    Edit Images on Server?
    17 Posts 3 Posters 929 Views 3 Watching
    • N Offline
      numerobis
      How did you (he) build your website?!?
      With Adobe Contribute?
      If yes, why can't you edit your image, update it in contribute and reupload it?
      I think, i don't understand your problem...
      Your "website" is stored in a folder on the server and consists of separated files like html-files, and maybe scripts or images. You can simply replace a file in this folder (or subfolder) with an ftp-client if it is not possible with contribute (which i can't believe).
      And your webhoster should have something like an ftp client on his service pages if you login under your account...
      I think 'edit image in external application' means that you can specify an image editor like photoshop to be opened when you click this function.
      • jeff hammondJ Offline
        I don't know what approach you should take but a little suggestion..
        it might be better to overlay your logo (or whatever) onto the image instead of a copyright notice.
        the image will then be a lot less usable to people wishing to do something shiesty with it but for others (majority of people), a logo etc will come across as advertising.. which to me at least, gives off a more positive vibe.
        ie- I personally wouldn't be too hyped on viewing a past projects catalog in which all the pictures were more blunty screaming "this is mine! you can't use it"
        just ideas ๐Ÿ˜‰
        • Joe WoodJ Offline
          Joe Wood
          My original site was built using adobe dreamweaver, and they set me up with adobe contribute so I could edit it. I've been adding pages, images Etc for the last 10 years or so. My last webmaster came on board about 8 years ago and was mainly helping me with a little scripting and graphics help.
          I don't want to delete the present image, then upload a new one with copyright info because I 'think' the new image instantly looses image search ranking. Am I wrong in thinking that? I'd use the same image name.
          I don't want to block people from downloading the images because many of them might become customers, I just hate it when I find pirated versions on my images on other websites, especially when they come up for my keywords.
          Joe Wood
          woodsshop.com/
          • N Offline
            numerobis
            Yes, if google image search is using hash code comparison then every manipulation will result in a different image.
            But what would you like to do then if you don't want to overwrite the image?
            • Joe WoodJ Offline
              Joe Wood
              Nume, what do you mean by overwright the image? Do you men put a transparent image over it so people can't download my original image?
              Joe Wood
              woodsshop.com/
              • N Offline
                numerobis
                no, with overwriting i meant replacing the image file on the server with a newer version.
                • Joe WoodJ Offline
                  Joe Wood
                  Isn't that what I don't want to do though, replace the image, for image search ranking?
                  with contribute I can go to that page http://woodsshop.com/PROJECTS/koi.htm, click Edit, then I can delete that image and upload a new one. Is that overwriting?
                  Joe Wood
                  woodsshop.com/
                  • N Offline
                    numerobis
                    Yes, sure... i meant what would you like to do instead, if you want to show a new image but you don't want to replace the old one? How should this work?
                    • Joe WoodJ Offline
                      Joe Wood
                      What I want is for this site to stop linking to my 3 images (2nd thru 4th)
                      http://ciudaddemexico.olx.com.mx/pisos-decks-madera-exterior-cumaru-ipe-teca-super-precios-terrazas-jardines-iid-265155312
                      I've sent three dmca notices over the last month to their server ultradns.net
                      but have had no response ..
                      here's the WhoIs page for that site http://whois.domaintools.com/olx.com.mx
                      so since I can't get my images removed, I'd like to put copyright text on that image (and the other two),
                      without the image loosing it's image search ranking
                      Google Image Search http://tinyurl.com/baoh7mx
                      Joe Wood
                      woodsshop.com/
                        if you want them to stop linking, why not break the links?
                        (but from where I'm sitting, it doesn't feel like misusing of your images anyway.. and probably more beneficial to you than anything else)
                        • Joe WoodJ Offline
                          Joe Wood
                          No, that image is showing up in image searches, using my keywords but landing you at that other site.
                          But you're right, my images (on my site) are showing up at the top of the search page so why should I worry about it.
                          I think I will stop fretting about it, I just don't like my images being pirated.
                          what does breaking the links mean? Sounds like this might also hurt my image ranking?
                          Joe Wood
                          woodsshop.com/
                            yes.. it would hurt the image rankings i imagine.. breaking meaning you just take those images down and reupload.. then the links on that other site will be dead because they're not linking to anything..
                            if i were you, i'd be more concerned with this site (which i found via the first site you showed)
                            403 Forbidden
                            (www.finewoodsmexico.com)
                            they've downloaded your image.. put their logo/info on it.. and are self hosting it.. with no sort of link back to you or image credit of anysorts that i can see..
                            that's copyright infringement
                            (whereas the first example you posted is not so much.. it's not much different than you putting their link here in this thread)
                            • Joe WoodJ Offline
                              Joe Wood
                              thanks I contacted that one place you provided, now I'm going to forget about it,
                              not a big deal,
                              just wish I could edit my images, seems like I can't, thanks for the help and advice ๐Ÿ™‚
                              Joe Wood
                              woodsshop.com/
                                just a quickie example of what i was saying in the first post.. you might want to consider something like this with future uploads..
                                • Joe WoodJ Offline
                                  Joe Wood
                                  naw mate, not going to worry about that image, mine's at the top anyway, no biggie,
                                  gawd couldn't do anything like that!
                                  I am starting to put a little copyright info on some images.
                                  I learned the hard way not to delete and then upload new keyword images, when I redid this one
                                  http://woodsshop.com/closeup/Japanese_Garden.htm and added the copyright info.
                                  it 'was' my highest landing page, and top of page for 'Japanese garden' image search,
                                  now nowhere to be found on that search or in my stats.
                                  Joe Wood
                                  woodsshop.com/
                                  • N Offline
                                    numerobis
                                    I think ultradns.net is only the DNS-server.
                                    The owner of the site should be OLX in New York
                                    Did you try to contact them?
                                    http://ciudaddemexico.olx.com.mx/contacts.php
                                    http://www.olx.com/contacts.php
                                    I don't know how this works with mexico and copyright ingringements, but since they seem to be located in the US...
                                    But concerning your ranking. I think you're at this place because of the image names and your page rank at google search. If i search for "koi pond deck" in the normal google search your page is on top.
                                    http://whois.gwebtools.de/woodsshop.com
                                    So i would say you can manipulate the images and keep the names and it should work, but no guaranty!
                                    Maybe you should ask a professional webdesigner and a lawyer for more information...
