    Living Space
    10 Posts 7 Posters 929 Views 7 Watching
    • Nat1N Offline
      Nat1
      Hi, I read a lot of posts on here but don't post much, so thought I'd share my recent Podium renders. Always room for improvement so feel free to comment.
      regards,
      Nat
      SU Podium
      SU Podium
      http://www.jbarch.co.uk
      • W Offline
        wtrouser
        Wow! That first pic is especially amazing... the second doesn't have the same sense of depth to me, but that's like saying "the other gold brick isn't quite as shiny". Fantastic stuff.
        • srxS Offline
          srx
          The best Podium renders I've seen. Looks like best V ray renders. Congratulations.
          Could your share your post process secret?
          www.saurus.rs
          • N Offline
            nickchun
            Both look great to me. Are the chairs leather or plastic?- they look quite shiny. Cant help feeling that the area around them could be a bit brighter even if the window area then got burnt out a bit. Light dappling at the window is gorgeous though so might spoil it.
            • marked001M Offline
              marked001
              definitely the best podium renders i've seen, as well.. great job.
              http://www.revision21vis.com
              instagram: revi21on
              • Nat1N Offline
                Nat1
                Thanks for the comments, the chairs are intended to be leather I know they are a bit too shiny. I do all the normally PP things to the renders, brightness contrast, levels, auto colour etc, the way I got the subtle light on the first image is by doing this:
                Copy the main image. Desaturate the copied layer. Go to the level histogram. Pull the left triangule to the right until everything turns black apart from the window(s). Add gaussian blur to the new layer (blur to suit needs). Set the layer's blend mode to 'screen'. Adjust the opacity to suit.
                Hope this is helpful. I have attached another render of a Kitchen, rendered with Podium again.
                regards,
                Nat
                SU Podium
                  sepo
                  great renders...proves it is always end user whatever the tool.
                  • W Offline
                    wtrouser
                    Very helpful... and very well put. If only all instructions were as clear. And not to gush, but the composition and render of that first pic is truly stunning. It looks even better on second viewing. You managed to highlight the window view and fireplace without distracting, then the transition from light to dark and the depth and... yeah I'm going to seek a strong drink now. Great pics all around.
                    • Nat1N Offline
                      Nat1
                      Thanks for your comments Sepo, I know you were using Podium right from the beginning and posted a lot on the forum so I am glad you like it.
                      "wtrouser" I appreciate your feedback, thanks again.
                      regards,
                      Nat
                      • Bryan KB Offline
                        Excellent renders.
