    Making a SketchUp game named "Resballiza"
    27 Posts 4 Posters 2.9k Views 4 Watching
    • renderizaR Offline
      renderiza
      This Thread is meant to document my progress in learning ruby inside sketchup while trying to make a simple game. So any questions or discoveries will be posted here.
      Before venturing in trying to figure out how to make a game inside sketchup, I started one called “Resballiza” with ruby and Gosu. The progress of that task was successful and more info can be found here: Resballiza info and Video Preview
      My future goal is to try and replicate “Resballiza” inside sketchup.
      Wish me luck! 👍
      Here is a game I am developing for SketchUp
      Video Update #1
      http://www.youtube.com/watch?v=xFrD7ORH4X0&feature=plcp
      Video Update #2
      http://www.youtube.com/watch?v=JuM2qtBy7bs&feature=plcp
      Video Update #3
      To download the latest SketchUp game version go here;
      https://www.dropbox.com/sh/w9m7du0fnhkgwv0/bIqndmMs1S
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        renderiza
        transform! Vs move!
        The method “move!” seems to behave similar to how the objects move in “Resballiza” with the “gosu” extension for ruby. It uses a global axis as reference for the (x,y,z) coordinates of the object while the Method “transform!” seems to use the local axis of that entity.
        I kind of figured out how to reset the position of an object when the Zaxis reaches a certain point using the method “move!” with the following code…
        # This file attepts to move an object down and when it reachea a certain distance it resets.
        require('sketchup.rb')
        module Game
        	module Resballiza
        		class MyGame
        			def inicializa ()
        				@x = 600
        				@z = 800
        			@x = 600 #Delete this after 1st exec hit for ball to move
        			@z = 800 #Delete this after 1st exec hit for ball to move
        			@ball = Sketchup.active_model.selection
        			@move = Geom;;Vector3d.new(@x,0,@z)
        			@ball.each do
        			|ball| ball.move!(Geom;;Transformation.translation(@move))
        				if @z <= 800
        					@z = @z - 50
        				end #if
        				if @z <= -200
        					@z = 800
        					@x = rand(600)
        				end #if
        			end #do
        		end #class MyGame
        		window = MyGame.new #If this is not here the above script won't work.
        	end #module Resballiza
        end # module Game
        The code doesn’t run smoothly inside “Sketchup” because ones you hit “exec” in the Web Console for the first time, you have to delete the code line that says “#Delete this after 1st exec hit for ball to move”. Once that is done you need to keep hitting “exec” for object to keep falling until it resets. I wish I can figure out how to solve this so I can move to the next step.
          Cool game 😄
          Black Ball can't move over the horizontal middle line ?
          Bon courage! ☀
            error 404 😉
              renderiza
              The ball can move freely all over the screen (even above the middle line)...There is a Resballiza.exe that runs without install, you can try it yourself with this following link.
              http://www.dropbox.com/sh/b9wp4fnvisd0qyd/-D3fdDBkZW
                renderiza
                The link is fixed....thanks for letting me know. 👍
                Just drop the files inside a folder and done.
                • Dan RathbunD Offline
                  Dan Rathbun
                  transform! Vs move!
                  transform! puts entries on the undo stack
                  move! does not put entries on the undo stack (so it's faster.)
                  Both only work on a Group or ComponentInstance
                  For primitives you must use:
                  Entities.transform_entities()
                  .. which says:
                  Important note: If you apply a transformation to entities that are not in the current edit context (i.e. faces that are inside a group), SketchUp will apply the transformation incorrectly, since the geometry has one origin and the current edit context has another. You can correct for this by watching the Model.edit_transform and Model.active_path. See ModelObserver.onActivePathChanged for more information.
                  I'm not here much anymore.
                    Dan Rathbun
                    Oh.. and the toplevel namespace (module) should be YOUR company or author name.
                    Not something common like "Game"... maybe Renderiza or RiveraR ??
                      renderiza
                      Problem fixed!
                      I now don’t have to delete any line of code after I hit the “exec” button for the script to work. Let me explain how this issue on the last code I posted was fixed. I was looking through the code Dan Rathbun posted in the following link.
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=48045
                      I was asking myself why he uses this “||” in “@@duration ||= 15” for example and decided to put “||” in my own code. For some “magical” reason the script now works.
                      Here is the new code:
                      module Renderiza
                      	module Resballiza
                      		class MyGame
                      			@@x ||= 600
                      			@@z ||= 800
                      			if @@z <= 800
                      				@@z = @@z - 100
                      			if @@z <= -200
                      				@@z = 800
                      				@@x = rand(600)
                      			@move = Geom;;Vector3d.new(@@x,0,@@z)
                      			@ball.each do
                      			end #do
                      		end #class MyGame
                      end # module Renderiza
                      Also the object is Xaxis randomly generates every time it resets. Now I can move to the next step which is to animate the object without having to keep clicking the “exec” button.
                      Wish me luck!
                        Dan Rathbun
                        Please use [ code ] ... [ /code ] bbTags, with space indenting.
                        I did say those snippets had problems...
                        Look at my example: AnimateSelection
                        Look at the Animate class. See how I defined an initialize() method ??
                        When you call a class' public class constructor method new(), it creates the instance, THEN calls the instance's copy of the initialize() method.
                        In this method is where you init @var instance variables.
                        Did you read the "Pick-Axe" Ruby Pragmatic Programmer's Guide ?? It's basic Ruby 101 ...
                          renderiza
                          Current issue at hand…
                          In the code bellow the references have to be “$” (constant) or else the script won’t work.
                          1st Problem
                          I have tried to use “@”& “@@” but it doesn’t seem to work… I should not use a constant as reference but right now I am lost in how to not use them.
                          2nd Problem
                          When using this following code:
                          … This code is similar to the one been used by the following here;
                          http://forums.sketchucation.com/viewtopic.php?f=180&t=25498#p218970
                          module Renderiza
                          	module Resballiza
                          		class SuGame
                          			$x ||= 600
                          			$z ||= 800
                          			if $z <=> 800
                          				$z = $z - 100
                          			if $z <= -200
                          				$z = 800
                          				$x = rand(600)
                          			def nextFrame( view )
                          			  $ball.move! $t                                                           #<<<---- using the move! there
                          				return ( Time.now() - $start ) <3
                          			def stop()
                          				puts 'emptying trash'
                          			$ball = Sketchup.active_model.selection[0]
                          			@move = Geom;;Vector3d.new($x,0,$z)
                          			$t = Geom;;Transformation.translation(@move)
                          			$start = Time.now()
                          		end # of class SuGame
                          			view = Sketchup.active_model().active_view()
                          			view.animation = SuGame.new
                          end #module Renderiza
                          Continuation of problem #2…
                          When the animation is started the object is position doesn’t travel down like it should with only one click. I still have to keep clicking the ‘exec’ button for it to move.
                          There is something about this “move!” method because if you replace that with “transform!” like it was originally written by the other guys then the object is position changes over time. But there has to be something that will still enable me to use the move! method because I really like that it uses the global axis of sketchup instead of the local axis of the object the transform! uses.
                            renderiza
                            Here is a video update about the progress of the game so far;
                            I need to find an alternative solution for playing sound effects since the Sketchup "UI.play_sound" can't seem to handle simultaneous sounds to overlay each other.
                            The current script is based on Scott Lininger's "Prince IO" but a lot of things are different. For example the collision is base on a javascript code to compare distances and not sketchup raytrace.
                            If you want to test the current alpha version of the game you can download it here for testing.
                            Dropbox - No Access - Simplify your life
                            (www.dropbox.com)
                              Does it a special install or more files to install than Resballiza.rb ?
                              You have not an only zip file ?
                              I have run it, I have the Menu Inside the Menu Plugins,Resballiza Demo level, but nothing happen ? 😮
                              tested under V7
                                renderiza
                                tested under V7
                                Apart from the "resballiza.rb" file being in the plugins directory of sketchup you also need to have the folder included in the link named "resballiza". If you have the "resballiza.rb" and resballiza folder with all the files inside the plugins directory it should work unless there is incompatibilities with a version of sketchup lower than 8. I will see if I can find the problem.
                                  renderiza
                                  So it's normal if I had onl the RB! 💚
                                  Ok I will made a new test when I have some free times!
                                  But It's some painful to download file one by one!
                                  A one Zip file will be a lot of better!
                                  Ok I have included the zip and just in case saved the sketchup file of the level in version 6. Also for the time being the sounds are disabled until problem is fixed.
                                    So it's normal if I had only the RB! 💚
                                      Thanks for the ZIp file!
                                      All works fine now! (tested on V7)
                                      Have you a test (or other thing) for be sure there is not a fully horizontal line of balls ?
                                        renderiza
                                        Well good question…
                                        There are 10 white balls that will each reset a value of 100 of each other in the z axis when they reach the bottom of the screen.
                                        Examples of reset value in z axis;
                                        ballZa = 900 ;
                                        ballZb = 1000 ;
                                        ballZc = 1100 ;
                                        ballZd = 1200 ;
                                        ect…
                                        There is a possibility that after a period of time they will be near parallel of one another but to create horizontal line will be unlikely since the x axis is generated randomly. Not saying is not impossible...I guess I will have to test it and see if it happens.
                                          Impossible is always probable :Murphy's law! 💚
                                            renderiza
                                            I hope Murphy is right because solving the sound effect problem its beginning to look impossible. I will try to work on other parts of the game until eureka shows at the door.
