    What defines an identity transformation?
    17 Posts 3 Posters 625 Views 3 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @thomthom said:
      The flag doesn't have to be computed on every call, just when the matrix' values has been changed - and that's set in #new and #set! . Right?
      ALSO ...
      t3 = Geom::Transformation.axes( Geom::Point3d.new(0, 0, 0), Geom::Vector3d.new(1,0,0), Geom::Vector3d.new(0,1,0), Geom::Vector3d.new(0,0,1)) %(#008000)[>> #<Geom::Transformation:0x753fe38>] t3.identity? %(#008000)[>> false]
      I'm not here much anymore.
        Dan Rathbun
        ALSO ...
        t4 = Geom::Transformation.scaling( 1.0 ) %(#008000)[>> #<Geom::Transformation:0x7621cc0>] t4.identity? %(#008000)[>> false] t4.to_a %(#008000)[>> [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]]
          Dan Rathbun
          I would consider this an API bug, myself.
          Workaround 1:
            def indentity_transform?(t)
              t.to_a == [ 1.0, 0.0, 0.0, 0.0,
                          0.0, 1.0, 0.0, 0.0,
                          0.0, 0.0, 1.0, 0.0,
                          0.0, 0.0, 0.0, 1.0 ]
          Workaround 2, a mixin module:
          module Mixin; end
          module Mixin;;Identity
            def indentity?()
              self.to_a == [ 1.0, 0.0, 0.0, 0.0,
                             0.0, 1.0, 0.0, 0.0,
                             0.0, 0.0, 1.0, 0.0,
          end # Mixin module
          Use mixin to change only individual transforms thus:
          require("Mixin/indentity.rb")
          # .. later
          tran = Geom;;Transformation.scaling( 1.0 )
          tran.extend(Mixin;;Idenitity)
          if tran.identity?
            # do something
          else
            # do something else
            If you want the optimisation you do the check in #new and #set!
            • AdamBA Offline
              AdamB
              But if you apply an Identity, it is, by definition, a transform that changes nothing, so no harm done.
              The method may not cover all cases, but its not really wrong either.
              The problem, Dan & Thomthom, is floating point precision issues. You can't just compare to an array of 1,0,0,..., because, as you well know, comparing floating point numbers for equality is "A Bad Thing".
              And sure, stick the test in #Set, and probably triple the execution time of that method and assume its not called often. And keep in mind its not actually catching all cases because of float precision...
              So then you have to look to generate the full orthonormal transform and check it's unit length etc..
              We've all been here, walk away. Really. πŸ˜„
                Except testing the transformation to be an identity transformation is faster than iterating over thousands of points applying the transformation.
                And for the usable I was looking for this in my current project the values fed to the transformation object would be true 0 - so floating point precision would not be an issue in this case.
                But I guess it's just as well to make special case for that in my code instead of the transformation code. Though still wish the API would describe the actual behaviour of #identity?
                  Dan Rathbun
                  (Headsmack!)
                  Right.
                  Well then the API's internal tolerance must be used, so for example compares like:
                  t_identity.xaxis == t_other.xaxis t_identity.xscale.to_l == t_other.xscale.to_l
                  But yes, very slow, new vector and point objects need to be created on both sides of the operator, for all x, y, z, etc. (You might save a bit of time, by using the global objects X_AXIS, Y_AXIS, etc.)
                  Not to mention the overhead of calling all those methods.
                  The API just needs updating / expanding on the C-side of things.
                  • AdamBA Offline
                    AdamB
                    I guess the docs could be updated to be:
                    returns true if it is Identity
                    returns false if its undetermined (ie, it might be)
                    Sure, if that is your bottleneck. Which it probably isn't. πŸ˜‰
                    Adam
                      It's part of it. For when the tool is being used with live preview and thousands of points are being constantly computed - every set of iteration eats some time.
                      The absolute biggest is how slow SketchUp is to add geometry. But that's not a whole lot I can do anything about.
                        Dan Rathbun
                        FYI: I DID notice that when you use clone() on an identity transform, that the new one correctly has the identity flag set true.
                          Dan Rathbun
                          How about this instead for simplicity, and to test using SketchUp's internal tolerance?
                          module WhatEver
                            ZERO = 0.0.to_l
                            UNIT = 1.0.to_l
                            IDENT = [ UNIT, ZERO, ZERO, ZERO,
                                      ZERO, UNIT, ZERO, ZERO,
                                      ZERO, ZERO, UNIT, ZERO,
                                      ZERO, ZERO, ZERO, UNIT
                              t.to_a.map{|m|m.to_l} == IDENT
                          end # module WhatEver
                            Dan Rathbun
                            Which also leads to the conclusion that the Geom::Transformation class needs a properly overriden comparison methods <=>(), ==(), and eql?() ...
                            πŸ’­
