that it is (mostly!) working! ๐Ÿ˜„
                                          Hi there - there was a damaged file for the download - I replaced this very quickly, but saw that one person downloaded the bad file. Maybe this person was you?
                                          Please try with the newest file (v1.1.1) in the top post - if this one is also broken for you, then let me know, and I will see if I can find the problem.
                                          Hi Pilou - yes, negative angles can be made possible. I avoided negative angles before because it made shapes with a mixture of front/back faces - but with the new code, I will be a able to make this work with a simple transformation.
                                          Selecting "follow-on faces" is difficult at the moment because the end faces can be in different groups - but maybe by moving the original selection it could be done.
                                          I think first, I will work on the user interface - already the options are becoming untidy, so I think it needs a proper tool (e.g. rotation arrows for the selection, like in your picture) to make the tool operation more clear.
                                          He he, a "Doh!" moment! I didn't see the 'X_AXIS' etc. constants before - thanks for the tip, that will be very useful.
                                          • jolranJ Offline
                                            jolran
                                            Yeah, it doesent say so in the API. I think it was TIG who told me last year or so.
                                            • 3 / 3
