    Draw curved line so difficult in SU
    7 Posts 4 Posters 532 Views 4 Watching
    • B
      bigeye2012
      hi, it is so difficult to draw some curved lines in SU.
      in Photoshop , it is very easy to make irregular curved lines.
      i wonder, is there any plugin to make irregular curved lines easily?
      • GaieusG
        @sketchymick said:
        There's a few plugins like bezier curves.
        And for the reference: http://forums.sketchucation.com/viewtopic.php?t=13563
          Jim
          It looks like you tried to draw each "tooth" individually. A Better approach would be to draw one tooth, then use the Rotate Tool ( **)**to copy it and make a radial array.
          • GaieusG
            @jim said:
            then use the Protractor to copy it and make a radial array.
            You mean the Rotate tool...
              Jim
              Like I said - the Rotate Tool. (original reply edited.)
                sketchymick
                It's not too hard in sketchup. There's a few plug-ins like bezier curves. I did the following:
                Created an 11 point polygon
                Created a tooth component that joined two of the polygon points (so each tooth would match exactly using the polygon sides for correct orientation)
                rotated (with copy x10) the tooth from one point of the polygon to the next using the centre of the polygon as the axis
                exploded the components and used the weld plug-in to make it a single polyline
                and it's regular, and you only need to edit one tooth to get the whole thing perfect
                Cheers
                • Mick
                "I love the sound that deadlines make as they rush past"
                • B
                  bigeye2012
                  guys, thank you very much!
