    A Thread for Fine Design
    759 Posts 54 Posters 574.3k Views 54 Watching
    • daleD
      dale
      Digging a little deeper, there are apparently a few fonts that have been in the works for dyslexia.http://www.scientificamerican.com/article.cfm?id=new-font-helps-dyslexics-read
      And there seems to be a lot of research papers on Google Scholarhttp://scholar.google.ca/scholar?hl=en&q=fonts+for+dyslexia&btnG=&as_sdt=1%2C5&as_sdtp=
        driven
        this is 'best of british' design. IMHO
        I have one space frame and a number of the 1960's 'F' frame models
        lovely bikes, man and company.
        • Mike LuceyM
          Mike Lucey
          Yes indeed John! Not only British design but also British workmanship!
          I see a new trend over the past couple of years whereby small manufacturing companies are starting up and producing quality products in locations in the Western world that have been devoid on manufacturing for some time.
          I am not sure about what is causing this but I imagine the recession with all the layoffs we are seeing from the large multi-nationals has kickstarted this new trend. Also small start-ups can more easily get into quite high-tech ventures with the now low cost availability of design and manufacturing processes. It no longer takes 3-4 years and multi millions to design, develop and produce a car! The Qbeak and Lit C-1 are cases in point.
          An excellent some scale example of this trend is Kickstarter and in many cases SketchUp has been the design tool of choice, at least on the initial design concept. I hope this trend keeps moving forward.
          • simon le bonS
            simon le bon
            A little time since I have posted 😎
            This is the result of my search for today:
            Hand Paintings by Annie Ralli
            http://morfis.files.wordpress.com/2012/09/hand-painting-illusion-annie-ralli-2.jpg?w=820
            Top 15 Exotic Retreats For Design Lovers
            http://knstrct.com/wp-content/uploads/2012/07/Exotic-Retreats-Adventure-Travel-Vacations-Tree-House-13.jpg
            ☀ simon
            • daleD
              dale
              Simon
              Good to have you back. Those retreats are incredible. Kenya under the stars. 👍
              • simon le bonS
                simon le bon
                Hi Dale 😄
                I agree with you. The simplest is also my preferred 👍 ☀
                http://knstrct.com/wp-content/uploads/2012/07/Exotic-Retreats-Adventure-Travel-Vacations-African-Safari-9.jpg
                (Can we still call this "Design" ?)
                ++Simon
                • daleD
                  dale
                  Design is a process, and when a design is well thought out and executed you will see an end product like this that has considered everything for the users it is intended for.
                  Stephen, well done!
                  http://sketchucation.com/forums/viewtopic.php?p=436919#p436919
                  • Mike LuceyM
                    Mike Lucey
                    I'm quite fascinated with some the the transforming furniture designs that come to fore. This particular sofa/double bed/ workstation is one such!
                    http://www.homecrux.com/wp-content/uploads/2012/10/Transforming-sofa-bed-and-table-by-Fanny-Adam.jpg
                    http://www.homecrux.com/2012/10/16/1597/transforming-sofa-converts-into-dining-table-and-bed-for-two.html
                    • daleD
                      dale
                      Mike
                      I was just listening to a radio show about a new development in Vancouver that will offer living spaces under 400 sq ft (just over 37 sq m)This is highly unusual in Canada where people consider 2500 sq ft (232 sq m)small. We still think we have a lot of space to waste.
                      This style of furniture will be essential in a space this size.
                      It really requires some innovative design and joinery, and out of the box thinking.
                      • stefanqS
                        stefanq
                        Mayor, I think you'll love this vid. then . 🎉
                        • daleD
                          dale
                          The idea of converting one object and its function into another.
                          Red Dot Award winner for Design Concept Chan Wen Jie, with his "Convertible" stair that converts to a ramp.
                          Convertible is a user-friendly, dual-function staircase that can be transformed into a ramp.
                          The goal of this design is to help the elderly, those who have walking difficulties, or those who need to move heavy items in a trolley or on a cart to climb stairs more efficiently and conveniently. It aims to minimise falls and injuries.
                          Convertible incorporates a simple linkage mechanism system that requires minimal effort to operate, making it quick and easy to use. It is mounted directly onto existing stairs, and makes efficient use of space, time, and money in comparison to the construction of a new ramp. Convertible has been designed for a low construction cost, easy installation, and minimal maintenance.
                          • daleD
                            dale
                            And this type of conversion is made more pertinent with the major storms happening world wide right now. Designer Chen Yu Jung
                            It is important to promptly and efficiently settle and comfort survivors after disasters. Rely – a foldout sleeping domain – makes things easier by accommodating a survivors’ needs within it.
                            After a disaster has occurred, refuges and aid centres typically gather the survivors and distribute the required resources. However, the distribution of resources can potentially be ad hoc depending on their availability. Rely presents a survivor with everything they need (bar food) and encourages feelings of warmth, safety, reassurance, and comfort.
                            Rely contains a sleeping bag and light shelter, a bottle of water, a lighting tool, a stool, tableware, and toiletries. All the components are rolled up into a hexagon-shaped cylinder that can be zipped up and carried on one’s back with the help of straps. The rigid cylinder casing can be used as a sun shelter for the head when the bed is unfolded.
                            The two ends of the cylinder store goods. On one side, a small storage compartment houses the bottle of water, tableware, and toiletries. When it is turned upside down, this ‘cabinet’ can be used as a stool. On the other side, a lighting tool is accommodated. It can be used as a lamp, and also as a flashlight that is charged via the kinetic energy associated with pushing a button. The lamp can be stood upright on its base. The rolled-up unit is efficient to stack and transport.
                            • daleD
                              dale
                              And for the Kids Designer Hsu Wei Chih
                              This build-it-yourself children’s bike is made (with parental help) almost entirely from a pre-cut cardboard sheet.
                              Almost all the components of D-Bike are made from reinforced honeycomb cardboard. They are all punched out from a pre-cut cardboard sheet. Parents and their kids work together to assemble the bike, enhancing the parent-child relationship in the process. The intention is also that kids will learn from the assembly process.
                              Kids can create their own drawings on the provided self-adhesive paper, and stick them on each side of the bike. A unique bike is therefore created. Kids will gain confidence and have fun during the assembly, drawing, and resultant play with the bike. D-Bike is easy and inexpensive to manufacture.
                                Roger
                                [attachment=1:2ie461l4]<!-- ia1 -->Screenshot 2012-10-30 at 8.29.42 AM.png<!-- ia1 -->[/attachment:2ie461l4]
                                So instead of being a "Thread for Fine Design," this is a "Tread for fine Design."
                                http://www.azcreative.com
                                • daleD
                                  dale
                                  Well Roger, I was just nosing around the internet, and thought this might be a step in the right direction. 😄
                                  • daleD
                                    dale
                                    Apologies for the lapse in time between posts. Just crazy busy.
                                    So it was very refreshing to stumble across this Architect. Makoto Tanijiri / Suppose Design Office. http://www.suppose.jp/profile/index_e.html
                                    I was researching small residential spaces, and if there is someone who has a handle on this it is certainly this gentleman. But in looking thought his website, you can get a feeling that this is a very creative individual. Well worth the peruse.Screenshot 2012-11-13 at 7.32.19 AM.pngScreenshot 2012-11-13 at 7.31.46 AM.png
                                    And the street view.
                                    And some other projects
                                    I was taken by this rendering style
                                    • daleD
                                      dale
                                      Can't find much on the Lexmark site, but I know this would solve a lot of problems.
                                      Seems to get up to A2.
                                      • pbacotP
                                        Accomadates all types of Medias ?
                                        • david_hD
                                          david_h
                                          great design. . .not so great English.
                                          • pbacotP
                                            I just wondered how official the image is. Where did it come from?
                                            How are those big cartridges to move back and forth (no room), or are there separate print heads?
                                            I'd want one, just to be cool.
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 37
                                            • 38
                                            • 32 / 38
