    Grass!
    extensions
    37 Posts 9 Posters 13.4k Views 9 Watching
    • jason_marantoJ Offline
      jason_maranto
      Yes, I agree -- I've been hopeful for tools like these ever since Maxwell started supporting hair/fur.
      Make sure to read the docs here: http://support.nextlimit.com/display/maxwelldocs/Grass#
      Particularly the "Level of Detail" parameters -- they can really help with keeping resource usage manageable when working inside SketchUp (although my preference is to work with Grass inside Maxwell Studio, so I can use all of my RAM).
      Best,
      Jason.
      • N Offline
        ninopiamonte
        I have a question,
        I have Maxwell Render 2.6, fully licensed, but is it possible to upgrade/update to 2.7 without buying
        and still licensed?
        Btw, I have also download a 2.7 patch, but it tells that "Maxwell 2.0 could not be found in your system, The patch cannot be installed. Please reinstall Maxwell Render 2.0 to solve this problem."
        Thanks,
        NP
          jason_maranto
          When you say you have Maxwell 2.6 are you talking about the full "Maxwell Render Suite" or the "Stand Alone Plugin"?
          Both can be updated to 2.7 for free (assuming you have the previous version) but each has different installers and you would need to download the proper installer to successfully update.
          If you want to, you can just download the full 2.7 installer (as opposed to the update installer) to have a clean install -- your license will work since it is valid for all 2.x releases of whichever type of Maxwell you purchased ("Stand Alone Plugin" or full "Render Suite").
          If you persists in having issues it is best to ask the devs directly on the Maxwell forum.
          Best,
          Jason.
          • cheddaC Offline
            chedda
            Here is my test, i'm quite pleased with the outcome.
            Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
              jason_maranto
              That looks really nice!
              I've done some tests that I've been pleased with as well. Here's one that incorporates a leaf litter MXM for the ground (textures originally free from http://www.photosculpt.net/) -- in this case I used 2 grass modifiers stacked(with different seed values), one for green grass and one for "dried" yellow grass, using a density map for both:grasstest2.jpg
              The yellow grass is down low to the ground, with altered geometry settings to help integrate the grass better into the "leaf litter" base. The green grass is just the MXM I linked in the first post.
              Best,
              Jason.
              • cheddaC Offline
                chedda
                Okay Jason that's super bad (meaning good) i'm kinda gobsmacked.
                  Mainline411
                  Do I need Maxwell to run this if not how do I install and use it?
                    jason_maranto
                    Yes, it is part of the Maxwell plugin, the grass is generated inside Maxwell at render-time based on the parameters you specify.
                    Best,
                    Jason.
                      Mainline411
                      Best,
                      Jason.
                      So Maxwell is payware?
                      • BurkhardB Offline
                        Burkhard
                        You can have a standalone version for free and for a small fee ( better Renderprocess and higher output )
                        Grass is restricted to 1 object + 1 grass type with the free version
                        http://www.maxwellrender.com/index.php/maxwell_for_sketchup
                        ...and the Maxwell Suite.
                        http://www.ia-plus.de
                        • utilerU Offline
                          utiler
                          Yep, at $195 that is a really nice solution for the user who wants more power than the $95 "stand-alone" SketchUp plugin, but doesn't need huge renders or network rendering. The really nice thing about that is it includes all of the Maxwell plugins free (including the SketchUp plugin) -- so you could use Maxwell with several different packages (as I do).
                          I also found the Maxwell integration into Artlantis to be a rather interesting tidbit: http://www.artlantis.com/index.php?page=products/studio/news
                          Best,
                          Jason.
                          I wasn't aware that I could have paid $195.00 for a 'never to expire' licence rather I believe the $95.00 option was only available when it was released.... I bit annoying that I have to now paid again. 😲
                          Just Curious...
                            jason_maranto
                            Pay again? I'm not sure what you mean -- the license doesn't expire... none of them do.
                            Best,
                            Jason.
                            • utilerU Offline
                              utiler
                              I was reffering to this Jason but then realised that is was for education purposes.... my bad. 😳
                              Just Curious...
                              • pietervP Offline
                                pieterv
                                Hello Jason,
                                What's up? 😉
                                Can the grass in Maxwell 2.7 also be applied on more organic terrain in sketchup? I have tried but these "cracks" appear... Can you help me with this please? Thanks!
                                http://www.citypixels.be/wp-content/uploads/2012/10/sloped-hill.jpg
                                http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-008.jpg
                                This is my website:
                                Citypixels - 3d Visualisatie Architectuur
                                  jason_maranto
                                  It can be used on such surfaces -- however there was a bug in the 2.7 release that revealed density control problems with subdivided surfaces. This was alleviated in the 2.7.10 release:
                                  (support.nextlimit.com)
                                  http://www.maxwellrender.com/forum/viewtopic.php?f=107&t=39134
                                  Also, when working in Maxwell Studio it is best to stack several grass modifiers on one piece of geometry (to mix the randomization in several ways) -- which IMO gives a more naturalistic look. However this is a bit difficult to do in the current SketchUp plugin so I don't recommend you try it there.
                                  Best,
                                  Jason.
                                  • pietervP Offline
                                    pieterv
                                    I'm sorry, I didn't write it right: I am actualy using 2.7.1 here
                                    This is my website:
                                      jason_maranto
                                      It could have something to do with the irregular shape and distribution of the subdivision. I just made a 10x10m patch (subd every 0.5m) using the sandbox tools and here is the initial result:
                                      As you can see there is still some slight artifacting from the subdivisions, but not as bad as yours.
                                      To alleviate this I added a copy of the same geometry set .01m below the current surface with the same grass settings except the Density>Seed value set differently -- this is the only current way to "stack" grass modifiers like I would in Maxwell Studio, but as you can see it does the trick pretty well (aside from slower renders):
                                      I would definitely prefer to do these types of things in Maxwell Studio (for now) so as to avoid duplicate geometry (and all the render costs it incurs)... I typically stack 2-5 grass modifiers for any scene I'm doing with grass.
                                      Best,
                                      Jason.
                                      subd_grasstest.skp
                                      • pbacotP Offline
                                        That looks great Jason. Can one add more variation in texture to create more randomness without the extra rendering load.
                                          jason_maranto
                                          If you are talking about in the "sculpted" geometry, unfortunately not -- this is limited by the grass settings and random seed value.
                                          If you are talking in Maxwell Studio then absolutely -- this is part of the reason for stacking modifiers. This way I can have several variations in materials (dry/dead grass, green grass, newshoots, etc.) and variations in the way the geometry is generated -- for instance: dead/dry grass is going to be much thinner and generally lower to the ground than green grass.
                                          In this way some clumping variation can be added for mixed grass types (very common in more wild areas) -- the sky is the limit. Just remember that for each stacked modifier you want to reduce the density amount accordingly so as to not end up with too many blades.
                                          Example: I have 1 modifier and conclude that a density of 4000 is sufficient -- if I add another modifier I should reduce both to a density of 2000 (or any balance that restores 4000 at the total number).
                                          Best,
                                          Jason.
                                          • pietervP Offline
                                            pieterv
                                            Hey Jason,
                                            I was not able to reproduce what you did with the sandbox tool. Also, when I apply the grass tool/ texture on a flat surface, very visible straight lines appear. Am I doing something wrong here?
                                            http://www.citypixels.be/wp-content/uploads/2012/10/simpel-huis-render-009.jpg
                                            http://www.citypixels.be/wp-content/uploads/2012/10/maxwell-leren-gras-002.jpg
                                            This is my website:
