    Allow to start a plugin just once
    4 Posts 3 Posters 232 Views 3 Watching
    • N
      niccah
      I'm wondering, that I can't find a nice solution, to allow to start a plugin just once.
      So, with the help of my plugin, I start a WebDialog... How I can ask, if there is the same WebDialog already opened?
      I think, this should be very easy, but, sorry...
      I tried:
      if (!defined? dlg) dlg = UI::WebDialog.... else dlg.bring_to_front
      But with this version, I am able to start several WebDialogs...
      Thanks for your help!
        Assuming your code is wrapped inside a method inside a module... then referring to the web-dialog like this will use the same object IF it already exists, and if it doesn't it makes a new one...
        @dlg = UI::WebDialog.new(...) unless @dlg
        Then later use @dlg to change its url, show it etc, and set/reset all other options available etc...
        • N
          niccah
          Sometimes, it is so easy! πŸ˜„
          Thanks TIG!!
          • Dan RathbunD
            Dan Rathbun
            This is important!
            The dialog instance is not destroyed when you close it. You can re-open it again.
            And if you had data from the dialog, stored in Ruby vars, you can reset them back into the dialog's Javascript vars, after it reopens.
            I'm not here much anymore.
