    Properly Curve mapping need help!!!
    8 Posts 4 Posters 298 Views 4 Watching
    • I Offline
      iNikiii
      I'm creating a modell for a videogame and I need to texture map properly around curves.
      Here's a pic.
      -top shows you my problem
      -bottom shows you the texture properly (set by rightclick-> texture position and moved it)
      http://i50.tinypic.com/3313tll.png
      and here's the texture itself:
      http://i46.tinypic.com/1tmxxj.png
      Thanks in advance!
      • cottyC Offline
        cotty
        If you are able to change your geometry to quads, you can use the UV mapping tool from ThomThoms QuadFaceTools...
        my SketchUp gallery
        • I Offline
          iNikiii
          Can you exactly show me how you did this?
          I tried like thom did in his videos, but it didn't really worked. (couldn't see everything tho πŸ˜• and no voice in the vid)
          • I Offline
            iNikiii
            It's not really working for me, could you make a video of specially a road?
            By the way: my road isn't flat it's has like little hills for better effect.(and not looking so boring)
            • pbacotP Offline
              Try projecting as in this video. You can use the surface you already have positioned as the source. Set texture on that one face to be projected then sample and apply to the other surfaces with hidden geometry OFF.
              http://www.youtube.com/watch?v=fcIMTJ99mZc
              • pbacotP Offline
                Would work for the example shown, but I seemed to have ignored the word "curved" 😳
                • sdmitchS Offline
                  sdmitch
                  Positioning the texture on individual faces to give a continueous appearence is not the problem. Bending the texture around curves is the problem.
                  http://sdmitch.blogspot.com/
                  • cottyC Offline
                    cotty
                    The UV mapping is described in this video from Thomthom, so no need to reproduce it...
                    [flash:mueajh11]http://www.youtube.com/v/HdX517AryWs[/flash:mueajh11]
                    my SketchUp gallery
