    Test of renderers
    extensions
    10 Posts 6 Posters 901 Views 6 Watching
    • V Offline
      vito157
      Here http://sketchup.org.pl/?p=78is a test of renderers. The site is in Polish language, but it's just pictures ...
        What is the winner and what is the time render ?
        • V Offline
          vito157
          Time is under picture.
          No winner! Renderer it's yours choice!
          • beginnerB Offline
            beginner
            1. Summary
              4.1. Rendering Time
              The fastest is TheaRender – only 56 seconds. Next is: Artlantis (1 min 08 sec) and VRay (3 min 03 sec)
              4.2. Passes count within one hour
              The most passes done by Twilight (182), next TheaRender (71) and IRender nXt (39).
            Regards, SU 'beginner'
            • FrederikF Offline
              Frederik
              Have to say that I personally don't like these tests that much... 😐
              Settings can be tweaked and adjusted and render times will be very different depending on these settings...
              It's really difficult to setup a model, where materials etc. are close to identical in the various render apps...
              I.e. if another material had been used for the glass in the Thea render, the render time might have increased 10 times caused by caustic reflections on the wall... (remember this is just an example...)
              Also the result with Indigo seem to be a combination of material and render settings... A little unfair IMO...
              Cheers
              Kim Frederik
              • beginnerB Offline
                beginner
                Any rendering test should be carried out based on results against time with a little twist...
                The final render has to be as close as possible to the real thing provided - VASE WITH SOME FLOWER but, you would 'lose points' if the time to produce is excessive.
                In principle - there is a time limit at the outset like in all SU's challenges on SUF πŸ˜‰ 😲 πŸ˜†
                  Will be funny to put it in Lumion! πŸ˜‰
                  • beginnerB Offline
                    beginner
                    And LightUp... πŸ˜‰
                    • soloS Offline
                      Meh!
                      There is absolutely no merit to these "tests", complete waste of time.
                      I have always been very clear on how one tests a render solution, and this is not it.
                        jpalm32
                        Why don't they post the scene? Don't seem right.
