    Multiple Conoid Membrane
    Scheduled Pinned Locked Moved Organic Modelling
    8 Posts 4 Posters 10.0k Views 4 Watching
    • C
      chib
      I have been trying to create a membrane from multiple closed path, one rectangle and 3 circles.
      The best results i could get was using the Skin/Bubble plugin.
      Since the Bubble/Skin Plugin only works with one closed path, the only way was to break the circles and connect to the rectangle manually, creating a closed loop.
      Is there another way to do it, without breaking the circles?
      Attached is a picture to illustrate.
      • gillesG
        gilles
        Take a look at this one.
        http://sketchucation.com/forums/viewtopic.php?f=323&t=32380#p286168
        • C
          chib
          i have tried that tool already. But you cannot use more then 2 contours at once with it.
            One by one then intersection ?
            Not sure that will be the good result πŸ˜„
              (please save in V6 πŸ˜‰
              And like this πŸ˜‰
              (show hidden geometry for easy drawing of plans for easy drawing curves in 3D Space)
              Use Projections By Didier Bur for extrude segments between volumes
              2bubbles.skp
              • panixiaP
                panixia
                membrane.jpgpilou, i would rather use this approach because i think it lead to better topology.
                i find that intersections of similar meshes in sketchup tends to cause some problem (small faces, small segments, holes, overlapping edges, not flowing loops, odd texture mapping etc..)
                membrane.skp
                • C
                  chib
                  Thanks for the suggestions, i have tried Pilou's method.
                  Though i am still not quite satisfied with the result as you still have to predefine the connecting curves between the cones.
                    Yes, it was a human method! πŸ˜„
