    Hardware advice
    30 Posts 7 Posters 1.5k Views 7 Watching
    • StinkieS Offline
      Stinkie
      How does this look?
      ALTERNATE.pdf
      • N Offline
        numerobis
        How does this look?
        this looks quite pricey... is hardware that expensive in Belgium?!?
        You really should compare prices. Maybe at http://www.vergelijk.be/
        (i don't know if there is a better one for Belgium)
        And concerning the components:
        • 3930K is good... but you need a cooler for it. (maybe a Thermalright HR-02 Macho or a Corsair H80/H100)
        • I think the board is ok (I have a P9X79 WS)
        • GTX 670 should be good... if you need it. (i would say it's overpriced...)
        • Antec 1200W PSU ...?!? WHY 1200W? Do you plan for quad SLI? A good 700-750W should be enough even if you want to overclock. Maybe a Seasonic X-Series 750W (i have one here ๐Ÿ˜‰ )
        • 2,5" 750GB HDD ...because it is more quiet? Or why did you choose a 2,5" HDD? I really would go for a SSD as system drive. The Samsung 830 are very good and cheap atm. because they will be replaced by the 840 next month. But i would take at least the 256GB version (~150โ‚ฌ) because it has a higher sequential write speed than the 128GB model.
        • 16GB Corsair CL8... I think the low latency will give you close to nothing. I would go for 4x8GB Corsair DDR3-1600 CL10 instead
        • StinkieS Offline
          Stinkie
          @numerobis said:
          this looks quite pricey... are the hardware prices in Belgium that high?!?
          Yes. Twenty-one percent VAT. ๐Ÿ‘Š
          Thanks alot for the pointers, as I know b*gger all about these things. Pretty much all I know is don't want to spend more than โ‚ฌ2500, and preferably less.
          How's these?
          pc_2.pdf
          pc_3.pdf
          • N Offline
            numerobis
            we have 19% here in germany so this can't be the difference...
            I think this looks better now.
            Here are some reviews of the cooler
            http://www.techpowerup.com/reviewdb/Cooling/Air/Thermalright/
            (Rev.A supports socket 2011)
            I can't say much about Coolermaster PSUs or the case, I don't know who is building the PSU for them http://www.tomshardware.com/reviews/psu-manufacturer-oem,2729-5.html. But i think it should be ok.
            Regarding the graphics card the second config would be much better i think. The GTX 650 is even slower than a GTX 560. http://ht4u.net/reviews/2012/nvidia_geforce_gtx_650_gt_640_evga_test/index40.php
            So i would say either the GTX 660 or 660 TI, or an "old" GTX 560, 560 TI (2GB), 570 TI (2,5GB) - depending on the price. And watch out for noisy coolers - i don't know the evga.
            Kingston RAM is good, but i can't say how it is running on this board. But normally they should be compatible.
            I don't know where you are storing your data. Maybe you would need an additional HDD of 1-2TB for it.
            I have only two samsung 830 in my machine and no HDD, one with 256GB and one with 512GB. The system is fully watercooled and quiet so i didn't want to have any HDDs installed. I use a file server to store the data and the SSDs for System and temporary project files (one 100GB partition for Win7 and the rest for data).
            I don't know if you can buy OEM (system builder) software in Belgium, but a OEM Win 7 x64 Pro would be much cheaper (~120โ‚ฌ). You don't need the retail package. What you get is only useless microsoft support. And the Pro version is normally enough. Ultimate adds only (useless) stuff like Bitlocker or EFS.
            • andybotA Offline
              andybot
              in terms of comparing CPU performance - here is a page with performance benchmarks:
              http://www.cpubenchmark.net/high_end_cpus.html
              This is very useful as it lists the raw horsepower without having to think through any multithreading conversions, etc. The higher on the list, the faster the processing. There's also a useful speed/price ratio column.
              • StinkieS Offline
                Stinkie
                Cool. Thanks, Andy.
                I think I'm done. Numerobis: muchos gracias.
                pc_4.pdf
                • StinkieS Offline
                  Stinkie
                  That is great info. Much obliged.
                  Thanks for helping out. I might quite possibly go with the second configuration ('pc_3'). It looks fairly decent, and I like the price.
                  As for storing data, I like to use external HD's.
                  Edit: it turns out I can indeed order an OEM version of Windows. ๐Ÿ‘
                  • N Offline
                    numerobis
                    I would say this looks like a nice system... ๐Ÿ˜‰
                    and if you plan to overclock it... 4,2-4,3GHz should be possible with this cooler - for higher clocks at a reasonable noise level you would need water.
                    ...one more point:
                    it seems that the difference in noise level isn't that big for the better GTX 660 cards.
                    But there are some who are more quiet, like one from Asus or Gigabyte
                    404 Not Found
                    (www.guru3d.com)
                    • StinkieS Offline
                      Stinkie
                      That's good to know, though I've always bluntly assumed overclocking shortens your CPU's lifespan. If I'm wrong ... good news for me. ๐Ÿ˜„
                      • soloS Offline
                        Tom depending on where you buy your rig (unless you are doing your own build) you can get them to do the overclock for you, that way you get a warranty.
                        • StinkieS Offline
                          Stinkie
                          Yeah, I figured as much. Did you overclock your system?
                          • soloS Offline
                            Nope, did not wanna mess with something that works fine.
                            • StinkieS Offline
                              Stinkie
                              Yeah ... I'm sure Numerobis is right, but I'm not overly comfortable with messing with my hardware either. However, the idea does have a certain lure. It might prove prudent, I think, if I consulted with the company I'm ordering my new machine from.
                              Anyway, thanks for your help, everyone. Especially you, Numerobis. ๐Ÿ‘
                              • N Offline
                                numerobis
                                if you don't overdo it in terms of voltage and temperature you will never notice a degradation of lifespan. Just stay within the save voltages (like below 1,3-1,35v vcore) and maybe 65-70ยฐC core temp.
                                It is possible that this will shorten the lifespan too... but maybe from 15 years to 12 or 10... so you will never be able to experience this ๐Ÿ˜‰
                                • michaliszissiouM Offline
                                  michaliszissiou
                                  Don't buy either, especially this MACPRO. It's old.
                                  from a macpro happy user.
                                  MacPros are in general very powerful but a 2008 model...
                                  Some thoughts on general Ghz counts are for the birds actually.
                                  Hyperthreading works perfectly, especially on xeons. To just count GHz is wrong. Count the speed of memory instead. Indicates the speed of motherboard in general.
                                  On the other hand a dual Xeon (a new hypethreading one) can beat any i7. Especially on rendering. Of course, a proper OS is needed. A Linux 64bit or OSX 10.6.8 or later is the appropriate choice.
                                  Try to have a good GPU. Nvidia or ATI, depends on your software. In general, ATIs are better under OGL. Nvidias have the CUDA though. A must under GPU based renderers.
                                  Whatever display you use, ATIs will make it look much better. Video will be better.
                                  Nvidias for CUDA only.
                                  All these tested under 3dcoat, zbrush, blender-cycles, octane etc. Under sketchup, I doubt if there's any significant difference in performance.
                                  • StinkieS Offline
                                    Stinkie
                                    You misunderstand, Michalis. I own that Mac Pro, and I'd like to replace it.
                                    I'm fond of OSX, but truth be told, both Linux and OSX are niche products. Remember how long it took for a Mac version of VfSU to appear?
                                    I know. Which is why I'll go with Nvidia.
                                    • StinkieS Offline
                                      Stinkie
                                      Alea iacta est. Prepare to be bombarded with weird, gloomy renders. ๐Ÿ˜Ž
                                      Processor: Intelยฎ Coreโ„ข i7-3930K
                                      GPU: Geforce GTX 660 Ti OC 3072 MB
                                      Cooling: Thermalright Silver Arrow SB-E Extreme
                                      PSU: Cooler Master Silent Pro MII
                                      Case: Cooler Master HAF X 942-KKN1
                                      HDD: Solid State Disk 2,5 inch SATA Samsung MZ-7PC256B/WW
                                      MB: MSI X79A-GD65 (8D)Intelยฎ X79 Express, ATX, SLI, CrossFire, 5x PCIe x16
                                      RAM: Kingston HyperX 32 GB DDR3-1600
                                      OS: Microsoft Windows 7 Professional 64bit
                                      • soloS Offline
                                        Great rig mate, I recently bought the exact same GPU (for Thea beta testing) and it works like a gem, trick is the extra ram and many Cuda cores.
                                        • StinkieS Offline
                                          Stinkie
                                          I am really eager to find out how much unbiased rendering is sped up by the gpu -and what the gpu's ram can handle, in terms of geometry and texture maps.
                                          • N Offline
                                            numerobis
                                            ๐Ÿ‘ Nice system... ๐Ÿ˜‰
