    [Plugin] Interactive Texture Editor for SketchUp [Prototype]
    16 Posts 6 Posters 21.7k Views 6 Watching
    • ArtlandiaA
      Artlandia
      @sir said:
      Without having tested it, I think this would only be useful if it created tileable textures πŸ‘
      Tileable textures is what SymmetryMill does! Thanks! Olga
      Artlandia: Pattern design tools for Illustrator, Photoshop, browsers, and SketchUp.
      • ArtlandiaA
        Artlandia
        We posted a new version of our SymmetryMill plug-in for SketchUp. Compared with earlier prototypes, the new version (0.2.0) is quite stable, and can even be used for production work. We consider it an advanced beta before the final release. There are also three tutorials to go with it:
        • Applying Textures to SketchUp Models (Basics)
        • Applying Textures to Curved Surfaces
        • Using the Color by Layer Style
        http://artlandia.com/labs/imgs/tutorials.png
        Let us know what you think! At this stage, we'd be happy to give a free subscription to SymmetryMill if you be the first to report a bug πŸ˜‰
        And finally, would there be interest in holding a little contest? You would take a SketchUp model (yours or from 3D Warehouse) and apply a SymmetryMill pattern that you create (or grab for free from Pattern Central)... We could also give away a SymmetryMill subscription as a prize.
        Please reply if interested (or email to info@artlandia.com) and we'll come up with some rules.
        Thanks,
        Olga
          jpalm32
          I think you need better examples. Not clear by the site what it does different then other plugins as it a[[lies to SU..
          But could be me, it usually is.
          • ArtlandiaA
            Artlandia
            OK, how about this:
            1. Select a surface in SketchUp.
            2. Fire up the plug-in; get a SymmetryMill pattern applied to your surface as a material (texture).
            3. Edit your pattern; see your model updated.
            If you just need bricks/other building materials/other ready-made textures applied to your model, you don't need this plug-in (there are plenty of textures already available, many for free). But if you want your own patterns applied as textures, then consider SymmetryMill.
            Re. more/better examples, we are working on that, but did you follow the links on this page? πŸ˜„
            Olga
              What happen on a sphere ?
              • ArtlandiaA
                Artlandia
                Well, SymmetryMill is supposed to do its job (which is interactive texture editing) with whatever texture mapping you choose. Here's what I get with the two methods I tried, projected and UV Tools (both with their own limitations):
                http://artlandia.com/labs/imgs/Sphere.png
                Olga
                BTW, nice art at the Renderosity gallery πŸ˜„
                  jpalm32
                  OK then.
                  Do Projected, UV Tools
                  & Your Plugin.
                  That's what I'm talking about.
                  It would be sooo clear with all three...get it?
                  • ArtlandiaA
                    Artlandia
                    @jpalm32 said:
                    OK then.
                    & Your Plugin.
                    Projected is already done, for a fashion model (that is, a generic case; see the end result at the bottom of the page). You'd map on a sphere EXACTLY the same way. UV Tools? Hmm, might be an idea.
                    But the point is that this plug-in's purpose in life is to work with whatever projection method you like. We can certainly add other examples too.
                      THX πŸ˜‰
                      • ArtlandiaA
                        Artlandia
                        Thanks All for the comments. The "SymmetryMill for SketchUp" plug-in is now released as a free, supported product. Details are here.
                        Olga 😍
                        • emkayE
                          emkay
                          Could user add gap on the material sides. Instead of making the texture seamless, user can insert/add gap (space)
