    Curves
    27 Posts 4 Posters 1.5k Views 4 Watching
      You can draw your own sphere with the Follow me tool πŸ˜‰
      from diffrent behaviour
      here one
      incease your number of segments / circle or arc circle following that you want
      maybe max is 100
      Click the circle call the Followme tool then click the surface
      by Driven
      http://forums.sketchucation.com/download/file.php?id=82508&t=1
        rumcajs
        This is my result
        http://i48.tinypic.com/116pc2q.png
          Try with this one πŸ˜‰
          Don't hesitate to make some try, Arc surface perpendicular, no perpendicular, rotate it, surface out the circle etc...
          It's a funny world! β˜€
          boule.skp
            rumcajs
            Very nice sphere. How to complete? I never succeed to close it with Follow me. I remember there was some truck in tutorial, but that one never worked for me.
            Edit:
            Now I succeed to close it. But if I would have bigger object, how to follow whole the path? I know there is some trick like double click or triple click.
            When I will add a texture to the sphere, how can I resize size of the texture. I know how to do it with one face, but with more faces, it looks like imposible.
              rumcajs
              There is a hole in top and a stair. I had these problems. When I wanted to draw a circle inside circle:
              1. I could not find the center point
              2. I had to start upward so when I wanted to move it back, I could not to find centerpoint again
              3. I had problem to draw the circle on different axis even that I hold arrow right or left.
              my_sphere.skp
                FOr find the center of an arc circle or a circle use this plug by Chris Fullmer
                Just 2 segments following are sufficient
                Else you can just draw a line on the top, a mine on the bottom (so diameter)
                then draw a line from middle of the 2 diameters)
                  rumcajs
                  Well, nice plug-ins you recommend to me. Nice tricks. I have seen one more plugin in the video here:
                  http://forums.sketchucation.com/viewtopic.php?t=18963
                  he bended a "pipe". Do you know what plugin it is? It also looks very cool.
                    Yes It's Fredo Scale by Fredo 6 πŸ˜‰
                    For the diameter without plug you can also made this
                    Menu WIndows / Model Info and put the maximum precision (number of decimal)
                    When you draw your line after the first click look inside the little box screen right bottom
                    When the length is maximum it's your diameter πŸ˜‰
                      rumcajs
                      I something did wrong because around the sphere of mine, there is a circle in the middle. I wanted to delete the circle but the circle is exploded. I think I could just to rotate the sphere in good position (circle to be horizontal)... select, and then I found that ... oh no there are also other edges selected not only the circle... So is there a way how to select the whole cicle? I use selection tools but did not find a way. And the second problem, is that if I delete the circle, so it deletes some surface under it. Probably I had made some mistake when creating the sphere.
                        Group (or make component) for geometry you've finished to separate it and protect it from damage by your next actions. Back up work. Save an extra file now and then.
                          rumcajs
                          These are just funny tries no need for components here or backing up. But in the future work sure. Bending the tubes is very funny
                            rumcajs
                            Do you know how to bend her hand with fredo scale tools
                            so it would looked naturally bended?
                            http://i46.tinypic.com/vrx8uu.png
                              Super cool never thought to bend a 2D image with the Fredo Scale! πŸ‘
                              • 2 / 2
