    You are now editing multiple components
    56 Posts 6 Posters 7.6k Views 6 Watching
    • jeff hammondJ
      is there a difference?
      (practically speaking)
      • KrisidiousK
        Krisidious
        Yeah, I don't select components... I just double click them.
        By: Kristoff Rand
        • ashscottA
          ashscott
          And coz Im clutter-phobic I only turn "Entity Info" on when I need it
          Just some stuff I do with Sketchup.
          • jeff hammondJ
            right.. like when you want to check if a group is solid or how many copies of them you have in a model.. πŸ˜‰
            • jeff hammondJ
              [edit] oh.. and hey.. i'm not knocking your idea in a way it may appear..
              just seems like the tradeoff between having this information being presented in a slightly different way than the native method..
              -compared with-
              needing yet another plugin to load and (as i understand) running at all times..
              isn't worth it
              • KrisidiousK
                Krisidious
                I do have way too many already.
                By: Kristoff Rand
                • Chris FullmerC
                  This is a plugin that in theory could run fairly silently in the background. Wouldn't even need a menu item.
                  Double click on a component and a little window pops up and tells you that their are X other identical components. Or even just a note that reminds the user that this is a component. It could be fairly useful I think. If it was not too intrusive.
                  • ashscottA
                    ashscott
                    It would have no interaction from the user and would only be a few lines of code can't imagine it would slow anything down.
                    • jeff hammondJ
                      right.. that's where i was concerned.. the user can't switch it on or off.. it's always on.. even though you'll only use it for maybe 1/10000th of your session time..
                      possibly.. i simply don't know and as of late, i'm just weary of having too much going at once due to stability issues..
                      but chris who posted above you likes the idea ANd knows ruby.. and if he says it's ok then it probably is..
                      but you sort of messed up in your 'request' for a plugin because you said:
                      I wanted to write this as my first ruby project but it seems slightly trickier than a total ruby noob like me can handle.
                      so now you've put the ball in your court πŸ˜„
                      get a few lines going and post in the developers forum when you hit a brick wall.. then ask them for a little steering in the proper direction
                      [or, of course.. get lucky and open this thread in the morning and find that someone wrote it while you were sleeping πŸ’š ]
                      [edit] oh wait.. you're in NZ.. so the sleeping & morning thing might not work out in exactly the same way i've described there..
                      • ashscottA
                        ashscott
                        The point of the plugin would be to stop accidentally modifying components.
                        If you had to turn it on and off it would defeat the purpose because you would accidentally start modifying a manifold component and unknowingly modify all copies of that component.
                        It would not be intrusive because it could just induce a watermark popup in the corner of your screen.
                        Chris seems to understand what I'm getting at.
                        I have no idea what I'm doing but perhaps something like this is a start:
                        def onOpen(instance) setVar ("X","definitions.count") end if componentinstance.manifold? = true setVar("text","You are currently editing {getVar("X")} components") end if componentinstance.manifold? = true getVar ("text") end
                        Don't laugh, I've just started reading the ruby documentation this week.
                        To put it in terms that I actually understand:
                        If the user opens a component to edit it
                        Count how many instances of that component are manifold with the one the user has open
                        Call the number counted "X"
                        Display "X" within this sentence as a watermark in the top left corner of the screen:
                        You are currently editing "X" components
                        Also, I'm from NZ but living in India
                        • Chris FullmerC
                          What does the manifold bit have to do with it? Why do you only care if it is manifold? It would be more applicable to more people I would imagine if it worked on all components, not just the manifold ones I would guess.
                          Also, I could be wrong, but the notion of this popping up and disappearing on its own is actually a bit more complicated then might be first suspected. It will require an observer to be running at all times, so it will add a little overhead to the system. Anyhow, I would be interested in trying to make it work, see if its simple and stable.
                          • KrisidiousK
                            Krisidious
                            I thought he was talking about the actual manifold plugin... what do you guys mean manifold?
                            By: Kristoff Rand
                            • ashscottA
                              ashscott
                              I've probably misunderstood what manifold means. I thought it meant that a component had other components that would be modified along with it?
                              Perhaps there is a more computationally straightforward way of notifying the user?
                              A simple UI popup seems to cost very little but, as someone pointed out, that requires the user to click "OK" each time they open a component.....
                              • jeff hammondJ
                                i take that to mean that the object is solid or watertight..
                                as in: if entity info reports "Solid Component (9 in model)"
                                it could instead say "Manifold Component (9 in model)"
                                and mean the same exact thing.
                                • Dan RathbunD
                                  Dan Rathbun
                                  I whacked out an example yesterday.
                                  Serves a good example of how to dynamically have SketchUp attach observers to models as they are opened.
                                  It uses a "view based" model note,... tagged with an empty attribute dictionary, named with the plugin's OPT_KEY. (The transparency of the note is controlled by the user, via the Model Options dialog, in "Fade Rest of Model".)
                                  [Code] (EXAMPLE) Edit Mode Warning Flag
                                  I'm not here much anymore.
                                  • Chris FullmerC
                                    That's great Dan! Works well and is even a bit simpler than I was thinking in certain aspects. I like it a lot. Would you consider saving it as an .rb or .rbz file and making a true full plugin? I'd hate to think people will end up not using simply because they don't understand the simple process of pasting the code into a text file and naming and saving it correctly.
                                    • ashscottA
                                      ashscott
                                      Sorry, I probably haven't attributed that work properly, all credit to Dan Rathburn. Dan, let me know if you don't want that link there. I assumed that since you shared the code so freely that you wouldn't mind a download link.
                                      Really enjoy the plugin and have shown it to a few people who are really excited by it. Thanks for your help everyone
                                      • Dan RathbunD
                                        Dan Rathbun
                                        @ashscott said:
                                        Just trying to figure out how to make that text bolder...
                                        Well the bummer is, that the API does not (currently,) expose methods to set or change the font attributes for Sketchup::Text objects. (These font features have already been requested formally.)
                                        So the only way to control how transparent or opaque the note is, ... is via the Model Info dialog > Components panel > Fade Rest of model slider.
                                        • ashscottA
                                          ashscott
                                          Well at least there is some kind of fix.
                                          Excuse my ignorance, but what do edit flag X and Y do?
                                          I've played with them in and out of the script and can't figure them out....
                                          Also, is there anyone else out there that does engineering modelling that thinks this is a really important tool for reminding you when you could be unintentionally editing component(s)?
                                          • ashscottA
                                            ashscott
                                            Am learning a lot by going through the script and trying to make it a 'menuless' background plugin - like Chris suggested earlier.
                                            Am surprised at the amount of work and notation you have put into it Dan, is it a script from something else that you adapted or did you write all of this "off the cuff"?
                                            • 1 / 3
