    New SketchUp Developers Tools - TestUp
    18 Posts 6 Posters 1.1k Views 6 Watching
    • Chris FullmerC Offline
      Has anyone been playing with this yet?
      https://github.com/SketchUp/sketchup-developer-tools
      I was wondering what they said about it basecamp. I've installed it and run through testing all the scripts they have in it already. But I have not really tried it on anything of my own. Any comments on this new tool?
        driven
        Chris,
        does all the html/css work on a PC?
        I have to use WebInspector to turn the tabs on to even see the test's.
        not tested anything else yet...
          Everything worked fine on my system as far as I could tell. That's peculiar that it didn't work smoothly for you.
            I'll be making use of it for my larger, more complex plugins. You can create your own folder which will create a new tab in the UI.
            They also recommend that when we report API bugs we create a test unit for it, as it'd be the best way for them to handle it.
            (Btw, did you see in the code the reference to a Layout module... πŸ˜‰ )
              Works fine for me.
              What IE version do you have on your PC?
                This is what it should look like.
                  driven
                  no IE or PC...
                  I only have macs...
                  this isn't working
                      # This blurring forces an update so the mac displays TestUp
                      # immediately after loading its content.
                      if @is_mac
                        @webdlg.execute_script('window.blur()')
                  the page is blank until I right click, then, I see all the content as a single page, i.e. no 'Tabs' The css and js inplies 'Tabs', but I don't get them
                  this is also not working...
                              divNav.appendChild(ulNav);
                        // Views are already attached, so insert the nav before all elements
                        TESTUP_elements.gui.insertBefore(divNav, TESTUP_elements.gui.childNodes(0));
                  if I amend it to
                        var sp2 = document.getElementsByClassName('view');
                        TESTUP_elements.gui.insertBefore(divNav, sp2);
                  it generates the Tabs at the foot of the document, so I can then add css, to move it to the top of page
                  #divGui div {
                    margin-top; 100px;
                    padding-right; 20px;
                  #divTestCaseNav{
                    position; absolute;
                    top; -100px;
                    left; 100px;
                  All the test's will run in either state, but was not displaying as intended, and still isn't perfect.
                  I'm on the latest 'Mountain Lion'. the current SU version and the latest WebKit/WebCore that SU uses.
                  Can someone post a screenshot of what it should look like?
                    driven
                    cheers Chris,
                    I now have it looking like that, after the first 'Tab' selection,
                    there's still something wrong with the 'blur' function, so I still start 'blank', then after a 'right click' I get the 'Tabs', but with all the 'tabs' content 'text' until I choose any 'Tab' then they ball work, i.e. only show their own content...
                    • scottliningerS Offline
                      scottlininger
                      I suspect this is a Mountain Lion problem. Chris added to an issue over on the github site.
                      https://github.com/SketchUp/sketchup-developer-tools/issues/1
                      I'll buy a beer (or cookie) for whoever figures it out first. πŸ˜‰
                      • Scott Lininger
                        SketchUp Software Engineer
                        Have you visited the Ruby API Docs?
                        Aerilius
                        Does anyone have success getting firebug into this console? It bugsplats...
                        (I have it in the other console, but that doesn't help here)
                          Really? a Javascript in a WebDialog makes SU BugSplat?? 😲
                            driven
                            Cloned the latest version and the TestUp CSS works now, however the blur still fails to refresh the page, and still require a 'right' click...
                            Another thing...
                            %(#0000FF)[3 ERROR(S): The following plugins had errors and may not be fully loaded:
                            PLUGIN: platformhelper.rb
                            FOLDER: /Library/Application Support/Google SketchUp 8/SketchUp/plugins/sketchup-developer-tools/testup/ruby
                            ERROR: no such file to load -- win32/api
                            PLUGIN: registry.rb
                            ERROR: no such file to load -- Win32API
                            PLUGIN: testuprunner.rb
                            ERROR: No such file or directory - results/12.10.30.21.48.52-1351633732]
                            if I add a conditional is_mac=($LOAD_PATH[0][1..1] != ":") if !is_mac before the require, and an additional end
                            I can avoid the Win32 errors,
                            but the other I'm unsure about, the file is being made, but after the load check [ I guess]
                              driven
                              On Mountain Lion, This seems to be the simplest way to get the page to load correctly at startup...
                                <body>
                                  <a href="javascript&#058;;" id="btnRunTests" onclick="run();return false;">&nbsp;</a>
                                  <input id="runList" type="hidden" />
                                  <span id="headsUpDisplay"></span>
                                  <div id="divGui"></div>
                                   <script type="text/javascript"> bodyLoad() </script>
                                </body>
                              everything else can stay the same...
                              would that work on other mac and IE versions?
                                You might need to take your comments and code over to github. Scott and Brian Brown have been very active over there. Post something, get comments, and get it incorporated quickly.
                                  +1 - if even just to submit an issue ticket.
                                    slbaumgartner
                                    Well, maybe I can claim the beer !
                                    There is a javascript bug in testup.html, at least on the Mac. The statement
                                    throws an exception that causes createGUI to abort before it is finished, which is why the tabs never appear!
                                    At least on the Mac, childNodes is an array, not a function, and the correct syntax is:
                                    TESTUP_elements.gui.insertBefore(divNav, TESTUP_elements.gui.childNodes[0]);
                                    I still have the issue that John mentioned, the window is blank until the first time I right click. But all else is ok.
                                    I don't grok github yet, so if someone who does can post this as a suggested change, I'd be grateful.
                                    Steve
                                    P.S. I don't think it is relevant, but I also rewired SketchUp to use Ruby 1.8.7, per a note I posted on another thread.
                                    Also, out of sheer fussiness, I changed the test for @is_mac in testup.rb to
                                    @is_mac = (Object::RUBY_PLATFORM =~ /darwin/)!=nil
                                    since the original code returns 5 (the index of darwin in RUBY_PLATFORM) whereas @is_mac should be boolean.
                                    PPS - Oh, it seems the discussion moved to github and this issue has already been resolved there. 😳
                                    But that leaves me puzzled. If the fix has been known for a month or so, how come the code I got from GitHub still had all the old errors?
                                      driven
                                      I did wonder the same after cloning the new version and losing that fix, at the same time I added
                                      </body>
                                        <script> bodyLoad() </script>
                                      and deleted it the top tag, again.
                                      I'm away for a few days but will try your version hack, does it work with gems?
                                        slbaumgartner
                                        </body>
                                        The only reason it wouldn't work with gems is that SketchUp doesn't set up a library load path to anything except their own stuff. To get any other ruby code you need either to copy it into SketchUp's area or manipulate the ruby load path before you access it.
                                        Steve
