    ENV['COMPUTERNAME'] for Mac?
    16 Posts 5 Posters 2.3k Views 5 Watching
    • H Offline
      honkinberry
      I'm not so concerned if a user has set the ENV variable to a bogus value in an attempt to circumvent our licensing system. I was hoping for just a 95% solution.
      (Key point, why would someone hack a license system for free software???)
      So I just want to query the machine name on a Mac, secure or not.
      If there's a way to do that with SSH, if you could point in the right direction, I'll find out.
      • Dan RathbunD Offline
        Dan Rathbun
        Your OP said nothing about it being free.
        I would counter, why would you want to complicate free software with a license management system ?
        Why would users want the hassle ?
        I'm not here much anymore.
          Aerilius
          So why don't you query it simply with uname -n``? No ssh needed (?).
            driven
            from Ruby Console
            `ioreg -rd1 -c IOPlatformExpertDevice | awk '/IOPlatformUUID/ { printf; }' `
            returns
            "IOPlatformUUID" = "00000000-0000-1000-8000-001E••••••••"
            I believe this is reasonably robust and unique...
            the ••••• are just me masking mine.
            edit to add from the man page...
            DESCRIPTION
            ioreg displays the I/O Kit registry. It shows the heirarchical registry
            structure as an inverted tree. The provider-client relationships among
            those objects is shown as follows:
             +-o provider
               +-o client
             By default, object properties are not shown.  The use of the -c, -k, -l,
             or -n options cause ioreg to show properties for objects that match the
             specified criteria.
              Jim
              @honkinberry said:
              There is indeed an etc/hostname file, and that's what I want -- how to read that from SU Ruby?
              --J
              Just read it.
              hostname = File.read('/etc/hostname').strip
                driven
                @jim said:
                Does Mac have an /etc/hostname file?
                only if someone/or some code has added it already...
                Error: #<Errno::ENOENT: (eval):2:inread': No such file or directory - /etc/hostname>`
                in /etc/ I have
                hostconfig
                hosts
                hosts.equiv
                but none contain any 'unique-ness' identifiers.
                • H Offline
                  honkinberry
                  driven is correct, no such filename.
                  I was incorrect, I did a "cd /etc" and then typed "hostname", like an idiot. Sorry.
                  the ioreg is interesting, but when I try that from Ruby console I get undefined local variable or method.
                  I appreciate everybody's help.
                  To emphasize, I was looking for something quick and easy, along the lines of the ENV vars.
                  If SU doesn't have that on the Mac side, I can add a config.rb faster than any other solution.
                  It sure would be nice to have, hint hint!!!
                  --J
                    driven
                    try without the awk filtering
                    theLot=(`ioreg -rd1 -c IOPlatformExpertDevice 2>&1` )
                    should give a proper error if not the return...
                    then sort from the return what you want...
                    { "compatible" = <"iMac7,1"> "version" = <"1.0"> "board-id" = <"Mac-F42386C8"> "IOInterruptSpecifiers" = (*********************long number hidden by me*************************) "IOPolledInterface" = "SMCPolledInterface is not serializable" "serial-number" = <*********************long number hidden by me*************************> "IOInterruptControllers" = ("io-apic-0") "IOPlatformUUID" = "*********************long number hidden by me*************************" "IOPlatformArgs" = <*********************long number hidden by me*************************> "clock-frequency" = <0008af2f> "manufacturer" = <"Apple Inc."> "IOConsoleSecurityInterest" = "IOCommand is not serializable" "IOPlatformSerialNumber" = "W8****ditto****T" "system-type" = <01> "product-name" = <"iMac7,1"> "model" = <"iMac7,1"> "name" = <"/"> "IOBusyInterest" = "IOCommand is not serializable" }
                    remember, not all macs have a serial number
                      Jim
                      You can use that then.
                      hostname =hostname.stip
                      (Works on win 8, but not sure how far back in terms of windows versions the command exists.)
                      I just assumed unique-ness was not an issue otherwise it would have been part of the original request.
                      host names and computer names are definitely not unique.
                      • H Offline
                        honkinberry
                        Oh, both of these last pasts, bammo, thank you guys!!!!
                        the ioreg is interesting for sure -- the board-id seems valuable for my purposes.
                        But Jim is correct!
                        hostname does indeed work.
                        So for me at least, it's as easy as:
                        machinename = ENV['COMPUTERNAME']
                        if (!machinename) then machinename = hostname # must be a Mac
                        Thanks all!!!
                          driven
                          @honkinberry said:
                          Jim is correct!
                          but that returns the same on all 5 macs on my network, so for a Licence management usage it seems a bit pointless?
                          If you only need to know if it's a mac or not there are many simple ways to get that...
                          glad your happy
