    What defines an identity transformation?
    17 Posts 3 Posters 1.0k Views 3 Watching
      But surely, the flag could be set in the #new method in all of these cases?
      The flag doesn't have to be computed on every call, just when the matrix' values has been changed - and that's set in #new and #set! . Right?
        And it's certainly something that would be helpful if the documentation mentioned.
        • Dan RathbunD
          Dan Rathbun
          ALSO ...
          t3 = Geom::Transformation.axes( Geom::Point3d.new(0, 0, 0), Geom::Vector3d.new(1,0,0), Geom::Vector3d.new(0,1,0), Geom::Vector3d.new(0,0,1)) %(#008000)[>> #<Geom::Transformation:0x753fe38>] t3.identity? %(#008000)[>> false]
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            ALSO ...
            t4 = Geom::Transformation.scaling( 1.0 ) %(#008000)[>> #<Geom::Transformation:0x7621cc0>] t4.identity? %(#008000)[>> false] t4.to_a %(#008000)[>> [1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 1.0]]
            • Dan RathbunD
              Dan Rathbun
              I would consider this an API bug, myself.
              Workaround 1:
                def indentity_transform?(t)
                  t.to_a == [ 1.0, 0.0, 0.0, 0.0,
                              0.0, 1.0, 0.0, 0.0,
                              0.0, 0.0, 1.0, 0.0,
                              0.0, 0.0, 0.0, 1.0 ]
              Workaround 2, a mixin module:
              module Mixin; end
              module Mixin;;Identity
                def indentity?()
                  self.to_a == [ 1.0, 0.0, 0.0, 0.0,
                                 0.0, 1.0, 0.0, 0.0,
                                 0.0, 0.0, 1.0, 0.0,
              end # Mixin module
              Use mixin to change only individual transforms thus:
              require("Mixin/indentity.rb")
              # .. later
              tran = Geom;;Transformation.scaling( 1.0 )
              tran.extend(Mixin;;Idenitity)
              if tran.identity?
                # do something
              else
                # do something else
                If you want the optimisation you do the check in #new and #set!
                • AdamBA
                  AdamB
                  But if you apply an Identity, it is, by definition, a transform that changes nothing, so no harm done.
                  The method may not cover all cases, but its not really wrong either.
                  The problem, Dan & Thomthom, is floating point precision issues. You can't just compare to an array of 1,0,0,..., because, as you well know, comparing floating point numbers for equality is "A Bad Thing".
                  And sure, stick the test in #Set, and probably triple the execution time of that method and assume its not called often. And keep in mind its not actually catching all cases because of float precision...
                  So then you have to look to generate the full orthonormal transform and check it's unit length etc..
                  We've all been here, walk away. Really. πŸ˜„
                    Except testing the transformation to be an identity transformation is faster than iterating over thousands of points applying the transformation.
                    And for the usable I was looking for this in my current project the values fed to the transformation object would be true 0 - so floating point precision would not be an issue in this case.
                    But I guess it's just as well to make special case for that in my code instead of the transformation code. Though still wish the API would describe the actual behaviour of #identity?
                    • Dan RathbunD
                      Dan Rathbun
                      (Headsmack!)
                      Right.
                      Well then the API's internal tolerance must be used, so for example compares like:
                      t_identity.xaxis == t_other.xaxis t_identity.xscale.to_l == t_other.xscale.to_l
                      But yes, very slow, new vector and point objects need to be created on both sides of the operator, for all x, y, z, etc. (You might save a bit of time, by using the global objects X_AXIS, Y_AXIS, etc.)
                      Not to mention the overhead of calling all those methods.
                      The API just needs updating / expanding on the C-side of things.
                      • AdamBA
                        AdamB
                        I guess the docs could be updated to be:
                        returns true if it is Identity
                        returns false if its undetermined (ie, it might be)
                        Sure, if that is your bottleneck. Which it probably isn't. πŸ˜‰
                        Adam
                          It's part of it. For when the tool is being used with live preview and thousands of points are being constantly computed - every set of iteration eats some time.
                          The absolute biggest is how slow SketchUp is to add geometry. But that's not a whole lot I can do anything about.
                          • Dan RathbunD
                            Dan Rathbun
                            FYI: I DID notice that when you use clone() on an identity transform, that the new one correctly has the identity flag set true.
                            • Dan RathbunD
                              Dan Rathbun
                              How about this instead for simplicity, and to test using SketchUp's internal tolerance?
                              module WhatEver
                                ZERO = 0.0.to_l
                                UNIT = 1.0.to_l
                                IDENT = [ UNIT, ZERO, ZERO, ZERO,
                                          ZERO, UNIT, ZERO, ZERO,
                                          ZERO, ZERO, UNIT, ZERO,
                                          ZERO, ZERO, ZERO, UNIT
                                  t.to_a.map{|m|m.to_l} == IDENT
                              end # module WhatEver
                              • Dan RathbunD
                                Dan Rathbun
                                Which also leads to the conclusion that the Geom::Transformation class needs a properly overriden comparison methods <=>(), ==(), and eql?() ...
                                πŸ’­
