    How to make a model follow with movetool
    3 Posts 2 Posters 479 Views 2 Watching
      alecchyi
      I could add a model in ,and send_action moveTool ,i am a newer in ruby plguin develop about sketchup.
      how to make a model follew with the movetool? thanks very much!
        Let's assume model=Sketchup.active_model
        If you simply want to add an external SKP as a component use:
        defn = model.definitions.load(path_to_skp)
        where perhaps path_to_skp="C:/users/alecchyi/desktop/MyComponent.skp"
        This will ensure it's now loaded into the model.
        Then name=defn.name - just in case it's been given a different name from what you expected ?
        Then model.place_component(defn, repeat)
        If repeat=false then you get to add one instance of that component - just like the native tool, with 'move' built-in etc.
        If repeat=true then you get to place multiple instances... one after the other...
        If you want to place a component that's already loaded 'by name', then set name="MyComponentsName", then
        defn=model.definitions[name]
        before running the 'place_component' code...
        You can select an instance in code then run the Move tool on it, but that isn't what you asked??
          alecchyi
          😄 i got it,谢谢
