    [Plugin]Draw Slope Normals.rb-v1.4-Mar 28,2013.
    36 Posts 21 Posters 55.7k Views 21 Watching
    • T
      tak2hata
      Hi,All.
      I create the managing tool for slopes like Site.
      Name:Draw Slope Normals.rb
      DOWNLOAD HERE:
      Get the latest version from the PluginStore:
      http://sketchucation.com/resources/pluginstore?pln=draw_slope_normals
      or AutoInstall from within SketchUp using the SketchUcation Tools
      update_v1.0b:Feb 13,2013:I correct mistake of dividing z value of curve.
      Update_v1.1:Feb 19,2013:Improves_ for 000additionalpluginfolder.
      update_v1.3:Mar 09,2013:Add tool bar.and small improve.
      update v1.31:Mar 2,2013:Add code "require 'sketchup.rb'
      update v1.4:Mar 28,2013:Bugfix.(Error with the vector(0,0,0) is exists.)
      General disclaimer
      I MAKES NO GUARANTEE OF VALIDITY about this script.
      Please use this script at your own risk.
      Enjoy!
      by TAK2HATA
      • guanjinG
        guanjin
        Great, thank you! πŸ‘ πŸ‘
          sawaken
          γŠγŠγ€€γ„γ€γ‚‚γ‚γ‚ŠγŒγ¨γ†γ”γ–γ„γΎγ™γ€‚
            antoniogulino
            Thank you very much for this new awesome plugin!
            • srxS
              srx
              β˜€
              I think it will be very helpful. Thanks a lot!
              www.saurus.rs
                dtrarch
                OMG
                Tak2 what a killer app and just perfect for concept work when no 3d topo data is available.
                A true "Sketch" tool and JF'n brilliant. β˜€
                WOW
                Thank you so very much.
                Hope things in Japan are better for all now. πŸ‘
                dtr
                  seasdes
                  A trully awsome plugin that will be usefull to many thay need to model terrain.
                  Walter
                  Using Sketchup Pro 2019
                    A new hit ? β˜€
                    • Chris FullmerC
                      This looks great! I hope I get a chance to use it soon, thanks!
                      • T
                        tak2hata
                        I 'm sorry.I made mistake.
                        So I update this script to version 1.0b.in Feb 13,2013.
                        Now it calculate the dividing z value of curve from XY distance between vertices.
                        The previous version did from XYZ distance.
                        Thanks.
                        by TAK2HATA
                        • U
                          unclex
                          it's wonderful
                            dtrarch
                            Tak2
                            Sure would be nice to have the options rt click contextual once the script has been started. πŸ’­
                            Any chance please.
                            dtr
                            • AureusA
                              Aureus
                              Does anyone know why this happens?
                              [b]^Error Loading File draw_slope_normals.rb
                              private method `gsub!' called for nil:NilClass
                              Is this a plugin for Sketchup 7 or 8? I have both. S7 doesn't recognize it and S8 reports this error. I put it into the folder 'Plugin' after unzipping it. The folder 'draw_slope_normals_v1.0b' went to the folder Plugin but still doesn't work. I tried to put the sole RB file 'draw_slope_normals.rb' but nothing happened.
                              I use Windows XP S3.
                              Sorry for asking this but usually creators of plugins usually post these small accompanying instructions themselves. πŸ˜„
                              Cheers to everybody.
                              • T
                                tak2hata
                                Hi,i update this to version1.1.
                                This will work in additional plugin folder.
                                Hi,dtrarch.
                                I add context menu when tool is active.
                                Hi,Aureus.
                                I modified by replacing "gsub!" to "File.expand_path".
                                I did not test it on mac os,yet.
                                Thanks.
                                by TAK2HATA
                                • AureusA
                                  Aureus
                                  Thank you, tak2hata.
                                  I haven't expected such a quick reply to my first question and post ever on this site.
                                  It seems you did performed necessary corrections my case requested as I was perfectly able to install 1.1 version of your plugin. Now I'll give it a go and see what'll happen. At the moment I'm modeling a river bank and I hope 'Draw Slope Normals' will turn into a very handy tool. πŸ˜‰
                                  P.S. It's good that keyboard shortcuts can be given to the commands.
                                  Greetings from Bosnia.
                                    dtrarch
                                    Tak
                                    Breakthrough plugin IMO and thanks again.
                                    You are truly the Miyamoto Musashi of code.
                                    Dave
                                    aka dtrarch
                                    • B
                                      Ben Ritter
                                      Thank you for your generosity.
                                        Mra
                                        Thank you x1000000000000000000000000000000000000000
                                        This is much needed in sketchup and for you to share with the community is so nice. Levels in SketchUp wohoo!
                                        • AureusA
                                          Aureus
                                          What kind of logic is applied for indicating z value?
                                          When I have the cursor over a single spot (the end of a line) the z value is displayed and everything seems fine. But when the cursor is over a line sometimes lower value is displayed and sometimes higher - or in other words, once indicating the value of lower end and on other occasion on some other line indicating the value of its higher end.
                                          So far I couldn't figure out what value is indicated when having the cursor over a face and in what relation it is to actual values of its edges.
                                          When you have a line with 2 ends one having z value of 1.7 and the other having z value of 1.9, whatever figure is displayed (1.7 or 1.9) for it when you write down a new value (say 1.5) both ends have that new and same value, putting your line in horizontal position.
                                          It seems this plugin has no respect to the groups as you can edit a group 'from outside'.
                                          At the end I have one actual proposal. When you undo a step (you are not satisfied with the result of just put z value) - you are out of the command. Then you must run the plugin again. Can you make it provide you stay in the current command when you undo a step? My opinion is that it would speed up your workflow since it's a bit annoying and time-consuming starting the plugin again over and over after undoes.
                                          • T
                                            tak2hata
                                            I update this to version1.3 in Mar 09,2013.
                                            Add Toolbar.
                                            and small improve.
                                            Hi,Aureus.
                                            The logic of modifying Z value is simple.
                                            If you click Vertex it change z value of that vertex.
                                            If you click Edge it changes z value of the vertices connencted to that edge.
                                            If you click Face it changes z value of the vertices connencted to that face.
                                            When the same positon of vertices clicked,The vertex in active_ editing group/component is preferred.
                                            But the vertices are not same position,the vertex that near to camera is preferred.
                                            Thanks.
                                            by TAK2HATA
