    ENV['COMPUTERNAME'] for Mac?
    16 Posts 5 Posters 2.7k Views 5 Watching
    • Dan RathbunD
      Dan Rathbun
      @honkinberry said:
      And as for iterating ENV, isn't it a bit quicker to just type ENV ? That seems to work.
      Problem is that setting a bogus environment variable, or setting a valid variable to a bogus temporary setting, is quite easy; .. both with a shell script, and from within Ruby.
      I would suggest looking into some sort of encrypted key.. what about SSH ?
      I'm not here much anymore.
      • H
        honkinberry
        I'm not so concerned if a user has set the ENV variable to a bogus value in an attempt to circumvent our licensing system. I was hoping for just a 95% solution.
        (Key point, why would someone hack a license system for free software???)
        So I just want to query the machine name on a Mac, secure or not.
        If there's a way to do that with SSH, if you could point in the right direction, I'll find out.
        • Dan RathbunD
          Dan Rathbun
          Your OP said nothing about it being free.
          I would counter, why would you want to complicate free software with a license management system ?
          Why would users want the hassle ?
            Aerilius
            So why don't you query it simply with uname -n``? No ssh needed (?).
              driven
              from Ruby Console
              `ioreg -rd1 -c IOPlatformExpertDevice | awk '/IOPlatformUUID/ { printf; }' `
              returns
              "IOPlatformUUID" = "00000000-0000-1000-8000-001E••••••••"
              I believe this is reasonably robust and unique...
              the ••••• are just me masking mine.
              edit to add from the man page...
              DESCRIPTION
              ioreg displays the I/O Kit registry. It shows the heirarchical registry
              structure as an inverted tree. The provider-client relationships among
              those objects is shown as follows:
               +-o provider
                 +-o client
               By default, object properties are not shown.  The use of the -c, -k, -l,
               or -n options cause ioreg to show properties for objects that match the
               specified criteria.
                Jim
                @honkinberry said:
                There is indeed an etc/hostname file, and that's what I want -- how to read that from SU Ruby?
                --J
                Just read it.
                hostname = File.read('/etc/hostname').strip
                  driven
                  @jim said:
                  Does Mac have an /etc/hostname file?
                  only if someone/or some code has added it already...
                  Error: #<Errno::ENOENT: (eval):2:inread': No such file or directory - /etc/hostname>`
                  in /etc/ I have
                  hostconfig
                  hosts
                  hosts.equiv
                  but none contain any 'unique-ness' identifiers.
                  • H
                    honkinberry
                    driven is correct, no such filename.
                    I was incorrect, I did a "cd /etc" and then typed "hostname", like an idiot. Sorry.
                    the ioreg is interesting, but when I try that from Ruby console I get undefined local variable or method.
                    I appreciate everybody's help.
                    To emphasize, I was looking for something quick and easy, along the lines of the ENV vars.
                    If SU doesn't have that on the Mac side, I can add a config.rb faster than any other solution.
                    It sure would be nice to have, hint hint!!!
                    --J
                      driven
                      try without the awk filtering
                      theLot=(`ioreg -rd1 -c IOPlatformExpertDevice 2>&1` )
                      should give a proper error if not the return...
                      then sort from the return what you want...
                      { "compatible" = <"iMac7,1"> "version" = <"1.0"> "board-id" = <"Mac-F42386C8"> "IOInterruptSpecifiers" = (*********************long number hidden by me*************************) "IOPolledInterface" = "SMCPolledInterface is not serializable" "serial-number" = <*********************long number hidden by me*************************> "IOInterruptControllers" = ("io-apic-0") "IOPlatformUUID" = "*********************long number hidden by me*************************" "IOPlatformArgs" = <*********************long number hidden by me*************************> "clock-frequency" = <0008af2f> "manufacturer" = <"Apple Inc."> "IOConsoleSecurityInterest" = "IOCommand is not serializable" "IOPlatformSerialNumber" = "W8****ditto****T" "system-type" = <01> "product-name" = <"iMac7,1"> "model" = <"iMac7,1"> "name" = <"/"> "IOBusyInterest" = "IOCommand is not serializable" }
                      remember, not all macs have a serial number
                        Jim
                        You can use that then.
                        hostname =hostname.stip
                        (Works on win 8, but not sure how far back in terms of windows versions the command exists.)
                        I just assumed unique-ness was not an issue otherwise it would have been part of the original request.
                        host names and computer names are definitely not unique.
                        • H
                          honkinberry
                          Oh, both of these last pasts, bammo, thank you guys!!!!
                          the ioreg is interesting for sure -- the board-id seems valuable for my purposes.
                          But Jim is correct!
                          hostname does indeed work.
                          So for me at least, it's as easy as:
                          machinename = ENV['COMPUTERNAME']
                          if (!machinename) then machinename = hostname # must be a Mac
                          Thanks all!!!
                            driven
                            @honkinberry said:
                            Jim is correct!
                            but that returns the same on all 5 macs on my network, so for a Licence management usage it seems a bit pointless?
                            If you only need to know if it's a mac or not there are many simple ways to get that...
                            glad your happy
