    Circle orientation other than Z_axis?
    5 Posts 2 Posters 321 Views 2 Watching
      tomot
      I'm in need for some code to orient a circle forming a stair railing, which needs to be normal to the riser/tread triangular relationship
      see attachment.
          edges = entities.add_edges(@pt1, @pt2)
          circle = entities.add_circle(@pt1, Z_AXIS, 1.inch, 16)
          base = entities.add_face(circle)
          base.back_material = Sketchup;;Color.new (255,200,100)
          base.followme(edges)
      my plugins
      tomot
        An edge has a 'line'.
        That's a two element array of the start point and its vector.
        So point=edge.line[0] and vector=edge.line[1]
        Use 'vector' instead of an 'axis' and also the 'center' can be 'point'...
          tomot
          do I replace the Z_AXIS code with your code?
          my plugins
          tomot
            Your ' @pt1' can be replaced with any point you specify - like edge.line[0]
            and the circle's 'normal' is any vector you specify - it doesn't have to be the z-axis [ Z_AXIS] so any vector, like edge.line[1], will do as well...
            The radius [' i.inch'] in your code can also be whatever you want it to be...
            And the ' 16' that sets the umber of segments, can also be what you like...
              tomot
              It took a while for your medication to be absorbed πŸ˜„
                      vector = $pt2a - $pt1a
                      edges1 = entities.add_edges($pt1a, $pt2a)
                      circle = entities.add_circle($pt1a, vector, 1.inch, 16)
                      base.back_material = Sketchup;;Color.new (255,200,100) #use RGB Color numbers
                      base.followme(edges1)
              using my coded example: subtracting the 2 points creates a 3d vector which is normal to any circle.
              my plugins
              tomot
