    Mantinence release coming soon.
    30 Posts 11 Posters 6.1k Views 11 Watching
      lumianti
      Hi CPhillips.
      Great to have you back. I wasn't sure if your valuable work on SP was abondoned, either. I'm glad it isn't.
      Right of the bat, may I suggest fixing emitted objects and entities created using "splitme" so they that would apear on SketchyReplay. It would help a lot of people in animation and since new Vray version is to come out it may become an ultimate animation tool for sketchup users.
      Thanks.
      • Dan RathbunD Offline
        Dan Rathbun
        (1) Can SP be made available as an rbz archive ??
        (I'd like to look at the code without actually running the installer.)
        (2) Any way a future edition can be made without WxSU / WxWindows ??
        I'm not here much anymore.
          +1
          • Bryan KB Offline
            Looking forward to the bug fixes.
            I've just started to try the tutorials and found it has multiple failures. I'm using SU 8.
            Great plug-in and I've seen some amazing things done with it.
              CPhillips
              I'll look into the RBZ thing. SP doesnt use Wx. There may be some stale references in the code but it is not required.
              • ashscottA Offline
                ashscott
                Really excited to see you back.
                My ruby knowledge is limited but I love SP and think the potential is huge - let me know if there is anything I can do to help in terms of testing etc.
                Have spent time playing with SP in conjunction with a tool called joytokey to allow me to run dual logitech joysticks and simulate prototype heavy machinery (similar to an excavator operator's configuration).
                People are blown away when I can let them virtually 'drive' a prototype machine, make a quick geometric modification to it and let them 'drive' it again with the new modification.
                Be very encouraged Chris - your work is brilliant
                Just some stuff I do with Sketchup.
                  mptak
                  AshCott, can you describe a little more your experience with joytokey. Looks intriguing.
                  • ashscottA Offline
                    ashscott
                    Well, SP allows you to refer to a single joystick for control by default. This is also the arrow keys which represent the various axes of the joystick.
                    However, one joystick is not enough so I used joytokey to assign keyboard commands that can be defined in SP to a second joystick.
                    So when I pull back on my second joystick, joytokey tells the system that "s" is being pressed. This way I can put a whole new set of functions into SP with the second joystick.
                    The limitation is that, with the primary joystick in SP, your input is along a scale. For example; if you have a motor set up to respond when you tilt the primary joystick right, the motor will speed up the harder you push the primary joystick to the right. With joytokey, the system is interpretting the secondary joystick as simply a set of buttons so, although it gives the illusion of a real world operator situation, the functions on the secondary joystick are either 'off' or 'on'....not variable like the primary joystick. It still does the trick though.
                    Hope that makes sense - there is probably a better way to do what I am doing but joytokey is my initial, hacky, solution
                    • ashscottA Offline
                      ashscott
                      Anything I can do to help with this Chris? - Testing etc?
                      Ash
                        CPhillips
                        Thanks but not yet ready for testing.
                        Kinda waiting for Trimble to release a new version of SU. I assume there is one coming since the google buyout.
                        • ashscottA Offline
                          ashscott
                          Ok, a new release will influence the way SP runs?
                            Next version will be "SketchUp 2013". When in 2013 it will be released has not been mentioned.
                              CPhillips
                              2013? Hmm. Might have to do something before that.
                              No, the new release will not need any new features. Just wanted to be current.
                              • ashscottA Offline
                                ashscott
                                and I was so enjoying the ever ascending numeration, Sketchup 21 would have been due in 2050 (thought-based modeling plugin comes standard with install package).
                                I'm jumping out of my lopsided desk chair to see the potential of SP's next iteration, even if its only bug fixes it will be awesome.
                                I know little about coding but is it worth putting SP on Github and try to get a community of coders around to help Chris out?
                                  They released SU8 M4 with the Trimble re-brand because their contract said so. That is the first Trimble release.
                                  • Bryan KB Offline
                                    I have just recently installed that and it runs great. The desktop icon has changed. su icon.JPGI already miss the old one. All plug-ins work without problems.
                                    Looking forward to SketchyPhysics update. I have some future projects that it will be great for.
                                      mptak
                                      Look forward to any and all updates. I have avoided updating to the latest su release partly cause I can't bear to part with the Sketchy Physics Piano but would love to take the plunge so I could dive more into Layout.
                                      • ashscottA Offline
                                        ashscott
                                        Any word on this Chris?
                                        • ashscottA Offline
                                          ashscott
                                          SU 2013 doesn't appear to have any drastic changes - I hope it hasn't thrown up any hurdles to SP development? http://www.sketchup.com/products/sketchup-pro/new-in-2013
                                          • 2 / 2
