    ENV['COMPUTERNAME'] for Mac?
    16 Posts 5 Posters 2.1k Views 5 Watching
    • H Offline
      honkinberry
      Hi all,
      long-time fan, first time posting.
      I was hoping to access ENV['COMPUTERNAME'] to use with our License management system.
      But it seems that value is only available on the PC side. Is there a way to get this on the Mac side?
      Thanks for any assistance!
      --J
        Jim
        Does Mac have an /etc/hostname file?
          Aerilius
          You can't rely on the existence of environment variables (they are not cross-platform like the SketchUp API and even differ between operating system versions). Take them rather as "hints".
          Did you already look through all results of this?
          ENV.each{|k,v| puts " #{k}: #{v}" }; nil
          In case it's not in ENV, I guess OS X has an app for that: uname -n``
          (Just a guess, I don't use that.)
          • H Offline
            honkinberry
            There is indeed an etc/hostname file, and that's what I want -- how to read that from SU Ruby?
            And as for iterating ENV, isn't it a bit quicker to just type ENV ? That seems to work. πŸ˜‰
            --J
            • Dan RathbunD Offline
              Dan Rathbun
              Problem is that setting a bogus environment variable, or setting a valid variable to a bogus temporary setting, is quite easy; .. both with a shell script, and from within Ruby.
              I would suggest looking into some sort of encrypted key.. what about SSH ?
              I'm not here much anymore.
              • H Offline
                honkinberry
                I'm not so concerned if a user has set the ENV variable to a bogus value in an attempt to circumvent our licensing system. I was hoping for just a 95% solution.
                (Key point, why would someone hack a license system for free software???)
                So I just want to query the machine name on a Mac, secure or not.
                If there's a way to do that with SSH, if you could point in the right direction, I'll find out.
                  Dan Rathbun
                  Your OP said nothing about it being free.
                  I would counter, why would you want to complicate free software with a license management system ?
                  Why would users want the hassle ?
                    Aerilius
                    So why don't you query it simply with uname -n``? No ssh needed (?).
                      driven
                      from Ruby Console
                      `ioreg -rd1 -c IOPlatformExpertDevice | awk '/IOPlatformUUID/ { printf; }' `
                      returns
                      "IOPlatformUUID" = "00000000-0000-1000-8000-001Eβ€’β€’β€’β€’β€’β€’β€’β€’"
                      I believe this is reasonably robust and unique...
                      the β€’β€’β€’β€’β€’ are just me masking mine.
                      edit to add from the man page...
                      DESCRIPTION
                      ioreg displays the I/O Kit registry. It shows the heirarchical registry
                      structure as an inverted tree. The provider-client relationships among
                      those objects is shown as follows:
                       +-o provider
                         +-o client
                       By default, object properties are not shown.  The use of the -c, -k, -l,
                       or -n options cause ioreg to show properties for objects that match the
                       specified criteria.
                        Jim
                        --J
                        Just read it.
                        hostname = File.read('/etc/hostname').strip
                          driven
                          only if someone/or some code has added it already...
                          Error: #<Errno::ENOENT: (eval):2:inread': No such file or directory - /etc/hostname>`
                          in /etc/ I have
                          hostconfig
                          hosts
                          hosts.equiv
                          but none contain any 'unique-ness' identifiers.
                          • H Offline
                            honkinberry
                            driven is correct, no such filename.
                            I was incorrect, I did a "cd /etc" and then typed "hostname", like an idiot. Sorry.
                            the ioreg is interesting, but when I try that from Ruby console I get undefined local variable or method.
                            I appreciate everybody's help.
                            To emphasize, I was looking for something quick and easy, along the lines of the ENV vars.
                            If SU doesn't have that on the Mac side, I can add a config.rb faster than any other solution.
                            It sure would be nice to have, hint hint!!!
                            --J
                              driven
                              try without the awk filtering
                              theLot=(`ioreg -rd1 -c IOPlatformExpertDevice 2>&1` )
                              should give a proper error if not the return...
                              then sort from the return what you want...
                              { "compatible" = <"iMac7,1"> "version" = <"1.0"> "board-id" = <"Mac-F42386C8"> "IOInterruptSpecifiers" = (*********************long number hidden by me*************************) "IOPolledInterface" = "SMCPolledInterface is not serializable" "serial-number" = <*********************long number hidden by me*************************> "IOInterruptControllers" = ("io-apic-0") "IOPlatformUUID" = "*********************long number hidden by me*************************" "IOPlatformArgs" = <*********************long number hidden by me*************************> "clock-frequency" = <0008af2f> "manufacturer" = <"Apple Inc."> "IOConsoleSecurityInterest" = "IOCommand is not serializable" "IOPlatformSerialNumber" = "W8****ditto****T" "system-type" = <01> "product-name" = <"iMac7,1"> "model" = <"iMac7,1"> "name" = <"/"> "IOBusyInterest" = "IOCommand is not serializable" }
                              remember, not all macs have a serial number
                                Jim
                                You can use that then.
                                hostname =hostname.stip
                                (Works on win 8, but not sure how far back in terms of windows versions the command exists.)
                                I just assumed unique-ness was not an issue otherwise it would have been part of the original request.
                                host names and computer names are definitely not unique.
                                • H Offline
                                  honkinberry
                                  Oh, both of these last pasts, bammo, thank you guys!!!!
                                  the ioreg is interesting for sure -- the board-id seems valuable for my purposes.
                                  But Jim is correct!
                                  hostname does indeed work.
                                  So for me at least, it's as easy as:
                                  machinename = ENV['COMPUTERNAME']
                                  if (!machinename) then machinename = hostname # must be a Mac
                                  Thanks all!!!
                                    driven
                                    @honkinberry said:
                                    Jim is correct!
                                    but that returns the same on all 5 macs on my network, so for a Licence management usage it seems a bit pointless?
                                    If you only need to know if it's a mac or not there are many simple ways to get that...
                                    glad your happy
