    New Computer
    110 Posts 11 Posters 8.1k Views 11 Watching
    • N Offline
      numerobis
      The CX500 has a single rail design with 38A combined. It is possible, that 500W and 38A will be enough, but i can't guarantee. This depends on the video card i would say.
      Like i wrote before i would take one with at least ~50A combined on the +12V rail.
      Something like this:
      http://www.dustinhome.se/product/5010586850/corsair-tx-650w-v2-natdel-atx12v-2-3-eps12v/#intcmp=searchProvider_dacsa (52A combined)
      http://www.corsair.com/en/media/cms/manual/TX-V2_manual.pdf
      The 650HX and the 500CX seem to be build by Channel Well. http://www.tomshardware.de/Netzteil-OEM-Hersteller,testberichte-240604-5.html
      I don't know this manufacturer, but from the critics on the net it should be a good one.
      or this one
      http://www.dustinhome.se/product/5010628023/seasonic-s12-ii-620w-psu/#intcmp=searchProvider_dacsa (48A combined)
      http://www.seasonic.com/pdf/datasheet/NEW/Retail/S12II%20Bronze.pdf
      I don't know how silent the corsair fan is, i have only saesonic PSUs. But i think it should be ok.
      But the fan is one more point for me to take a slightly bigger PSU. Since they are usually controlled by the workload a 600W PSU "could" (!) be more quiet at the same power level than a 500W PSU.
      But this is MY opinion and i might be wrong! I'm no PSU expert!
      I would buy 1600MHz RAM with CL10 - i don't know why they are so much more expensive in this shop. Here the difference between 1333 CL9 and 1600 CL10 is only ~5€.
      But like i wrote above...
      @numerobis said:
      • 1600MHz RAM would be only slightly better (but only maybe 2%) but should be almost in the same price range.
      @vigge50 said:
      I have change the processor to intel core i7 3770K(can't find the i7 3930)
      Dustin
      Dustin, Dustinhome
      (www.dustinhome.se)
      😲 quite expensive...
      • V Offline
        vigge50
        I found that proccesor later, was looking at 1155 sockets.
        When i look at http://www.enermax.outervision.com/index.jsp and fill in all the information i know it says that i need a PSU on 394 W. I now that you need to have some margin but i think 650W is littel overkill.
        I found a 16 gig ram for 589:- so i take that insted, not any big different.
          As Numerobis said, you need to take the video card into account, too. Some mid-to-high range cards can be rather power demanding.
          • V Offline
            vigge50
            I now that some graphic card need much power but as i say, i don't going to buy any graphic card, the intel hd graphic 4000 that is in the intel core i7 proseccor is enough for me.
              All right, sorry, I must have overlooked that. Note however that without a dedicated video card, SU may be sluggish (although I have heard of some later integrated chipsets that they can run at least without issues even if not at full power).
              • N Offline
                numerobis
                I don't know if you are actually reading what i am typing here... but i will try it again.
                1. wattage is not everything - you need enough ampere
                2. efficiency is normally best at 50-60% load
                3. noise
                And i think you should get a video card if you want to use that machine for modeling and graphic stuff...
                You can compare the performance of the HD4000 embeded graphics only with the lowest end video cards on the market, and even then it is slower:
                http://www.techpowerup.com/reviews/Intel/Core_i7_3770K_Ivy_Bridge_GPU/23.html
                and now look how the GT430, GT440 or HD6670 perform compared to a good midrange card like the GTX560TI:
                http://www.tomshardware.com/charts/2012-vga-gpgpu/19-Tom-s-Hardware-Index-B-Performance,2976.html
                not really comparable...
                But you can try it and plug in a card later.
                  @numerobis said:
                  ...But you can try it and plug in a card later.
                  Indeed - and to do so, you may want to prepare with the PSU already enough to support it (so that you need not change that as well later).
                  I would really not start saving on that piece.
                  • V Offline
                    vigge50
                    Okey, after your tip I have change it to this:
                    ASRock Z77 PRO3 Intel Z77 4xDDR3 CrossFireX Socket 1155 ATX 825:-
                    Intel 330 Series 180GB SSD R:500/W:450 2.5" SATA-3 989:-
                    Microsoft Windows 7 Home Premium 64-bit OEM Swedish SP1 819:-
                    SEASONIC S12 II 620W PSU 890:-
                    GIGABYTE GEFORCE GT 430 2GB PCI-E VGA/DVI/HDMI 566:-
                    INTEL CORE I7 3770K 3.5GHZ 8MB S-1155 IVY 2 590:-
                    COOLER MASTER MIDITOWER ELITE 310 ATX BLACK/ORANGE 290:-
                    CORSAIR 16GB DDR3 XMS3 PC12800 1600MHZ (2X8GB) 639:-
                    ASUS DRW-24B5ST DVD±R/RW/RAM DL 24X SATA BLACK RETAIL 169:-
                    Total for me with student discount 7 727:- = 880 euro
                    • N Offline
                      numerobis
                      I would say this looks good now... 😉
                      But i think you misunderstood my hint for the video card?!? I didn't mean that a GTX 430/440 would be better than the intel graphics, but that the HD4000 is almost at the same level like the worst available video cards on the market and that something like a GTX 560 (TI) would be much better...
                      But if you buy an active cooled card you should watch out for noisy fans... better read some reviews.
                      How about a CPU cooler?
                      • V Offline
                        vigge50
                        If I search around on the website there i want to buy it from, what would i look for to know if it´s good ore not if i dont want to search over google every time? Is higher number in GeForce GT(X) (number) better and what does the X stands for?
                        • N Offline
                          numerobis
                          To get a rough overview of the available cards you should maybe take a look at the linked comparison chart on tomshardware...
                          nvidia names the faster cards of a line "GTX" and the slower ones "GT". I think everything under "50" (GTX550 or GTX650) is named GT now.
                          Like i said before, i would look for a GTX 560 or GTX 560 TI. They are available with 1GB and 2GB RAM and different coolers from different brands.
                          Everything above is too energy consuming for daily sketchup work - in my opinion (and is too expensive and runs too hot).
                          The newer 6xx series seems to be not so good for professional 3D work.
                          • V Offline
                            vigge50
                            I found Asus GTX560 1GB PCI-E DC for 1 549:- but when I read reviews it often comes up what it's overpriced, if I now have to buy a graphic card to I mayby need a better PSU and then I found this at the same price as the other but it is at 650 W and it's gold certified FRACTAL DESIGN TESLA R2 650W WHITE.
                            I have found that the company that cell windows 7 for 819:- have rais it to 949:- so now I mayby take windows 8 instead.
                            Do you have any tip for another good graphic card in a little cheaper price class?
                            (I think I am up in about 8 000 kr now I think it is little too much)
                            • N Offline
                              numerobis
                              The Seasonic that i posted should be enough for one video card - even if you plug in a GTX580/680. No need for 80plus GOLD - Gold is not stronger, only a few percent more efficient (~5%) than Bronze - but much more expensive...
                              ( http://en.wikipedia.org/wiki/80_Plus )
                              I really don't know what to say about the video card... If the 560 or 560TI is too expensive for you, then buy a cheaper one!?
                              But as most of the time if you buy components - you get what you pay for! A GTX 550 or 550TI could be ok. But i would not go below a GTX 550. I think a GT440 is not worth the money - then you can better use the embedded chip...
                              The 550TI should be ~30-40% slower than a 560TI but for maybe 50% less money - i'm not sure about the 550.
                              I think 949 SEK = 110€ is still cheap or normal for Win7 Pro x64 OEM.
                              If you want it cheaper you could buy a "labled" version. These are reselled OEM Reinstallation DVDs, normally from Dell. I have already bought two of these and registered successfully - but no guaranty from my side! (But i would not buy it on ebay!)
                              I don't know if there are swedish versions...
                              http://www.amazon.de/gp/product/B005KJ9P2U/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=330045087&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B004BMPJZO&pf_rd_m=A3JWKAKR8XB7XF&pf_rd_r=1CKAY6RQ79JE7GBA9H80
                              • V Offline
                                vigge50
                                After some serach i found GTX 550 TI so now I think to buy this:
                                ASUS GEFORCE GTX 550 TI 1GB PCI-E DVI/HDMI 1040:-
                                MICROSOFT WINDOWS 7 HOME PREM SP1 64-BIT SWE DVD#OEM 901:-
                                INTEL CORE I7 3770K 3.5GHZ 8MB S-1155 IVY 2 675:-
                                CORSAIR 16GB DDR3 XMS3 PC12800 1600MHZ (2X8GB) 629:-
                                ASUS DRW-24B5ST DVD±R/RW/RAM DL 24X SATA BLACK 169:-
                                Total 8 408:-
                                Have look on different cpu cooler from Noctua and have also found Zalman CNPS12X CPU Cooler that cost just 169:- insted of 675:- but it's temporarily out of stock.
                                • N Offline
                                  numerobis
                                  Wow, 19,62€ for a CNPS12X? Really? If this is true, i think it's clear why they are out of stock...
                                  The CNPS12X seems to be really great - but normally a bit expensive
                                  http://www.xbitlabs.com/articles/coolers/display/zalman-cnps12x_5.html
                                  If you don't get one, i think the cheapest good cooler is still the Thermalright HR-02 Macho Rev. A
                                  One more thing about the Seasonic... if you would like to have removable cables there is also a M12 II 620W for a few bucks more (i've just ordered one today for my new rendernode 😉 )
                                  • V Offline
                                    vigge50
                                    Found a new website with some nice prices so now I have this:
                                    KFA2 GeForce GTX 550 Ti - grafikkort - GF GTX 550 Ti 816:-
                                    MICROSOFT WINDOWS 7 HOME PREM SP1 64-BIT SWE DVD#OEM 834:-
                                    INTEL CORE I7 3770K 3.5GHZ 8MB S-1155 IVY 2 641:-
                                    CORSAIR 16GB DDR3 XMS3 PC12800 1600MHZ (2X8GB) 562:-
                                    SEASONIC S12 II 620W PSU 748:-
                                    Samsung SH-224BB - DVD±RW- (±R DL-) / DVD-RAM-en 154:-
                                    Total 7 859:-
                                    • N Offline
                                      numerobis
                                      no cooler anymore?
                                      • V Offline
                                        vigge50
                                        The prices have get up littel and the graphic card I had choose doesn't sells anymore so now I am just over 8 000kr and look for a cooler. I have read that Noctua make the best air cooler but I don't now if I would chosse the extrem Noctua NH-D14(679:-), mayby the littel cheaper NOCTUA NH-U12P(525:-) or NOCTUA NH-U9B SE2(425:-)
                                        • N Offline
                                          numerobis
                                          The Noctua NH-D14 is nice but VERY expensive. I didn't think that this would fit your budget...
                                          @numerobis said:
                                          • a good cooler, maybe Thermalright True Spirit 120 Rev. A ~25€ (or HR-2 Macho or Macho 120)
                                          I think the Thermalright HR-02 Macho Rev. A (BW) has still the best price/performance ratio at the moment (~40€) and a very quiet fan - i have two of them in use for render nodes (overclocked i7 980x and 3930K).
                                          The True Spirit would be an even cheaper solution. Performance is a bit below the Macho - like the price.
                                          • V Offline
                                            vigge50
                                            Thank you for the tip, found out that the true spirit is really good if you look on this test
                                            http://www.xbitlabs.com/articles/coolers/display/xigmatek-prime-thermalright-true-spirit-140_7.html
                                            I found this for just 344:- and the other one that you talk about I just found on one or two websites and was mush expensiver so the spirit is enought for me. Right now I am on 8391:- = 967€
                                            • 2 / 6
