    Making a SketchUp game named "Resballiza"
    27 Posts 4 Posters 3.0k Views 4 Watching
    • renderizaR Offline
      renderiza
      Black Ball can't move over the horizontal middle line ?
      The ball can move freely all over the screen (even above the middle line)...There is a Resballiza.exe that runs without install, you can try it yourself with this following link.
      http://www.dropbox.com/sh/b9wp4fnvisd0qyd/-D3fdDBkZW
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        The link is fixed....thanks for letting me know. 👍
        Just drop the files inside a folder and done.
        • Dan RathbunD Offline
          Dan Rathbun
          transform! Vs move!
          transform! puts entries on the undo stack
          move! does not put entries on the undo stack (so it's faster.)
          Both only work on a Group or ComponentInstance
          For primitives you must use:
          Entities.transform_entities()
          .. which says:
          Important note: If you apply a transformation to entities that are not in the current edit context (i.e. faces that are inside a group), SketchUp will apply the transformation incorrectly, since the geometry has one origin and the current edit context has another. You can correct for this by watching the Model.edit_transform and Model.active_path. See ModelObserver.onActivePathChanged for more information.
          I'm not here much anymore.
            Dan Rathbun
            Oh.. and the toplevel namespace (module) should be YOUR company or author name.
            Not something common like "Game"... maybe Renderiza or RiveraR ??
              renderiza
              Problem fixed!
              I now don’t have to delete any line of code after I hit the “exec” button for the script to work. Let me explain how this issue on the last code I posted was fixed. I was looking through the code Dan Rathbun posted in the following link.
              http://forums.sketchucation.com/viewtopic.php?f=180&t=48045
              I was asking myself why he uses this “||” in “@@duration ||= 15” for example and decided to put “||” in my own code. For some “magical” reason the script now works.
              Here is the new code:
              # This file attepts to move an object down and when it reachea a certain distance it resets.
              require('sketchup.rb')
              module Renderiza
              	module Resballiza
              		class MyGame
              			@@x ||= 600
              			@@z ||= 800
              			if @@z <= 800
              				@@z = @@z - 100
              			if @@z <= -200
              				@@z = 800
              				@@x = rand(600)
              			@ball = Sketchup.active_model.selection
              			@move = Geom;;Vector3d.new(@@x,0,@@z)
              			@ball.each do
              			|ball| ball.move!(Geom;;Transformation.translation(@move))
              			end #do
              		end #class MyGame
              		window = MyGame.new #If this is not here the above script won't work.
              	end #module Resballiza
              end # module Renderiza
              Also the object is Xaxis randomly generates every time it resets. Now I can move to the next step which is to animate the object without having to keep clicking the “exec” button.
              Wish me luck!
                Dan Rathbun
                Please use [ code ] ... [ /code ] bbTags, with space indenting.
                I did say those snippets had problems...
                Look at my example: AnimateSelection
                Look at the Animate class. See how I defined an initialize() method ??
                When you call a class' public class constructor method new(), it creates the instance, THEN calls the instance's copy of the initialize() method.
                In this method is where you init @var instance variables.
                Did you read the "Pick-Axe" Ruby Pragmatic Programmer's Guide ?? It's basic Ruby 101 ...
                  renderiza
                  Current issue at hand…
                  In the code bellow the references have to be “$” (constant) or else the script won’t work.
                  1st Problem
                  I have tried to use “@”& “@@” but it doesn’t seem to work… I should not use a constant as reference but right now I am lost in how to not use them.
                  2nd Problem
                  When using this following code:
                  … This code is similar to the one been used by the following here;
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=25498#p218970
                  module Renderiza
                  	module Resballiza
                  		class SuGame
                  			$x ||= 600
                  			$z ||= 800
                  			if $z <=> 800
                  				$z = $z - 100
                  			if $z <= -200
                  				$z = 800
                  				$x = rand(600)
                  			def nextFrame( view )
                  			  $ball.move! $t                                                           #<<<---- using the move! there
                  				return ( Time.now() - $start ) <3
                  			def stop()
                  				puts 'emptying trash'
                  			$ball = Sketchup.active_model.selection[0]
                  			@move = Geom;;Vector3d.new($x,0,$z)
                  			$t = Geom;;Transformation.translation(@move)
                  			$start = Time.now()
                  		end # of class SuGame
                  			view = Sketchup.active_model().active_view()
                  			view.animation = SuGame.new
                  end #module Renderiza
                  Continuation of problem #2…
                  When the animation is started the object is position doesn’t travel down like it should with only one click. I still have to keep clicking the ‘exec’ button for it to move.
                  There is something about this “move!” method because if you replace that with “transform!” like it was originally written by the other guys then the object is position changes over time. But there has to be something that will still enable me to use the move! method because I really like that it uses the global axis of sketchup instead of the local axis of the object the transform! uses.
                    renderiza
                    Here is a video update about the progress of the game so far;
                    I need to find an alternative solution for playing sound effects since the Sketchup "UI.play_sound" can't seem to handle simultaneous sounds to overlay each other.
                    The current script is based on Scott Lininger's "Prince IO" but a lot of things are different. For example the collision is base on a javascript code to compare distances and not sketchup raytrace.
                    If you want to test the current alpha version of the game you can download it here for testing.
                    Dropbox - No Access - Simplify your life
                    (www.dropbox.com)
                      Does it a special install or more files to install than Resballiza.rb ?
                      You have not an only zip file ?
                      I have run it, I have the Menu Inside the Menu Plugins,Resballiza Demo level, but nothing happen ? 😮
                      tested under V7
                        renderiza
                        tested under V7
                        Apart from the "resballiza.rb" file being in the plugins directory of sketchup you also need to have the folder included in the link named "resballiza". If you have the "resballiza.rb" and resballiza folder with all the files inside the plugins directory it should work unless there is incompatibilities with a version of sketchup lower than 8. I will see if I can find the problem.
                          renderiza
                          So it's normal if I had onl the RB! 💚
                          Ok I will made a new test when I have some free times!
                          But It's some painful to download file one by one!
                          A one Zip file will be a lot of better!
                          Ok I have included the zip and just in case saved the sketchup file of the level in version 6. Also for the time being the sounds are disabled until problem is fixed.
                            So it's normal if I had only the RB! 💚
                              Thanks for the ZIp file!
                              All works fine now! (tested on V7)
                              Have you a test (or other thing) for be sure there is not a fully horizontal line of balls ?
                                renderiza
                                Well good question…
                                There are 10 white balls that will each reset a value of 100 of each other in the z axis when they reach the bottom of the screen.
                                Examples of reset value in z axis;
                                ballZa = 900 ;
                                ballZb = 1000 ;
                                ballZc = 1100 ;
                                ballZd = 1200 ;
                                ect…
                                There is a possibility that after a period of time they will be near parallel of one another but to create horizontal line will be unlikely since the x axis is generated randomly. Not saying is not impossible...I guess I will have to test it and see if it happens.
                                  Impossible is always probable :Murphy's law! 💚
                                    renderiza
                                    I hope Murphy is right because solving the sound effect problem its beginning to look impossible. I will try to work on other parts of the game until eureka shows at the door.
                                      Dan Rathbun
                                      I hope Murphy is right because solving the sound effect problem its beginning to look impossible. ...
                                      Did you try the <embed> tag yet?
                                      See: http://sketchucation.com/forums/viewtopic.php?f=180&t=48260&p=433470#p433470
                                      It is not impossible.. we are having you the obvious simple possibilities first (because they are likely to be cross-platform, and because the system specific solutions are very advanced programming exercises.)
                                        renderiza
                                        Here is a video update;
                                        youtube;xFrD7ORH4X0]http://www.youtube.com/watch?v=xFrD7ORH4X0&feature=plcp
                                        To download the latest SketchUp game version go here;
                                        https://www.dropbox.com/sh/w9m7du0fnhkgwv0/bIqndmMs1S
                                          Dan Rathbun
                                          Cute!
                                          Did you make the background a watermark ??
                                            renderiza
                                            Thanks...Yes its watermark image. I was planing for the future to build animated backgrounds. Maybe using SinfonIA animation tools since it is so easy to use, but that will require other people to have the plugin as well to see the animations.
