    .skp to inventor autodesk
    15 Posts 10 Posters 10.0k Views 10 Watching
    • Z Offline
      zamgiu
      i want to export my work in inventor Autodesk...solution?
      • Jean LemireJ Offline
        Jean Lemire
        Hi Zamgiu, hi folks.
        What is the format that Autodesk Inventor can open or import ?
        If dwgis one of these, you can export a dwgfile from SketchUp but you need the Pro version for that.
        I see that you posted twice with the same subject. Once is enough, be patient, a few of the persons answering these kind of posts are now in Bouldfer, Colorado, USA, taking part in the 2012 SketchUp BaseCamp. This means that they cannot be active as much as they usually do.
        If you don't mind, I will delete the redundant post.
        Best regards and welcome to SketchUcation.
        • charly2008C Offline
          charly2008
          Autodesk Inventor Fusion 2013 (Free) can import skp-files directly.
          Charly
            bjornkn
            Really?
            I had to deliver skp files to some Inventor guys recently, and they asked for IGES or SAT. Apparently they were able to open the DWG files I sent them originally too.
            I can read from IGES and SAT with NuGraf/PolyTrans, but not write 😞
            IIRC I used FreeCAD to write IGES.
            They never told me they could've read the SKP files directly 😞
              charly2008
              Yes, the Skp model shown by me was just opened by me in "Inventor Fusion".
              • H Offline
                HPW
                Hello,
                Generally it is hard or impossible to convert a surface modell to a solid modell file.
                From solid to surface only the surface is triangulated and the surface mesh is written.
                The question is also what inventor fusion has build from the surface-file?
                It might be still a mesh-modell.
                Regards
                Hans-Peter
                  charly2008
                  Hans-Peter,
                  have a look here:
                  http://labs.autodesk.com/technologies/fusion/getting_started
                    gryse
                    Charly2008,
                    OK we can open SKP file in Inventor Fusion, but after? What can you do with this new file?
                    If the goal is to send it to a customer who works with Inventor, it's not the good way: no file exported with Fusion can be imported in Inventor full version...
                    However, I didn't find how.
                    Gryse
                    • W Offline
                      watkins
                      I've posted this before, but I can't remember where, and so here it is again.
                      Object moved
                      (www.spaceclaim.com)
                      SpaceClaim can export .sat and .iges files for other CAD systems.
                      Regards,
                      Bob
                        bjornkn
                        SpaceClaim looks promising. Always suspicious when they have no prices on their pages, but I have sent a request for a quote..
                          Just save your SKP format in OBJ format
                          you can with the pro version or with this free one by TIG
                          You can with this little free prog by Michael Gibson (the creator of Moi: Moment of Inspiration ) convert any OBJ file in 3DM format! (Open Nurbs)
                          http://moi3d.com/download/Obj23dmWireframe.zip
                          You have 2 options : each line will be a line without "double" or each closed faces will be a "closed curves"!
                          So reloadable in Moi, Rhino or directly in any CAD Nurbs program! 😉
                          You can try Moi a very less price than Spaceclaim! 😄
                          its export format for nurbs for Fusion Sat, Step, STP, 3DM, igs, iges 😉 and some other for poly modeler : OBJ, stl, 3DS, lwo, fbx, dxf (best converter at this date for Nurbs to OBJ format!
                          a little pervertising example : at the end it's a nurbs volume from an SKP format! 😎
                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3531936.jpg
                            sofashee
                            @charly2008 said:
                            Charly
                            Charly, how do you do this? I don't have an import option in my dropdowns, and using the open option doesn't allow access to non supported files.
                              charly2008
                              Hi Dave,
                              have a look at the photo below
                                LLesniak
                                Hi Charly2008,
                                Thanks for posting this information as I'm trying to do exactly as you've shown i.e. open a SketchUp model using Inventor Fusion. I'm using the Mac version and my screens and menus are completely different as the file format options on the Open command. Did you have to add any plug-ins or other mods in order to get all of those file types to appears in your Open menu?
                                Thanks again for your post.
                                LLesniak
                                  charly2008
                                  Hi Larry,
                                  I personally do not own the program. I tried it with a friend who owns the program.
                                  I have checked with my friend again, these are the standard import formats without any plugin.
                                  Do you have a licensed version or a trial program.
                                  Charly
