    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 293.8k Views 41 Watching
      troypiggo
      This plugin looks exactly like something I'm after. I downloaded the 1.6 version from post #1 in this thread, but it only seems to have a very simple crosshatch available and the dialog isn't as well developed as some screenshots I'm seeing in some followup posts. I skimmed through the pages, but did I miss where an updated version with those concrete hatches etc is available?
      This is not my signature. I type it at the end of every message for quality control.
      • jolranJ Offline
        jolran
        Hi! Sorry for late reply.
        At the moment there is only crosshatching with edges. ver 1.6.
        The pictures you have seen is probably screen-grabs from developpment.
        I just want to assure you I have not abandoned the project. In the future those features will be available, if all goes well.
        Thanks.
        • E Offline
          emartingr
          Thanks.
          Hello jolran,
          Great plugin, just what I was looking for. Only one question: Can the menu keep the last input values? (angle, spacing). This would be useful when there are several surfaces to be identically hatched.
          For the rest I found no bugs. Surfaces with complex geometries, with holes, spirals Etc, hatched fine. Thanks a lot.
          • jolranJ Offline
            jolran
            Hi Emartingr.
            Can the menu keep the last input values? I'm afraid I can't tell you at the moment 😳
            (This is a bit embarrassing)I have not done any coding since May and now I feel lost in the world of Ruby, so I'm rehearsing a bit at the moment.
            Did not expect to forget a language so fast πŸ˜†
            rookie mistake..
            Hopefully be back soon. Haven't given up the idea with an update with better dialogs and stuff. Unless someone else has done a similar plugin since I've been gone.
            • jolranJ Offline
              jolran
              In Version 1.7 http://sketchucation.com/forums/viewtopic.php?f=323&t=38637
              The menu should remember the values during sessions. Although not crosshatching. Crosshatching is calculated as a negative from value 1(Angle).
              If it seams like a must by request, Remebering 2nd values can of course be done, but I don't think it would be practical.
              I'm working on the next version with patterns, still lot's to do πŸ˜„
              I'm doing a comeback in coding, been off for a while..
              Hope this version will work OK for ya!
                sergey2402
                It's great. Thank you so much, Jolran!
                • jolranJ Offline
                  jolran
                  πŸ˜„
                  Thanks, more coming soon.
                  • jolranJ Offline
                    jolran
                    404 Not Found
                    (sketchucation.com)
                    New version added. Please read the help-file in the draw menu(if it's possible πŸ˜„ )
                    It would be nice with feedback if it works on Mac.
                    Some new stuff, but all is in the helpfile. Might do a tutorial later on, just for fun.
                    /Joel
                    • jolranJ Offline
                      jolran
                      Yeiks!! Crosshatching is not working! Will fix that as soon as possible.
                      edit: Actually it works. But be aware that (until fixed) if you have a negative value in 1st "angle" with crosshatching the crosshatching default value will be negative as well.
                      So just erase the "-" sign in crosshacthing dialog.
                      Also some geometry is created if cancelling in the crosshatching-menu.
                      edited again πŸ˜„ Fixed for next version. Will be added in ver 1.9.
                      Funny thing, been testing a lot but did miss this obvious thing.
                      Sorry about that.
                        photon2
                        testing v1.8 on osx 10.8. I'm an osx newb. install went fine (maybe if you named the file .rbz a person could use the in-app installer?)
                        Error 404 (Not Found)!!1
                        (support.google.com)
                        It seems to work great! I really think this project deserves to continue! :stamps foot: I was just looking for insulation pattern tool like yesterday. But I like parallel lines too! It's great you have done some research for the other patterns. Any additional vector tricks instead of images are wonderful. I will use the crosshatch feature too.
                        • jolranJ Offline
                          jolran
                          I'll take a look at it for the next version.
                          I'm working on it, mate! I updated the plugin a month ago.
                          Anyway..
                          I've ironed out the tiling parts and intersections for Hatchfaces patterns.
                          But for the moment I'm deep into Javascript.
                          Went for a "Component window" look and feel. What do ya think?
                          It will recognize new folders, and new components. So you can just create new folders and save the components(in the pluginfolder) and the thumbnails will be updated.
                          (I'm looking forward bugtracking that part πŸ˜’ )
                          It looks like a simple dialog, but there are actually quite a lot of events going on. I'm using some sprites for icons, so we will see how it will work on MAC.
                          Need to do some adjustements to the css and stuff but nearly there with the dialog..
                          After that, port the dialog to Hatchfaces and do some more Ruby adjustments and then maybe after that there can be a new betatest.
                          teaser...
                            photon2
                            That looks amazing. I think component window is pretty similar on Mac.
                            My main concern was just to keep some support, not necessarily new features, but that looks very cool.
                            By the way, if one uses the plugin as a drawing tool, to create a grid for example, is there any way to use that component separate from the face it was created on? I find that deleting the original face does work. Is that allowed? Is there some other way to unglue? If I'm understanding what's happening correctly. Thanks!
                            • jolranJ Offline
                              jolran
                              Hi.
                              If you choose "None" for the background-color the component will not glue, cause it has no faces.
                              If for some reason you want to unglue the component(when you have background) you can always right click and perform "unglue". That way the component will release the face.
                              Well hopefully, knock on wood, there will be plenty of new stuff for the next release.
                              BTW, since youre on MAC, and I'm really curious to know if the icons in the help files are showing up correctly? And the webdialog is working ok. I have no way of testing for Mac. 😞
                              In case you missed, help files are in the draw menu -> Hatchfaces -> Help.
                                photon2
                                I did see the help files and they are helpful. There are 3 icons at the bottom but I had no idea you could click on them until you said to check the icons...Maybe put them at the top and/or make a note or sign to click on them for more?
                                I don't know if I can PM yet but I can always test or send screenshots.
                                • jolranJ Offline
                                  jolran
                                  Hah! Yes your right! Just had a look. It's not that obvious they are clickable.
                                  I will update this topics 1st page and make a note about that.
                                  No need for screenshots. If the dialog looks fine to you, and is behaving like normal webpage all is probably good. It's good if the icons appear as they should...
                                  Anyway I'm considering a PDF for the next version. We will see..
                                  Thanks for the feedback.
                                    rv1974
                                    Thank you for your efforts, it's a nice tool indeed.
                                    Could you please refine this tool by adding:
                                    1. hatch origin point option
                                    2. multiple faces hatching
                                    3. memorizing the previously inserted parameters
                                    4. could additional 2nd window (for crosshatching) be merged with the first one?
                                    • jolranJ Offline
                                      jolran
                                      Hi rv1974! Thanks for your suggestions.
                                      1. Could you explain a little more, please? I have a feeling I know what you mean, but just to be sure.
                                      2. It is on the todolist. But remember that gluebehavior must be calculated as well. So it might not be as easy as it seams. Alignment might be difficult if components are side by side. Because code will probably have to perform 1 hatch at a time.
                                        There is also an issue regarding performance too. When doing linehatching this wont be much of a concern, but when having complex patterns intersecting will take longer time to calculate. If you then have many faces to perform, SU might freeze.
                                        BUT! Most things can be solved, they just have to be worth it and practical.
                                      3)That should already be working?? I have the second inputdialog set up to always return negative value of 1st parameters. It's more practical like that than just remember values from last performed hatch? I can change that if desired...But I would need more than 1 vote before changing anything unless it's an obvious thing.
                                      4)Well. I don't know if you noticed, but I'm working on webdialog for next version, so..
                                      There will be only 1 dialog. πŸ˜„
                                      404 Not Found
                                      (sketchucation.com)
                                      • HeliosLabsH Offline
                                        HeliosLabs
                                        This plugin made my day -- no more struggling with hatch materials -- especially when exporting to CAD or vector programs. It also comes out much clearer in jpg exports. Can't wait to try it out on my next floor plan.
                                          rv1974
                                          404 Not Found
                                          (sketchucation.com)
                                          1. Say we have double hatching. It'd be great to precisely point the location of the vertical and horizontal hatching lines crossing (for example, by preselecting the face(s ) and construction point. It was implemented in the TIG's extrusion tools)
                                            N.B. It'd be fantastic to (by default) get the resulted hatching aligned to the current UCS, including origin point. Simply and user friendly!
                                            And the most important: thank you replying and sharing!
                                          • jolranJ Offline
                                            jolran
                                            HeliosLabs, thanks πŸ˜„
                                            UCS(user-coordinate-system) will in this case be the face bounds, right?
                                            The Origin for hatches currently is center of face bounds.
                                            What I have already on the "TODO list" is to be able to translate Origin(center) by different methods.
                                            Perhaps by edge selection(point is edge start or end) or automatic with distance user-input from dialog. Under investigation..
                                            Are you still talking about Origin or spacing between lines?
                                            Anyway, when there will be component-patterns available, one could create taylormade linepatterns to fit the needs. Scaling could have an undesirable effect though..
                                            I will still have a look at TIG's tools. Although, I do not plan to turn this plugin into a tool with pickpoints.
                                            Thank YOU for feedback and suggestions πŸ‘
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 16 / 18
