    How to deform ovalish object
    70 Posts 5 Posters 9.7k Views 5 Watching
      Make like this! โ˜€
      Center on the front view of the Body
      Make a zoom on it
      Then double Click again and again... for arrive to the Level of group of the element
      Press the icon Xray Mode (it's a toggle command ON / Off etc...)
      Select the face in the front of the element you want move
      Right CLick / Hide
      You can now select inside your top cรดne of the part body ๐Ÿ˜„
      Just careful to not select another vertice behind in the same time!
        rumcajs
        I've just found that I can zoom in the body and simply select the bottom of the ovalish body. With Fredo scale tool I had discreased the bottom onto normal level. But I need to extend the the hips and to add there circles to make it cylinder. This is question how to add new entities into existing object.
        Quite, one man would say, it must be difficult to build such model, but now I see that with SU, it can be super easy!
        The idea with selecting objects from inside the body is good. But I found that better is to select the circle around body or just a part of arc and to change its scale... Or rather to say you did guide me this way. Also sometimes just rotating of some line can help to get better shape (this I did with breasts together with scale).
          Just create anything you want
          Go to the level of group of the body you want add if you wan add inside a special group
          this can be just a modification of an existing group!
          or your new object is also a new group grouped to another group or not!
          with SU you can make anything you want ๐Ÿ˜„
          Use the window /Outliner โ—
          for select, move, add, delete etc...anything in any group level existing to an other!
          Move group of group...components etc...
          โ˜€
          It's the more powerful tool of Sketchup! ๐Ÿ‘
          "+" for extend, "-" for rollback
          Don't forget to name your group or component with an expressive name โ—
          because when you will have an aircraft carrier that will be more easy! ๐Ÿ˜Ž
            rumcajs
            No worries, I understand the Outliner, groups and components. I use it and I know that when I would like to create e.g. heart, or stomach, I would need to create group. That is not problem. I asked not on group, but on object. But I should say entity. So my question is about this. We have the ovalish body entity. And there in the bottom of the oval, I need to add one or more circle to extend the oval. So when I will have more circles in the hips of body, I can better model it. But I don't want to put hips in group, it is one entity, whole body is one entity with hips.
            So I don't need to add new groups. There is everything already. I need only change the shape -> and that means to add the details. So for hips right now, I need to add the circle one or two*. But I don't want to create new circle which is out of the body structure.
            • There is a picture above by 9:59 pm. I need to add it under the yellow frame.
              rumcajs
              OK, but how can I change the object? Is there some plugin which can correct the object if I had draw a circle there?
              Similar situation - here I need to add circles to the body to create neck and shoulders shape:
              http://i45.tinypic.com/2585f9w.png
                So select only the part that you want modify
                Inverse Selection / Hide
                Just carreful some object are Groups, some are components !
                So when you modify a component all instances of this component will be change!
                Except if you make it "Unic"
                Ok Use this plugin ๐Ÿ˜‰
                I come back in few minute ๐Ÿ˜‰
                  Extrusion Cross editing : it's free in the Training edition ๐Ÿ˜‰
                  [flash=560,315:1i4goeba]http://www.youtube.com/v/11mhfNJlduE[/flash:1i4goeba]
                    You can also use Zorro2! by Whaat ๐Ÿ˜Ž
                    Just use the views front side top and camera parallel projection for have straight circle // existing circle
                    if you trim a spheric form!
                    Zorro2 don't create face inside the volume! ๐Ÿ˜Ž
                    You can't "slide" the cross section like the previous tool !
                    Move, scale, Rotate yes ๐Ÿ˜„
                    So be sure to place it! ๐Ÿ˜‰
                    Will be in the Menu Tool !
                      rumcajs
                      That plugin is really cool. I've seen face editing. Cool. Thanks.
                        rumcajs
                        It works, but I have problem with the neck. I have did a mistake when I scaled a neck and saved it. The neck had torned off. I needed to rescale it, but it did not connect with the body already. How to connect it? I cannot draw on it until it is connected back.
                        http://i47.tinypic.com/2evpz7l.png
                          Impossible to answer without file ๐Ÿ˜„
                          (save as V6)
                            rumcajs
                            I had a dream about SU during I slept (Yes, I work during my sleep!). It was that I could draw soft edges or smooth edges directly. I realized, that I don't know if is it possible? Acually I don't know much about soft edges, I've just look for help and found Soft edges dialog box:
                            http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114940
                            But where can I found this box? I had seen it somewhere days ago.
                            Next thing I have in my brain now is that, it could be good if we could have a mode for interference for segments. For example, I want to find some segment and must click it before I can resize/rescale it. Would not be much better to click directly on the ends of segment? Just idea.
                            I did not yet check the last plugin.
                            Here is the file:
                            human body v6.skp
                              @rumcajs said:
                              ...Yes, I work during my sleep!...
                              Interesting. I have something similar: I sleep during my work! ๐Ÿ˜ฎ
                              ...It was that I could draw soft edges or smooth edges directly...
                              Maybe with this plugin? http://forums.sketchucation.com/viewtopic.php?t=37359
                                The box is here :Menu WIndow / Soften edges ๐Ÿ˜‰
                                Else subdivision modeling for Sketchup is here ๐Ÿ˜‰
                                Artisan by Whaat (39$ )
                                A free very basic is here by Rick Wilson
                                or more recent with another concept by guitar list
                                http://www.guitar-list.com/files/styles/article-pic/public/gearpics/Smooth-glass.jpg
                                http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=26902;image
                                All for segments and vertex is here : Vertex Tools by Thomthom (20 $)
                                  About the neck
                                  Why do you say that is not more part of the body ?
                                  Seems it is ๐Ÿ˜„
                                  In front view inside the level of the group / component
                                  Just make a box selection from right to left (so else who touch this box is selected) on the "cone neck"
                                  then right click / reverse faces
                                  When you move a segment of the neck it moves also the body, so it's makes part of the body ๐Ÿ˜„
                                    rumcajs
                                    The color. Why the neck has blue color and the body is white?
                                    • numbthumbN Offline
                                      numbthumb
                                      Reversed faces.
                                      Comfortably numb...
                                        Yep reverse face : blue can't receive the light of sun (so internal faces - backface)
                                        White = receive the light of sun (so external faces)
                                        Useful for the render program !
                                        If you select one face of a volume* then right Click / Orient faces (different than Reverse faces !!! )
                                        all faces of the volume will take the "work's color" (blue or white) of the first face clicked!
                                        • if the volume is well built ๐Ÿ˜‰
                                          rumcajs
                                          I've got it.
                                          Any suggestions how to correct shoulders muscles, up on collar bone? So called posterior lateral triangle of Trapezius muscle? This is the muscle which leads from top of shoulder up to neck.
                                          http://4.bp.blogspot.com/-QSWjVVJqt0k/T_W7sQDyQJI/AAAAAAAAA0E/rkmUw573Jis/s1600/8_31_10-shoulder+muscles.jpg
                                          Also I tried the Cross Section tool to add a circle bellow neck from Tgi3D, but it writes to me: Cannot resolve cross section. This is after I reversed the neck faces. I don't know if it is the cause, because this should not have effect. I click just outside the neck. Try.
                                          Question:
                                          Do you know some video tutorial how to model head from the sphere or oval? This head does not look good at all. I don't need to model face, but just the main proportions of the head.
                                          human body v6.skp
                                            rumcajs
                                            Q: When I try to rotate arms, should I rotate it outside or inside model? I see my model's arms are not exactly in same (mirrored) position.
                                            • 1 / 4
