    Sample Model for Rendering - Loft w Telescope
    46 Posts 14 Posters 7.2k Views 14 Watching
    • Al HartA
      Al Hart
      First try with IRender nXt
      Placed a background image outside the window, made the telescope body reflective and made the window itself a light source.
      Al Hart
      IRender nXt from Render Plus
      • Al HartA
        Al Hart
        @chedda said:
        A couple of things stand out, the harvest moon has an orange glow, the scene does not. Also the window frames do not meet the wall. The shadows are not really that realistic either. Being a loft and the fact you are looking up to me means that you wouldn't really see the top of the trees either. I've never use IRender nXt it looks like it renders fast is there anyway to increase the quality ?
        Thanks for taking a look and for your comments. (I am always amazed how artistic people can see things that I do not see when they view a rendering.)
        I just wanted to get a quick version out - hopefully to inspire some other people to render it with their own favorite rendering engine.
        IRender nXt is a multi-pass renderer - meaning that the longer you let it render the better it gets. The image below was rendered for 500 passes and about an hour. To get better and better resolution of the shadows I could let in render overnight.
        I liked the trees - so lets assume our loft is in a valley near a hill.
        I could have placed the background on an actual surface - further outside the window - and then made it a light. I will do that for my next version.
        Even better would have been an actual HDRi sky - which would have then used all the actual objects in the sky as light sources. But it is always a challenge to find a good night sky as an HDRi.
        Also, I made the window itself the light source - which means that the shadows are all coming from the point of the window. Using the moon as a light source would make them more realistic.
        Al Hart
        • cheddaC
          chedda
          Yes Al Night sky HDR's are hard to find, however i believe you can make your own using hi res images. I make mine with Maxwell but i expect photoshop or some other editor can also do this.
          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
            Roger
            Night sky
            Here is a night sky photo I took in Sonoita, Arizona. You are welcome to use it as a sky source. Let me know if you need a larger image.
            http://www.azcreative.com
              The best guy for astronomic photos! 😉
              Robert Gendler 😉
              Totally amazing! 😲 😮 😎
                Roger
                Telescope_room
                Here is how I would visualize that scene. Keep in mind you could never have a view like that unless the moon was about 10 times closer and then the tidal forces on earth would be wreaking all kinds of havoc.
                • Bryan KB
                  Picky, picky. 😄
                  Very nice render. I like the softness. I might try this tonight.
                  • david_hD
                    david_h
                    I dunno . .. I think I have done something wrong. . .
                    • Bryan KB
                      Who you gonna call?!
                      • Bryan KB
                        What a pain. Took me an hour. I couldn't get the starscape to show after 8 tries. Couldn't get the light right. There was something wrong with the window and I had to delete it altogether.
                        However, it rendered in mere minutes. 👍
                        Kerkythea.
                        You really need to view it on a dark/black screen/border background for the full effect.
                        As usual, click on each image for the bigger stand alone picture.
                        • david_hD
                          david_h
                          well I see your problem right off the bat. . .you've got draco where andromeda should be. . .Ursa Major in your first house, and Capricorn in your seventh house. . ..
                          I'd move into an apartment. 💚
                          • Bryan KB
                            DOH! I knew something was wrong! 😆
                            • Al HartA
                              Al Hart
                              @roger said:
                              [attachment=0:kp2w2k8m]<!-- ia0 -->telescope_room.jpg<!-- ia0 -->[/attachment:kp2w2k8m]
                              Do you want to mention which rendering engine you used so I can put the result on SketchUpRendering.com?
                              Al Hart
                                Roger
                                @al hart said:
                                @roger said:
                                [attachment=0:6kvfnt10]<!-- ia0 -->telescope_room.jpg<!-- ia0 -->[/attachment:6kvfnt10]
                                I did not use a rendering engine. All were Post Production modifications of your render done in PhotoShop.
                                • Al HartA
                                  Al Hart
                                  AHA! You photo shop guys are amazing!
                                  Al Hart
                                  • david_hD
                                    david_h
                                    Still not workin' quite right. . .
                                    • Al HartA
                                      Al Hart
                                      Here's another attempt with lots of stars and a reflective floor.
                                      Some light is coming from the ceiling, and some light from those bright stars.
                                      I also had to remove one of the semi-transparent window things.
                                      (rendered with IRender nXt)
                                      Al Hart
                                      • soloS
                                        Whoah!! is this a room in a space ship?
                                          Roger
                                          Too late meteor warning system.
                                          • Al HartA
                                            Al Hart
                                            I think the whole idea of a loft and a telescope would inspire the imagination of the the viewer, and could cause some non-realistic "photo-realistic" images - such as the large bright moons, and the bright colorful stars.
                                            Al Hart
                                            • 1 / 3
