    JSON in Ruby
    48 Posts 7 Posters 7.9k Views 7 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @myhand said:
      @aerilius said:
      please take a look and make use of the WebDialogX project.
      I cannot access the content. I get "You do not have access to the wiki." message, even after I have registered.
      Sorry, it is a 5-slot private repository at this time, and we really need very experienced Rubyists for the slots.
      And you are kinda re-inventing the wheel. Js has %(#8000BF)[escape()] and %(#8000BF)[unescape()], and Ruby has them in the URI library.
      See topic: http://sketchucation.com/forums/viewtopic.php?f=180&t=49183#p442102
      In fact I would vote for Ruby's URI::Escape module to be mixed into the SketchUp API UI::WebDialog class.
      I'm not here much anymore.
        Myhand
        No problem Dan, I only looked there as Aerilius recommended I do so.
        Thank you, I will try the URI library (I already use escape() in my latest JS code). I do not really want to reinvent the wheel, hence me asking the question here.
        http://www.keepingmyhandin.com/
          Myhand
          @aerilius said:
          1. You need to escape \ characters in the double-quoted javascript code that you want to bring into the webdialog (this first escaping is what makes a valid Ruby string).
            %(#000000)["alert('C:\users')"] # bad Ruby string
            %(#000000)["alert('C:\\users')"] # good Ruby string
          2. In the webdialog, the string arrives written in a script element. As always, the same escaping rules apply again:
            %(#000000)[alert('C:\users')] // bad JavaScript code
            %(#000000)[alert('C:\\users')] // good JavaScript code
          => So finally this means we need double escaping on the Ruby side!
          %(#000000)["alert('C:\\\\users')"] # Ruby string
          Thanks for a very clear explanation. πŸ‘ I tried this last night and it worked. Need 7 '''s for a "!
            What?
              Myhand
              Thanks for this Dan! It works well, and I do not need to remember the number of slashes. πŸ˜„
              I see that escape() and unescape() are deprecated though and that you are recommended to use
              decodeURI()
              decodeURIComponent()
              Which do you recommend or should I continue with unescape()?
                Myhand
                @thomthom said:
                What?
                Sorry, meant you need
                "a JSON escaped double quote need to be specified like this \\\\\\\" in Ruby for a WebDialog call"
                to produce
                "a JSON escaped double quote need to be specified like this \" in Ruby for a WebDialog call"
                as the parameter of the JS function called.
                  Dan Rathbun
                  Hmmm..
                  given a Js function named say()
                  .. and a Ruby string:
                  jarg = %q('a JSON escaped double quote need to be specified like this %q(\") in Ruby for a WebDialog call')
                  I usually do something like this:
                  dlg.execute_script("say(#{jarg});")
                  or I will leave the single quotes out of the jarg string, and put them in at the call ...
                  jarg = %q(a JSON escaped double quote need to be specified like this %q(\") in Ruby for a WebDialog call.)
                  dlg.execute_script( "say('" << jarg << "');" )
                  πŸ’­
                    Dan Rathbun
                    [quote="Myhand":31wco2xd]I see that %(#8000BF)[escape()] and %(#8000BF)[unescape()] are deprecated (in Javascript,) though, and that you are recommending to use [them]
                    ***%(#BF4000)[
                    ](http://msdn.microsoft.com/en-us/library/dz4x90hk(v)":31wco2xd]The unescape function should not be used to decode Uniform Resource Identifiers (URI). Use decodeURI and decodeURIComponent functions instead.
                    %(#8000BF)[decodeURI()]
                    %(#8000BF)[decodeURIComponent()]
                    Which do you recommend or should I continue with %(#8000BF)[unescape()]?
                    The old functions are ASCII, the new ones are Unicode.
                    Taking a look at the most recent released ECMA-262 (but not the latest proposed revision,) the old functions are no longer listed.
                    see: ECMA-262, 5.1, Global Object: 15.1.3 URI Handling Function Properties
                    ECMAScript Language Specification
                    Standard ECMA-262
                    5.1 Edition / June 2011
                    Link to the downloadable PDF of the specification.
                    But you need to handle the situation where an older browser does not have these functions so, write a wrapper in JS:
                    var unesc = function(uri) {
                        var test = false;
                        if (typeof(decodeURI) == "function") test = true;
                        return test ? decodeURI(uri) ; unescape(uri);
                    πŸ’­
                    • 3 / 3
