    Using the Cancel btn, to return to previous menu?
    22 Posts 5 Posters 971 Views 5 Watching
      Here's an example I know works as I have tested it...
      require('sketchup.rb')
      module CANCEL_TEST
      	#Set default settings
      	@height = 9.feet if not @height # floor to floor height
      	@riser = 16 if not @riser       # no. risers total
      	def self.run()
      		self.dialog1()
      	# Dialog box #1
      	def self.dialog1()
      		prompts = ["Floor/Floor Height ", "No. Risers"]
      		values = [@height, @riser]
      		@results1 = inputbox prompts, values, "Dialog Box #1"
      		if @results1
      			@height, @riser = @results1
      			@riserheight=@height/@riser  # riser height
      			self.dialog2()
      		else
      			return nil
      	# Dialog box #2
      	def self.dialog2()
      		prompts = ["My RiserHeight  ", "--------"]
      		values = [@riserheight, @any_entry]
      		@results2 = inputbox prompts, values, "Dialog Box #2"
      		if @results2
      			@riserheight, @any_entry = @results2
      			puts "Got here !"
      			[@height,@riser,@riserheight,@any_entry].each{|e| puts e}
      		else
      			self.dialog1()
      			return nil
      	unless file_loaded?(__FILE__)
      		UI.menu("Plugins").add_item("Cancel") { CANCEL_TEST.run() }
      	file_loaded(__FILE__)
      	# load"CANCEL_TEST.rb"
      end#module
      IT is now properly structured to loop back into itself is needs be... πŸ˜’
        tomot
        Thanks TIG:
        I would never have been able to figure out the self.run routine on my own! πŸŽ‰
        [my plugins](http://thingsvirtual.blogspot.ca/)
        tomot
        • 2 / 2
