    Wooden Deck Plugin.
    5 Posts 3 Posters 281 Views 3 Watching
      mmbrajohan
      Hi guys.
      I'm searching for a plugin that converts planes into wooden lats.
      As seen in the attachments, the red plane (walkway) should be converted to a deck as shown in decking.jpg
      does anyone know of such a plugin?
      Johan.
      desired outcome
      • mitcorbM Offline
        mitcorb
        Considering the complexity of your model, you may wish to consider using a texture resembling what you want to do. Short of that, you could multicopy components. Maybe a plugin like Component Stringer, or Path Copy.
        The texture approach would keep the file size small. The other methods may grow your file to critical mass, and potentially slow navigation and response.
          mmbrajohan
          Hi mitcorb.
          Thank you for your reply... I tried the component stringer, but I couldn't get it to work as I wanted it too, so I'm just gonna copy over the component manually.
          • gillesG Offline
            gilles
            Why not use dynamic components, if you have pro version?
            • mitcorbM Offline
              mitcorb
              Chuck Vali, valiarchitects.com Instant Wall may be able to do this, if you can change orientation of the output. I am not sure. These plugins at this site are commercial plugins, as far as I know.
