    Advent Candle Stand or Floor Lamp
    11 Posts 4 Posters 2.5k Views 4 Watching
      My wife asked me to come up with a design for an Advent candle stand so I doodled up this.
      It's based on a table lamp I built a few years ago. I figured if I wind up building it, I'll make two and make the other one a floor lamp. the only difference is the length of the cross arms at the top.
      The tapered vertical pieces are cut with a dovetail cutter so they fit together leaving a space up the center for a power cord. It's a little fiddly to get the cutter set exactly right but once it is, the pieces are easily cut--they're identical--and easy to assemble.
      • pbacotP
        Nice, Dave. Might you want more of a drip catcher on the arms? We used to have the candles on the table, with a wreath. This was one of my favorite traditions as a child. Thinking back it seems it must been picked up from the Menorah tradition.
          Thank you. I think the candles will be oil-filled so they shouldn't drip. If they aren't going to use oil-filled candles I'll probably make some drip catchers out of brass.
            davidheim1
            Dave,
            Nice looking piece, but your method for joining the vertical pieces has me puzzled. How about adding another view to show the joinery?
            Best,
            dh
              Hi David,
              Thank you.
              I don't have the model at my disposal at the moment so I made a quick sketch showing the joint.
              You cut this with a dovetail cutter in the router table. Each piece gets a pass with the edge of the board against the fence and then with a face. all four pieces are identical. When I made the table lamp I spent quite a bit of time making test cuts. With SketchUp, it's dead easy by using copies of a component arrayed around the center.
                davidheim1
                Very clever, as always.
                dh
                  I wish it was my idea. It is pretty cool. Much like the birdsmouth method used to make hollow masts and spars for sailboats.
                    Here's the floor lamp with a mica shade. I added a couple of Morris chairs and Gregory Paolini's Limbert-style coffee table for scale.
                      mwm5053
                      Very nice Dave. I've always like the Arts and Craft furniture.
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                        Thank you, Walt. Now I just have to get the mica and get moving on it. If I'm going to make one I might as well do two and the shades should come first.
                          FWIW, I've simplified it to use simple rabbets for joining the vertical pieces. It should be less fussy to cut those joints.
