    [Plugin] CleanUp
    974 Posts 217 Posters 861.0k Views 217 Watching
      sunnix
      thank you so much !!!
      great plugin !
      • jhapo11J Offline
        jhapo11
        thank you for this plug-ins i will try it later. keep it up!
          Piratestef
          OK so i downloaden the TT_lib2 (2.7.1) file and the tt_cleanup file and put into the plug in folder.
          Why is it crashing? at startup it said: Error Loading File tt_cleanup.rb
          no such file to load -- TT_Lib2/core.rb
            Did you install TT_Lib2? Using the Install Extension button under Preferences? Or did you just copy the RBZ file to your plugins folder?
            And when you say "crash" - did SketchUp BugSplat? (Or did you mean you got an error message?)
              Sure, you must load also the new TTlib so TT_lib 2 πŸ˜„
              (yes install plugins is more & more boring! πŸ˜’
                Piratestef
                I couldn't find the install extention button..
                this is the bugsplat: Error Loading File tt_cleanup.rb
                I just copied the 2 files into the extentions folder
                  You need SketchUp 8 M2 or newer.
                  That is an error message. It is not a crash or bugsplat. It's a big difference and knowing exactly what it is makes it easier when trying to solve the problem.
                  RBZ files needs to be installed with the Install Extension feature.
                  For a general guide to installing plugins:
                  http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                  • I Offline
                    inasia777
                    Thank you very much Sir,
                    Thomthom, indeed it is an awesome plugin that i can proudly say one plugin you cannot be without in Sketchup.
                    Thank you very much again, Salutations.
                    Inasia
                      Piratestef
                      I got the plug in working but I have A model that's giving me trouble.
                      what settings should I need to clean up this file?
                      Dropbox - Error - Simplify your life
                      (www.dropbox.com)
                        I wouldn't be able to tell - not knowing what result you are looking for. Nor do I know what problem you are experiencing - and what settings you used then.
                          Piratestef
                          I just need clean faces. With how the model now is it had all kinds of holes and gaps in the faces.
                            Ahamd
                            hi ,, i download cleanup up plugin but it's not working ???
                              Need a lot more info than that. Error messages? Result not what you expected? No menus?
                                That looks to be due to poor geometry in the model. Not something that can automatically fixed. When I opened the DWG in AutoCAD I got a warning I'd never seen before, it'd encountered 30 errors and wanted to abort loading the file.
                                  tomot
                                  I created a simple cube greeble ruby a while ago that draws an array of cubes in xy, xz, yz, or xyz planes. My idea was to carve out cubes from these arrays to create other 3d objects, retaining the basic cube module, much like the Voxel idea. Attached is 3d object file.
                                  I ran Cleanup on this file. but it was unable to delete the redundant interior faces.
                                  In addition is Cleanup able to remove the unnecessary exterior cube lines while retaining the integrity of the 3d object?
                                  Hilbert.skp
                                  my plugins
                                  tomot
                                    Cleanup does not remove internal faces. It's a very difficult thing to do - determining what is "inside" from code. Look at TIGs list of plugins, he have at least one that does that job.
                                    "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                                      Piratestef
                                      Thanks for the help, I was working on a Solidworks file and wanted it as an sketchup file. So I made it a .dwg and there is the result.
                                      Do you know a way to get a solidworks model into a sketchup file?
                                        Afraid not, I've not used Solidworks - don't know it's export capabilities.
                                          Have you looked at TIGs tools?
                                            Solid Solver and Fix Solid should both do it - at least they where made to do so. Perhaps you have an edge case there.
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 44 / 49
