    Painting Plugin Help
    7 Posts 4 Posters 606 Views 4 Watching
    • renderizaR
      renderiza
      I want to create a plugin that will feel like I am painting. Have couple ideas but want to start by copying a 2D or 3D geometry and by pressing & holding a key it will keep pasting the geometry so that if I move the mouse it will feel like a Photoshop brush.
      Javascript Code that will be sended to Ruby with other code using params;
      if (keyIsDown[SPACE]) {
      paint = 1
      if (keyIsDown[SPACE] == false) {
      paint = 0 ;
      Here is Ruby Script ;
      if params['paint'].to_i == 1  ;
        Sketchup.send_action(CMD_PASTE) ;
      The thing is that when I click Spacebar the object paste itself but problem is I need to click with mouse to put it down and this disrupt the flow of things. I want to Press spacebar and object automatically paste itself down without clicking mouse.
      Any Suggestions?
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
      • Chris FullmerC
        Yeah, you need to specify in your code where to put the instance. You would do that with a pickhelper. Is this plugin written inside a SketchUp Tool class? You will need to do it as a tool to track the cursor position, so you can then insert the instance at the cursor position.
          The description is a bit lacking. Not 100% sure what you're code is doing, but when you say "I need to click with mouse to put it down and this disrupt the flow of things." I then take it you used Model.place_component? In order to just insert a component you use entities.add_instance.
          ... ah ... you trigger SketchUp's Copy and Paste commands. What you probably want to do instead is use a variable to store the reference to the instance or definition you want to "copy" - then you can use entities.add_instance.
          • Dan RathbunD
            Dan Rathbun
            Didier Bur has done several Component Spray plugins. Look at what he has done.
            I'm not here much anymore.
            • renderizaR
              renderiza
              Hi, thanks for the replays
              Chris Fullmer this might be the answer but I need to study how to apply this little more. If I am not mistaken this will get the coordinates of the object that is referenced under the mouse.
              So somehow I need to make a variable that gets the values of does coordinates so I can do what Thomthom said... entities.add_instance
              Dan Rathbun the Compo Spray has the same issue I am having and that is that in other to keep dropping coponent one has to keep clicking the left mouse click.
              It would be ideal to click & hold and components constantly keep dropping.
              I already have web dialog updating 15 frame a second all I need is a way to get rid of the multiple clicks and I am golden.
              Note: Still lack a lot of knowledge in creating geometry with code but little by little I will learn...thank you guys really appreciate it.
              • Chris FullmerC
                Here is a really quick tool that shows how to "paint" with components. I forget how the "flags" work, but it looks like you get a flag of 1 if the mouse button is down. Isn't there a list somewhere of the flags?
                I wrote this quickly as a test code. I run my code snippets like this in a multi-line code editor in SU (Like Jims, or Alex Schreyers, or Aerilius).
                You must have a component selected before running the snippet. Then just hold the left mouse button down and move the mouse and it will paint the selected instance.
                class Cltool
                def activate
                @@sel = Sketchup.active_model.selection[0]
                @@ents = Sketchup.active_model.active_entities
                def onMouseMove(flags,x,y,view)
                  ip1 = view.inputpoint x,y
                  point = ip1.position
                  if flags == 1
                    add_object(point)
                def add_object(point)
                t = Geom;;Transformation.new(point)
                @@ents.add_instance(@@sel.definition,t)
                Sketchup.active_model.select_tool Cltool.new
                • renderizaR
                  renderiza
                  Christ Fullmer you are a genius!!!
                  This transform SketchUp into the best painting application in my opinion...I will see If I can expand this & add new features to make it even better.
                  I am so excited!...again thanks!
