    You are now editing multiple components
    56 Posts 6 Posters 7.6k Views 6 Watching
    • ashscottA
      ashscott
      Doesn't need to add another keystroke, it could just modify the watermark in the top left hand corner of the screen. Normally there would be no watermark but when you are modifying a manifold component the number of components currently being modified would be displayed.
      No extra keystrokes required.
      Have seen this watermark modification done within sketchyphysics before...
      Just some stuff I do with Sketchup.
      • KrisidiousK
        Krisidious
        Oh so just information... not a dialog box that you have to hit ok on... I'm down.
        By: Kristoff Rand
        • ashscottA
          ashscott
          Well, once you've got it reading and returning the info you want I can't imagine its much work to change how the info is presented to you whether a watermark or dialogue box
          • jeff hammondJ
            @krisidious said:
            If that were the case there should definitely be a way to turn it off.
            there's already a way to turn it off.. close the entity info panel
            πŸ˜•
            • KrisidiousK
              Krisidious
              Nice try Jeff but that only works while you have it selected, not while editing.
              By: Kristoff Rand
              • jeff hammondJ
                is there a difference?
                (practically speaking)
                • KrisidiousK
                  Krisidious
                  Yeah, I don't select components... I just double click them.
                  By: Kristoff Rand
                  • ashscottA
                    ashscott
                    And coz Im clutter-phobic I only turn "Entity Info" on when I need it
                    • jeff hammondJ
                      right.. like when you want to check if a group is solid or how many copies of them you have in a model.. πŸ˜‰
                      • jeff hammondJ
                        [edit] oh.. and hey.. i'm not knocking your idea in a way it may appear..
                        just seems like the tradeoff between having this information being presented in a slightly different way than the native method..
                        -compared with-
                        needing yet another plugin to load and (as i understand) running at all times..
                        isn't worth it
                        • KrisidiousK
                          Krisidious
                          I do have way too many already.
                          By: Kristoff Rand
                          • Chris FullmerC
                            This is a plugin that in theory could run fairly silently in the background. Wouldn't even need a menu item.
                            Double click on a component and a little window pops up and tells you that their are X other identical components. Or even just a note that reminds the user that this is a component. It could be fairly useful I think. If it was not too intrusive.
                            • ashscottA
                              ashscott
                              It would have no interaction from the user and would only be a few lines of code can't imagine it would slow anything down.
                              • jeff hammondJ
                                right.. that's where i was concerned.. the user can't switch it on or off.. it's always on.. even though you'll only use it for maybe 1/10000th of your session time..
                                possibly.. i simply don't know and as of late, i'm just weary of having too much going at once due to stability issues..
                                but chris who posted above you likes the idea ANd knows ruby.. and if he says it's ok then it probably is..
                                but you sort of messed up in your 'request' for a plugin because you said:
                                I wanted to write this as my first ruby project but it seems slightly trickier than a total ruby noob like me can handle.
                                so now you've put the ball in your court πŸ˜„
                                get a few lines going and post in the developers forum when you hit a brick wall.. then ask them for a little steering in the proper direction
                                [or, of course.. get lucky and open this thread in the morning and find that someone wrote it while you were sleeping πŸ’š ]
                                [edit] oh wait.. you're in NZ.. so the sleeping & morning thing might not work out in exactly the same way i've described there..
                                • ashscottA
                                  ashscott
                                  The point of the plugin would be to stop accidentally modifying components.
                                  If you had to turn it on and off it would defeat the purpose because you would accidentally start modifying a manifold component and unknowingly modify all copies of that component.
                                  It would not be intrusive because it could just induce a watermark popup in the corner of your screen.
                                  Chris seems to understand what I'm getting at.
                                  I have no idea what I'm doing but perhaps something like this is a start:
                                  def onOpen(instance) setVar ("X","definitions.count") end if componentinstance.manifold? = true setVar("text","You are currently editing {getVar("X")} components") end if componentinstance.manifold? = true getVar ("text") end
                                  Don't laugh, I've just started reading the ruby documentation this week.
                                  To put it in terms that I actually understand:
                                  If the user opens a component to edit it
                                  Count how many instances of that component are manifold with the one the user has open
                                  Call the number counted "X"
                                  Display "X" within this sentence as a watermark in the top left corner of the screen:
                                  You are currently editing "X" components
                                  Also, I'm from NZ but living in India
                                  • Chris FullmerC
                                    What does the manifold bit have to do with it? Why do you only care if it is manifold? It would be more applicable to more people I would imagine if it worked on all components, not just the manifold ones I would guess.
                                    Also, I could be wrong, but the notion of this popping up and disappearing on its own is actually a bit more complicated then might be first suspected. It will require an observer to be running at all times, so it will add a little overhead to the system. Anyhow, I would be interested in trying to make it work, see if its simple and stable.
                                    • KrisidiousK
                                      Krisidious
                                      I thought he was talking about the actual manifold plugin... what do you guys mean manifold?
                                      By: Kristoff Rand
                                      • ashscottA
                                        ashscott
                                        I've probably misunderstood what manifold means. I thought it meant that a component had other components that would be modified along with it?
                                        Perhaps there is a more computationally straightforward way of notifying the user?
                                        A simple UI popup seems to cost very little but, as someone pointed out, that requires the user to click "OK" each time they open a component.....
                                        • jeff hammondJ
                                          i take that to mean that the object is solid or watertight..
                                          as in: if entity info reports "Solid Component (9 in model)"
                                          it could instead say "Manifold Component (9 in model)"
                                          and mean the same exact thing.
                                          • Dan RathbunD
                                            Dan Rathbun
                                            I whacked out an example yesterday.
                                            Serves a good example of how to dynamically have SketchUp attach observers to models as they are opened.
                                            It uses a "view based" model note,... tagged with an empty attribute dictionary, named with the plugin's OPT_KEY. (The transparency of the note is controlled by the user, via the Model Options dialog, in "Fade Rest of Model".)
                                            [Code] (EXAMPLE) Edit Mode Warning Flag
                                            I'm not here much anymore.
                                            • 1 / 3
