    SCF Forum Syntax Highlighter (v 1.5)
    21 Posts 6 Posters 5.0k Views 6 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Noticed that the Google Syntax highlighter doesn't colorize the first @ in a module / class @@variable correctly.
      Here's another test that fails in some hightlighters, when if and unless are used in modifier position:
      puts("Testing") if @value.empty?
      warn("Error!") unless $VERBOSE
      (Hey if and unless are coloered correctly!)
      Here's another test that fails in some hightlighters, the periods in ranges don't color correctly:
      for index in 0..256
        puts("The value is #{@value[index].to_s}")
      end # for
      (Looks like the second "dot" is a different color.)
      I'm not here much anymore.
        Dan Rathbun
        I am seeing a warning in my Chrome extensions list, that says support for manifest version 1.0 will be ending.
        Ref: http://code.google.com/chrome/extensions/manifestVersion.html
        It says extensions need to be updated to use version 2.
          Jim
          Version 2 added.
            Dan Rathbun
            After loading.. the title still says ver "1.0"
            Line numbers do not appear, and alternating line shading is off.
              driven
              I noticed this while experimenting on the new site, then tested here,
              other than the odd colors, this works without the plugin on mac,
              what about on PC's?
              <span class="syntaxdefault"></span><span class="syntaxcomment"># By default, SketchUp automatically loads (using require) all files with<br /># the .rb extension in the plugins directory.  This function can be used<br /># to automatically load all .rb files from a different directory also.  to<br /># use this add a call like the following to a file in the plugins directory<br /># require_all "MyRubyScripts"<br /></span><span class="syntaxdefault">def require_all</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    begin<br />        rbfiles </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Dir</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"*.{rb,rbs}"</span><span class="syntaxkeyword">)]<br /></span><span class="syntaxdefault">        </span><span class="syntaxkeyword">$;.</span><span class="syntaxdefault">push dirname<br />        rbfiles</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">f</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">require f</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    rescue<br />        puts </span><span class="syntaxstring">"could not load files from #{dirname}"<br /></span><span class="syntaxdefault">    end<br />end</span>
              • KrisidiousK Offline
                Krisidious
                A lil OT, I only got here because I thought this might have to do with my alert request.
                Yeah Chrome is fast... But it grows and grows... independent process for tabs and who knows what else.
                running one instance of each FF, Chrome and IE9 these are the processes I get.
                I think FF is by far the biggest beast of all. I might add I have like 3 plugins going on FF.
                By: Kristoff Rand
                  Dan Rathbun
                  Fix & bump to v1.4
                  (The Chrome Extensions panel will give you the path to the extension folder, in your USER local APPDATA path.)
                  ISSUES:
                  (1) The forum URL changed after the new site launch, so the manifest.json needed to change:
                  • "matches" value needed a new url entry for the new site.
                  • "js" value, needed the ref to "jquery-1.6.2.min.js" removed.New "manifest.json" file:
                      "manifest_version" ; 2,
                      "name" ; "SCF Syntax Highlighter",
                          "version" ; "1.4",
                          "description" ; "Formats SketchUcation <code> areas.",
                          "content_scripts" ; [
                              "matches"    ; ["http://sketchucation.com/forums/*","http://forums.sketchucation.com/*"],
                              "js"         ; ["google-code-prettify/prettify.js", "contentscript.js"],
                              "css"        ; ["google-code-prettify/prettify.css"],
                              "run_at"     ; "document_idle",
                              "all_frames" ; false
                  (2) As John said the Jquery needed to be replaced in "contentscript.js":
                  old "contentscript.js" file:
                  //$("#p").hide();
                  //$("#page-body div p").hide();
                  //$("#page-body img").hide();
                  $("code").parent().parent().parent().css("width","100%");
                  $("code").css("max-height", "800px");
                  $("code").addClass("prettyprint");
                  // $("code").addClass("linenums");
                  prettyPrint();
                  //$("code").css("border", "1px solid blue");
                  chrome.extension.sendRequest({}, function(response) {});
                  new "contentscript.js" file:
                  // SCF [code] Google Syntax Highlighter v1.4+
                  x=document.getElementsByTagName('code');
                  var newatt;
                  for (i=0;i<x.length;i++)
                    newatt=document.createAttribute("class");
                    newatt.value="prettyprint linenums";
                    x[i].setAttributeNode(newatt);
                  prettyPrint();
                  Reload from the Chrome Extensions panel, after making changes.
                  Refresh any pages with code blocks.
                    Jim
                    Thanks much to John and Dan - I have updated the .zip in the first post with your fixes, and simplified the structure.
                      Dan Rathbun
                      @jim said:
                      Note: Dan likes the line numbers, I do not because the line numbers are included when the selected code is pasted in an editor.
                      That's news to me.. because it does not happen to me!
                      I usually use the SELECT ALL button at the top of the codebox.
                      Do you mean if you are copying the whole post ??
                        driven
                        @Jim,
                        how about changing the topic title to just SFC_Forum_SyntaxHighlighter and include other browser versions in your top post.
                        I've done a 'GreaseKit' which works for most 'WebKit' Browsers including 'webDialog'.
                        and a Safari Extension both based on 'google-code-prettify'
                        FireFox should be easy...
                          driven
                          @dan rathbun said:
                          Wondering...
                          can we embed a conditional statement within a CSS script ??
                          MSIE lets us have a user (client-side) css file applied to ALL websites, so if I could something like have:
                          if window.location contains "forums.sketchucation.com" then CODE {max-height: auto}
                          I know this post is old, but to get this to work as a Safari Extension,
                          I had to 'apply to all' then 'whitelist' the forum then 'blacklist all'.
                          On safari the 'whitelist' has precedence over the 'blacklist', so only the forum gets the highlighting...
                          maybe IE has something similar?
                            Dan Rathbun
                            @driven said:
                            @Jim, how about changing the topic title to just SFC_Forum_SyntaxHighlighter and include other browser versions in your top post.
                            A one-stop shop ?
