    Retrieve import file name?
    3 Posts 3 Posters 212 Views 3 Watching
      lestercavey
      Is there some way to retrieve the "File -> Import..." file name that the user selects in the Import Browser? Perhaps some observer would have access to that name?
      My goal is to import a dxf file into Sketchup, and then run a script that parses that dxf text file, to obtain more information from it. I cannot use "model.import" directly though, because the user must have access to the Options dialog in the Import Browser. Also, Sketchup.send_action(21112) does not work for me. Even though send_action returns true, no Import Window appears.
        Since you have
        filepath=UI.openpanel(...)
        The imported file is
        filename=File.basename(filepath)
        If an importer doesn't append the file-type then use
        filename=File.basename(filepath, ".*")
        However, the name isn't 100% guaranteed as there might be a similar existing component's name so
        filename=model.definitions.unique_name(filename)
        which will give the one that will be used...
        • Dan RathbunD Offline
          Dan Rathbun
          Because the API Dictionary is way out of date, and that list of integers is erroneous.
          The proper integer (PC only,) to invoke the "File > &Import..." is 21933
          I do not know if there is a cross-platform string arg.
          I'm not here much anymore.
