    Render package options?
    38 Posts 13 Posters 2.5k Views 13 Watching
    • StinkieS Offline
      Stinkie
      Pete, looks good. Bsd?
      • soloS Offline
        TR1 (unbiased), I tested BSD and it rendered in 2 min 46
        • StinkieS Offline
          Stinkie
          Not bad, not bad at all. I assume you downsampled the image?
          • soloS Offline
            I set supersampling on 'normal', I did a quick video of the interactive BSD engine.
            Let me upload it to someplace and post in this reply when done.
            Here it is, It's in this wide format as I recorded over two monitors (both 27 inches)
            So take into account I am rendering at a huge ratio of 1870x850 (my SU ratio)
            Dropbox - 404
            (dl.dropbox.com)
            • StinkieS Offline
              Stinkie
              Cool vid. Thanks for that.
              My assumption was you made your image smaller in post, thus compressing the noise.
                jpalm32
                Twilight will give great results at very reasonable price. Learning curve can be applied to Thea!
                • soloS Offline
                  Absolutely, Twilight is another great option.
                  The new Thea4SU is very simple to use by the way.
                  • StinkieS Offline
                    Stinkie
                    @solo said:
                    Ah, yes. Forgot about that one. Good choice for a beginner. Easy to use, cheap, nice forum. And there's a tutorial on Lynda.com.
                      toynlet
                      Thankyou to everyone for their input!
                      Even more research for me and hopefully an opportunity to use some of these packages.
                      Steve
                      • jo-keJ Offline
                        jo-ke
                        @solo said:
                        all within SU (not studio) no post processing.
                        Is there now a thea- SU integrated- version (comparable to twilight) without export like Kerkythea?
                        Sounds interessting!
                        http://www.zz7.de
                        • soloS Offline
                          Yup,it's amazing, not yet available as it's still in beta, hopefully some time this month.
                          • jo-keJ Offline
                            jo-ke
                            Wow!
                            This are really good news!
                            Can't wait to try it...
                            http://www.zz7.de
                              kilgo
                              Here's one from Podium.
                              Podium Default Settings
                                kilgo
                                another one...You can see by the render info (bottom of image) adding the trees extended its time from 4min to 20 min.
                                with some trees and a few (post render) color adjustments
                                • majidM Offline
                                  majid
                                  I gave a try using KT, + KT free trees, instancing them around the model.
                                  background fit image + distance blue light ( to simulate blues shadows)
                                  that is all
                                  4 min 37 sec!
                                  • 2 / 2
