    Pour changer un peu...
    1.2k Posts 28 Posters 976.5k Views 28 Watching
      Semble attirant 😄 Open Source!
      Salome
      Easy to Create/modify, import/export (IGES, STEP, BREP), repair/clean CAD models
      Supports interoperability between CAD modeling and computation software (CAD-CAE link).
      Mesh CAD models, edit mesh, check mesh quality, import/export mesh (MED, UNV, DAT, STL)
      Makes easier the integration of new components into heterogeneous systems for numerical computation.
      Easy to Handle physical properties and quantities attached to geometrical items
      Display computation results (scalar, vectorial)
      Provides a generic user-friendly and efficient user interface, which helps to reduce the costs and delays of carrying out the studies.
      Reduces training time to the specific time for learning the software solution based on this platform
      Manage studies (create, save, reload)
      Provides access to all functionalities via the integrated Python console.
      http://www.salome-platform.org/about/screenshots/geom1.png/image_large
      http://www.salome-platform.org/about/screenshots/visu1.png/image_large
        En VF 😉
        http://www.polyloop.net/attachment.php?attachmentid=32451&d=1345549340
        La création
        Le pack et installation
        [flash=560,315:24c9r2mv]http://www.youtube.com/v/h72YFffJSPw[/flash:24c9r2mv]
          By Meats Meier avec Zbrush 😉
          http://www.zbrushcentral.com/attachment.php?attachmentid=317158
          http://www.zbrushcentral.com/attachment.php?attachmentid=319983
          http://www.zbrushcentral.com/attachment.php?attachmentid=319275
          http://www.zbrushcentral.com/attachment.php?attachmentid=319276
            Ai fait cela aussi
            Chapitres 8 à 14
            Chapitres 15 à 17 (fin)
            la suite dans pas longtemps 😄
            Et puis la version VF de ça aussi de Thomthom qui va bientôt sortir (20 € je crois) 😉
            [flash=560,315:oyps3xrn]http://www.youtube.com/v/xfM02PleFMg[/flash:oyps3xrn]
              Terminé ! ☀
              le What new in Zbrush 4R4! VF
              Y compris le fameux QRemesher! 😒
              M'en vais pouvoir terminer le manuel d'Artisan pour Sketchup! 😉
              [flash=560,315:23aqj79f]http://www.youtube.com/v/iRSZ8lO15_8[/flash:23aqj79f]
              • DVERGERD
                DVERGER
                Très bonne idée!
                  En attendant déjà le manuel de Vertex Tools 😉
                    Moment of Inspiration (Moi pour les intimes) 💚
                    beta V3 du 2 septembre 2012
                    Bibliothèque Solids++ mise à jour
                    Commande Gordon améliorée
                    la version Mac OSX devrait marcher avec OSX 10.8 Mountain Lion
                    MoI, 3D modeling for designers and artists
                    MoI is a new 3D Modeling/CAD application for designers and artists. Offering a blend of precision and freeform NURBS drawing tools, it sports a unique user interface that operates seamlessly with a pen tablet.
                    (moi3d.com)
                    Mise à jour de la Commande Gordon - Correction d'un bug qui faisait que les résultats du réseau étaient très grumeleux dans certaines circonstances, le correctif doit donner des surfaces de meilleure qualité. Il ya aussi un nouveau "Mode" d'option que vous pouvez ajuster pour modifier le comportement du raccord.
                    Mode = "Normal" correspond aux courbes limites de la tolérance normale de construction. Ce qui que la surface résultante épouse la forme de la limite des courbes avec une précision suffisante de manière à pouvoir être reliées à d'autres choses construites hors de ces mêmes courbes.
                    Mode = "Léger" rend la surface apte à une perte de tolérance, ce qui rend plus légère la surface, mais qui adhère moins aux courbes frontières.
                    Mode = "Personnalisé" - vous permet d'entrer une valeur de tolérance numérique de votre choix.
                    Mode = "Uniforme" - vous permet d'entrer dans un certain nombre de points - chaque section du réseau est apte avec ce nombre de points de contrôler par région plutôt que d'affiner les choses de manière adaptative pour répondre à une tolérance de distance comme les autres modes.
                    Vous pouvez utiliser l'un des modes autres que «Normal» si vous voulez afficher une surface moins contrainte et plus légère au détriment de la contraindre pas aussi étroitement aux courbes frontières. Donc, une chose à noter si vous utilisez Gordon, c'est qu'il ya maintenant une étape supplémentaire à la commande où vous pouvez régler le mode, et la commande ne sera pas terminée tant que vous n'appuyez pas sur «Terminé» ou faites un clic droit sur cette nouvelle étape supplémentaire.
                    Ajustement de la courbe: Mise à jour de la commande Rebuild (Reconstruire) pouvez maintenant génèrer un ajustement avec la même précision que précédemment, mais avec moins de points de contrôle (souvent environ la moitié du nombre) utilisé. La case à cocher "Supprimer les objets d'entrée" est maintenant activée par défaut pour les recréer.
                    Correction d'un bug avec l'Union booléenne lorsque certaines surfaces ouvertes ont été utilisées dans le cadre du booléen, où, dans certaines circonstances, il ne savait pas reconnaître et éliminer les "parois intérieures" entre les 2 régions solides. Cela corrige le bug signalé sur le forum ici: http://moi3d.com/forum/index.php?we...OI&msg=4388.160
                    Mise à jour de manière que la touche Alt tenue également supprime les snaps "fermés" snap lors de l'élaboration d'une courbe ou une polyligne même qu'il supprime d'autres Snaps. Rapport sur le forum ici: http://moi3d.com/forum/index.php?webtag=MOI&msg=5338.1
                    La gestion des fichiers sur Mac OSX fixe de telle sorte que l'un des caractère: "* <> | peut être utilisé avec un nom de fichier ou de répertoire maintenant - déjà un nom de fichier avec l'un de ces caractères ne fonctionnerait pas correctement, ce qui est un effet secondaire, certains d'entre eux étant des caractères génériques illégaux dans Windows.
                      Comme j'ai reçu un cadeau empoisonné, j'ai été voir du côté de Groboto! 💚
                      (très léché comme interface, mais pas hyper simple à prendre en main, par contre le résultat à l'écran est
                      est remarquable! 😎
                      Le manuel est une pure merveille pour les yeux, mais comment dire, plus que fourni! 😲
                      [flash=560,315:3p2yluoo]http://www.youtube.com/v/q4FoEYptQvA[/flash:3p2yluoo]
                      [flash=560,315:3p2yluoo]http://www.youtube.com/v/Wp3-98ZGIas[/flash:3p2yluoo]
                      Impressionnant 😲
                      [flash=560,315:3p2yluoo]http://www.youtube.com/v/nK2g_ItzBCs[/flash:3p2yluoo]
                      [flash=560,315:3p2yluoo]http://www.youtube.com/v/5PrJk9PFlOE[/flash:3p2yluoo]
                      Le pourquoi du comment Groboto peut être utile par rapport à un modeleur Poly normal 😄 Minute 9.40
                      [flash=560,315:3p2yluoo]http://www.youtube.com/v/N3wN9MssMKg[/flash:3p2yluoo]
                      [flash=560,315:3p2yluoo]http://www.youtube.com/v/NiQ7Btweh5g[/flash:3p2yluoo]
                      • DareDevilD
                        DareDevil
                        (très léché comme interface, mais pas hyper simple à prendre en main, par contre le résultat à l'écran est remarquable! 😎
                        Comme j'adore le génératif et le paramétrique pour explorer ces approches en architecture, j'avais jeté un coup d'œil il y a quelques temps sur Groboto... C'est beau, c'est amusant, c'est puissant... Mais je ne suis pas arrivé à le faire rentrer dans un flux de conception pour l'architecture, trop complexe et difficile à maîtriser 😞
                        Si tu as des pistes pour l'aborder du "bon" coté, je reconsidèrerai peut-être mon point de vue...
                          C'est sûr que les "Snaps" pour de l'architecture sont un peu pénibles
                          On ne peut à priori en avoir qu'un à la fois car l'un empêche l'autre!
                          (a vérifier...mais je le verrais peut-être si je me decide à traduire le manuel 💚
                          Par contre je vais aller leur demander s'il n'y a pas moyen de récupérer
                          les objets sous un autres format que le natif, ou l'obj!
                          C'est peut-être du nurbs qui sait 😄
                            Rafraichissant! ☀
                            BY Bernard Gitton
                            son site est curieux... 💚
                              Sinon j'ai commencé le manuel GroBoto VF 😒
                              Je vous ferais signe quand ils sera terminé ! 😉
                                je vous l'avais, il y va fort le Nanard ! 😎
                                http://www.bernard-gitton.com/images/gitton1.GIF
                                  Bien avancé pour ce qui est de Groboto, 😄
                                  mais pas trop encore le manuel, car en fait leur documentation est labyrinthique! 😲
                                  Les bases étaient ailleurs! 😒
                                    3D Coat 😉
                                    [31.08.2012] 3.7.18A
                                    • Les outils de retopo ont les outils Extruder Faces en mode sélection de faces - http://bit.ly/MC23kz
                                    • Autre amélioration retopo - Outil selection automatique Sommet/ Arêtes / Faces. Double-clic va sélectionner la zone connectée.
                                    • La Sélection devient additive. Utilisez CTRL D ou ÉCHAP ou cliquez en dehors du maillage retopo pour désélectionner.
                                    • Nouvelle fonction interface utilisateur globale - si vous changez quelque chose en faisant glisser la souris manuellement, vous pouvez appuyer sur ESPACE, puis entrez la valeur exacte numérique. La barre d'espace a maintenant une double action - choisit généralement l'outil, mais dans les outils où vous pressez souris et faites glisser quelque chose, elle permet d'entrer une valeur précise. Il est appliqué aux gizmo, outils primaires, outil d'anneau dans la chambre retopo.
                                    • import-expor Collada (DAE) présenté comme première bêta.
                                    • Ajouter / découper des Quads peut travailler dans l'espace libre aussi si vous fixez des polygones à la géométrie existante.
                                    • Paramètres généraux de Retopo déplacés à la ligne de menu pour économiser de l'espace.
                                    • Outils Points & faces retopo se sont d'améliorés:
                                      (1) Possibilité d'assigner un autre outil sur CTRL, MAJ, CTRL + MAJ - http://bit.ly/NpAMYE
                                      (2) la possibilité de créer des quads seulement,
                                      (3) la possibilité de travailler dans un espace libre
                                    • Dans cette construction, il y aura possibilité de naviguer avec les touches fléchées, ALT + flèches et NUM + -. Dans de nombreux cas, il est commode. Il suffit de choisir le système de navigation "3D-Coat_Arrows"
                                      *- Des problèmes d'instanciation et proxy fixés - http://3d-coat.com/mantis/view.php?id=588
                                    • Correction problème retopo qui conduit à la disparition des faces (rarement) après soudage des sommets voisins.
                                      de manière d'obtenir une bonne combinaison artistique "sur l'oeil" et des outils précis pour un travail précis.
                                    • Grandes listes de bugs de Mantis fixés.
                                      Qubicle
                                      Des nouvelles du front! 😉
                                      ça mijote, ça cogite fort! ☀
                                      Rien encore à l'horizon ultra proche mais des trucs prometteurs! 😉
                                      Fait cela en 1200 milli-secondes 😲
                                      Quasi temps réel (dans le sens Maya --> Qubicle, voxélisation cubique)
                                      http://www.qubicle-constructor.com/forum/download/file.php?id=106
                                        Encore un système de présentation de folie! Pinterest
                                        Cliquez sur Pub du jour 😉 (en haut à droite)
                                        J'ai mélangé avec Pearltress qui est lui un système de gestion des liens! 😉
                                        Vertigineux tout ça! 😲
                                        Ce qui est bien c'est que l'on peut s'en servir de manière privée! ☀
                                        Dommage que le bandeau d'arrivée de Pinterest soit si moche! 😮
                                        Regardez ce que cela donne avec ZBrush 😉
                                        ou la sauce tomate 💚
                                        [flash=560,315:1qei28b2]http://www.youtube.com/v/H1JSvir2CIo[/flash:1qei28b2]
                                        • DVERGERD
                                          DVERGER
                                          Je rêve, c'est un mirage! 😎
                                          Enfin quelqu'un qui rentre dans le chou de Blender et de son interface soporifique! 💚
                                          Je viens de voir cela ici ☀
                                          A suivre mais c'est vrai que pour moi rentrer dans Blender... heu comment dire... je me suis cogné plusieurs fois avant de faire demi-tour.
                                          Je vois que vous avez commencé à discuter icones/pas icones. Rien que l'exemple de la molette sur SU pour faire tourner le modèle c'est 100 fois plus rapide qu'un raccourci clavier (+ zoom avant/arrière tjs avec la molette).
                                          • DVERGERD
                                            DVERGER
                                            Merci j'ai pu découvrir le blog "Urban Sketchers" grâce à cela, j'adore ce qu'ils font.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 58
                                            • 59
                                            • 17 / 59
