    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 519.1k Views 114 Watching
    • bmikeB
      bmike
      @seasdes said:
      Thanks Sonder and Bmike. So it is my understanding that Any building component that I want displayed in the section view should be modelled in Sketchup rather than trying to draw it in Layout. Also linework in layout should be limited to annotation type lines. Is this correct?
      I think it's just easier to draw it in SketchUp and detail in LayOut, but I have used methods similar to Sonders where I explode geometry or trace over geometry to get the drawing and detail I need.
      But the short answer, for me is, draw it once, and cut it up and scene it out.
        sonder
        Great video Mike! We have very similar workflow. Anything that has to do with the design is in SU. All notation, dimensions and drafting elements like grids or symbols are in Layout. The only difference is I pull the section cut linework such as the post, into Layout to vector render it over the raster render.
        And yes the PDF files get pretty large. I have one set of CD's that is 425Mb!
        • utilerU
          utiler
          Gee Nick, there must be something you can do about that!!! How do you transfer files to sub- consultants electronically? πŸ˜•
          Just Curious...
            sonder
            I lower the PDF file size through acrobat if need be. Typically I just use Dropbox so the best quality goes through. The 400+mb files are out to bid to 4 contractors and no one has complained. All contractors only received the download link. The print quality at that size is outstanding.
            • utilerU
              utiler
              I bet it is!!!! πŸ‘
              Just Curious...
              • W
                whitelock
                @bmike said:
                Another small project for a workshop.
                https://lh3.googleusercontent.com/-M9q773YwJH8/T6p8LKfkUMI/AAAAAAAASwY/doQR7UawG4s/s1111/oldstonebarn-3-22-11_01.jpg
                https://lh4.googleusercontent.com/-yLUqMkN0uhk/T6p8Lm0pT1I/AAAAAAAASwc/pYLzFNPq-9A/s1111/oldstonebarn-3-22-11_14.jpg
                https://lh5.googleusercontent.com/-g0JVrNLkqXo/T6p8MJ-W7aI/AAAAAAAASws/3NtM1N1e1rA/s1111/oldstonebarn-3-22-11_15.jpg
                https://lh4.googleusercontent.com/-B0tHwN6dO_I/T6p8M5AslGI/AAAAAAAASw0/LaGqNH2fnHo/s1111/oldstonebarn-3-22-11_16.jpg
                On deck are 2 small buildings - I'm taking the entire process through SU and LO, as well as another small timber frame workshop project (similar in scope to these drawings).
                Here's hoping Trimble sees the value in LayOut and ups the development of it. It is my go to tool now for taking 3d to 2d.
                Hi, Beautiful detail sheets can you tell me what settings you use for your styles?
                • daleD
                  dale
                  This is an excellent question. Our electrical and mechanical engineers all request dxf/dwg drawings as they take our base drawings and build theirs on that.
                  Can you export layout in dxf/dwg?
                  • beginnerB
                    beginner
                    Yes you can export in DWG or DXF (AC12 to AC2010)
                    http://forums.sketchucation.com/viewtopic.php?f=12&t=47135&p
                    Regards, SU 'beginner'
                    • daleD
                      dale
                      Thanks beginner. I'm just starting to consider Layout for final working drawings, but having a proper set of dxf/dwg drawings for other consultants is a must.
                      Doesn't sound flawless, so I might have to take certain drawings (ie floorplans, reflected ceiling plans) from SketchUp into one of my Cad programs first on order to accomplish this. Too bad.
                      • beginnerB
                        beginner
                        Hi Dale,
                        Have a look this...
                        http://forums.sketchucation.com/viewtopic.php?f=12&t=47488
                          sonder
                          Yes you can and in either model or paper space. What I do for my consultants and my floor plans is create a group from slice in the section tool. This accurately isolates simply line work of a plan or section. Then export that group only as a dwg file. They then have a simple background without all the crap that they usually have to erase. So far my structural engineers and surveyors have commented on how my drawings are the easiest to deal with. Pretty funny considering I don't even open ACAD to provide them.
                          • daleD
                            dale
                            Thanks Sonder. That will tilt me over the edge to Layout.
                            I'm sure there will be lots of questions ahead.
                            Dale
                            • bmikeB
                              bmike
                              another recent project:
                              https://lh5.googleusercontent.com/-U-EwYdi2sLk/UFCialLe_II/AAAAAAAATsI/OmnhcXPFBxY/s800/barn1.jpg
                              https://lh3.googleusercontent.com/-SP2sdU4ho7k/UFCiawfvwtI/AAAAAAAATsQ/a6GocncGtS8/s800/barn2.jpg
                              https://lh5.googleusercontent.com/-zOCKblZaYyM/UFCibGoYdVI/AAAAAAAATsY/1Kd10KN3PV4/s800/barn3.jpg
                              https://lh6.googleusercontent.com/-lYSQ76479nQ/UFCibd78eMI/AAAAAAAATsg/5ZtvTyKqa3c/s800/barn4.jpg
                              https://lh4.googleusercontent.com/-nm_llXvalOo/UFCib99wz-I/AAAAAAAATsk/mkLVkK2IK14/s800/barn5.jpg
                              https://lh6.googleusercontent.com/-hd3dqkROaKA/UFCicA6VTLI/AAAAAAAATsw/78lawNA-jcg/s800/barn6.jpg
                              https://lh5.googleusercontent.com/-BlJIu6KX2mA/UFCicioq0pI/AAAAAAAATs4/Tww8g9UEz5w/s800/barn7.jpg
                              • porch_unpluggedP
                                porch_unplugged
                                very nice. did you do your foundation details as 2D's in layout?
                                • bmikeB
                                  bmike
                                  the foundation details are 'typical' and were pasted in as a PDF from my engineer.
                                  if you look at the 'Round Barn' project I modeled the foundation details in SketchUp, then detailed in LayOut.
                                  • ccaponigroC
                                    ccaponigro
                                    Thought I would jump in here. I'm pretty new to sketchup but have 30 years of acad disappointment under my belt. Right now I use Architectural Desktop for plans and schedules and creating a model from them for all my elevations and layout to present them. I wanted them to look like b/w CD's so I saved the model and changed all the textures to have no color. I would love to do everything in layout but it is hard to give up all the bim and attribute extraction. This is a real project with real clients so it was a leap of faith since I had never used sketchup for a real project before this. We have a permit and it's under construction. The clients love being able to see the model. Constructive criticisum welcome.
                                    I know the grade is rough but I'm flying by the seat of my pants here.
                                    Try drawing this in autocad I dare you.
                                    And some design development for the interiors.
                                    cfcaia.com
                                      mwm5053
                                      Very impresive πŸ‘
                                      2011 iMac
                                      SU 2015 Pro, 2017 Make
                                      V2 Twilight
                                      macOS Sierra 10.12.5
                                      • pbacotP
                                        Really nice work! Thanks for posting and the information.
                                        A trick I have used in LO to hide the terrain and create a ground line: trace along the ground line in LO, making a polygon- complete the polygon, below, to mask the terrain with fill, make a duplicate and trim this to use as a thick ground line (without fill)
                                        • ccaponigroC
                                          ccaponigro
                                          Thanks! I like that idea and it sure wouldn't hurt to get that terrain turned off.
                                          cfcaia.com
                                          • pbacotP
                                            Yes, actually don't need the terrain layer to be on, but you may want something to draw the ground line to, at least at first.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 22
                                            • 23
                                            • 16 / 23
