    Landscape Job
    21 Posts 7 Posters 1.9k Views 7 Watching
    • cheddaC Offline
      chedda
      Thanks for the comments Richard the trees are from evermotion vol 61.
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • cheddaC Offline
        chedda
        Here is the polished, final version.Thanks for the feedback everyone.
        • Bryan KB Offline
          Looks great. Hope your client thinks so, as well. (they should!)
          • RichardR Offline
            Richard
            Chedda
            Mate for me the night shot needs a little more flood lighting - maybe a light panel where the camera is to simulate a flash!
            BUILTBRAND.COM.AU
            • unrealVizU Offline
              unrealViz
              Do you have a final version of the day shot?
              http://www.unrealviz.blogspot.com
              • cheddaC Offline
                chedda
                Some updated images:
                • cheddaC Offline
                  chedda
                  As always guys just when i think it's finished their are changes again, watch this space for the next episode ! Good tip Richard on simulating a flash i will try to mimic it.
                  • cheddaC Offline
                    chedda
                    This steps detail is a WIP as i try to find a solution for this difficult space, can anyone help with the layout it has me puzzled ?
                    • pbacotP Offline
                      you mean layout of the actual project? I would try to make the steps go down in both directions if you have space in the foreground. Wrap them on the corner for a more generous use of the space. Is that a door at the building? Is that why the steps are going there? Looks like one too many landings to be nice, but appears you have a level challenge--- I'd prefer to make all the steps come down to one level, perhaps it needs to then step down to the path. But I don't like single steps out in the middle of things either...
                      So have one set of steps go to the door and one set come out towards us with a planter (and that one step you have between)? Maybe that planter would relate to the planter on the left of the step. I'd put a handrail at the wall beyond and not have one in the middle of the steps if you are OK with that. Can the steps move a little towards the pool to make the landing less abrupt? It looks like that can't much
                      or are you asking something else?
                      • cheddaC Offline
                        chedda
                        That's exactly what i'm asking. This house has been renovated about 3 times in different areas, where they join is problematic. The door is one step up the pool four, there is a little space to play with at the top. It's difficult to understand your suggestion. The rail your right should be pushed back under the light. I put it here to prevent any confusion with the steps and try and make it safer.Thanks for the feedback.
                        • pbacotP Offline
                          Well, I guess one part i mean is put a planter to divide the steps instead of the rail.
                          • cheddaC Offline
                            chedda
                            Thanks for the tip pbacot.
                            • pbacotP Offline
                              You're welcome. Nice picture! I admire your rendering skills.
                              I guess I do like the direction, the various stepping forms are juxtaposed on two axes, even the hedges. The planter highlights the entrance to the pool deck. I do feel uneasy about swimsuits and cacti though. Heh!
                              Those are nice plants BTW. Did you model them?
                              Congrats!
                              • cheddaC Offline
                                chedda
                                Thanks pbacot the trees & pot plants are from evermotion. I use a proxy in the maxwell plugin.Yes Cacti means respect & caution but this is Cyprus ! Thanks for taking the time.
                                • RichardR Offline
                                  Richard
                                  NICE modification to the stairs there mate! Great recommendation Peter!!!
                                  Mate have you played at all with the shift lens? Very useful for landscaping renders!
                                  BUILTBRAND.COM.AU
                                  • cheddaC Offline
                                    chedda
                                    Cheers Richard, no i haven't ever used the shift lens feature, sometimes i use the 2 point perspective camera in sketch up though.
